souci d'affichage Le sujet est résolu
percute
bonjour, en premier lieu, merci d'être là.
voici les informations concernant mon système:
-Linux toto 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64 GNU/Linux
-01:00.0 VGA compatible controller: NVIDIA Corporation NV44 [GeForce 6200 TurboCache] (rev a1)
-lsmod|grep nouveau :
nouveau 1544192 4
mxm_wmi 16384 1 nouveau
wmi 16384 2 mxm_wmi,nouveau
video 40960 1 nouveau
ttm 98304 1 nouveau
drm_kms_helper 155648 1 nouveau
drm 360448 7 nouveau,ttm,drm_kms_helper
i2c_algo_bit 16384 1 nouveau
button 16384 1 nouveau
-je suis sous Debian stretch
-xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 340.46 (buildd@brahms) Tue Oct 7 08:00:32 UTC 2014
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nouveau"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
-dmesg tail
[ 36.745218] gnome-session-f[3111]: segfault at 0 ip 00007f8c982b7e19 sp 00007fff517e58d0 error 4 in libgtk-3.so.0.2200.11[7f8c97fd5000+700000]
[ 37.960253] gnome-session-f[3157]: segfault at 0 ip 00007eff53166e19 sp 00007ffe473bd470 error 4 in libgtk-3.so.0.2200.11[7eff52e84000+700000]
[ 44.468501] gnome-session-f[3220]: segfault at 0 ip 00007fcd5465be19 sp 00007ffc6bf6d2c0 error 4 in libgtk-3.so.0.2200.11[7fcd54379000+700000]
[ 44.869190] gnome-session-f[3267]: segfault at 0 ip 00007f1899aece19 sp 00007ffe89f609f0 error 4 in libgtk-3.so.0.2200.11[7f189980a000+700000]
[ 47.546471] gnome-session-f[3332]: segfault at 0 ip 00007f281f756e19 sp 00007ffc70679e30 error 4 in libgtk-3.so.0.2200.11[7f281f474000+700000]
[ 48.620991] gnome-session-f[3396]: segfault at 0 ip 00007fcf3fcb1e19 sp 00007ffce91d6ab0 error 4 in libgtk-3.so.0.2200.11[7fcf3f9cf000+700000]
[ 49.722802] gnome-session-f[3460]: segfault at 0 ip 00007fe1ca2bae19 sp 00007ffc42f8fb20 error 4 in libgtk-3.so.0.2200.11[7fe1c9fd8000+700000]
[ 50.843195] gnome-session-f[3524]: segfault at 0 ip 00007f313e4ebe19 sp 00007ffe1e348c40 error 4 in libgtk-3.so.0.2200.11[7f313e209000+700000]
[ 51.963198] gnome-session-f[3588]: segfault at 0 ip 00007fe641268e19 sp 00007ffc1452cfa0 error 4 in libgtk-3.so.0.2200.11[7fe640f86000+700000]
Mon souci:
Au démarrage, X ne se lance pas . Après plusieurs tentatives infructueuses, le système me bascule en mode console.
Je connecte donc mon utilisateur, et je lance la commande 'startx', ce qui me permet d'avoir un affichage.
seulement, je n'ai que deux modes possibles (640x480 et 700x400)
-xrandr me donne:
Screen 0: minimum 320 x 200, current 640 x 480, maximum 4096 x 4096
VGA-1 connected primary 640x480+0+0 (normal left inverted right x axis y axis) 376mm x 301mm
640x480 59.94*
720x400 70.08
DVI-I-1 disconnected (normal left inverted right x axis y axis)
TV-1 disconnected (normal left inverted right x axis y axis)
Je précise que je préfèrerai garder le pilote 'nouveau' si possible.
Voilà , je suis à votre écoute, merci d'avance.
Rien que pour avoir fait un premier message aussi bien posé je te laisse un message ;)
Juste pour info c'est un portable ou une tour ?
percute
Ah oui, j'avais oublié de le préciser , c'est une tour. Merci pour ta prompte réponse
pour cette carte vous devriez installer le pilote propriétaire nvidia fourni par le paquet nvidia-legacy-304xx-driver. Il faudra d'abord ajouter non-free à votre sources.list et recharger avec la commande "apt update" ensuite vous installez le paquet indiqué.
percute
merci, mais ais-je réellement un problème de pilote, ou est-ce simplement qu'il manque une ligne quelque part dans un fichier quelconque ? Car après des années de galère avec l'affichage sous GNU/Linux, je me suis aperçu que les soucis venaient souvent d'une mauvaise configuration.
le fichier xorg.conf n'existe plus et il n'est pas dit que le pilote nouveau prenne en charge votre carte, alors essayez avec le pilote proprio nvidia.
hybridemoineau
marcastro a écrit : 03 juil. 2017, 17:56 le fichier xorg.conf n'existe plus et il n'est pas dit que le pilote nouveau prenne en charge votre carte, alors essayez avec le pilote proprio nvidia.
Je le croyais aussi mais si si, il existe encore si on en a besoin. J'ai dû en créer un pour faire marcher marcher xbacklight sous Stretch.
marcastro a écrit : 03 juil. 2017, 17:27
La carte graphique est compatible avec Nouveau d'après ce fil.
https://forum.ubuntu-fr.org/viewtopic.php?id=1078421
ce que confirme cette page
https://h-node.org/videocards/view/en/1 ... ---rev-a1-
Du coup, c'est bien un problème de réglage....
Et il y a deux problèmes:
- Le segfault avec Gnome (encore un bug de gdm3 ou une incapacité à basculer en mode allégé suite à l'absence de prise en charge de la carte graphique?)
- l'affichage par défaut
Que raconte le fichier .xsession-errors ? (dans /home/user/). Je suppose que ça bascule sur Vesa, mais pourquoi ?
Perso, je passerai en mode single user, virerai (en le mettant de côté) le fichier de conf, désinstallerai les paquets en Xorg, les réinstallerai, en faisant gaffe au noyau et à ce qui se passe (il me semble, mais je dis peut-êtrer une énorme co...) qu'il faut les headers du noyau d'installés ainsi que dkms pour que ça marche..
+1;j'ai oublié de mentionner; mais j'installerais tout de même le pilote proprio.
percute
dkms ? je viens de vérifier et je n'ai pas nvidia-kernel-dkms, peut être est-ce que cela vient de là. Le problème, c'est qu'il y a énormément de dépendances qui vont avec, et j'ai peut de ne plus avoir d'affichage du tout ensuite, comme ça arrive dès qu'on bidouille.
percute
peut-être dois-je d'abord désinstaller le pilote 'nouveau' avant ?
hybridemoineau
Installer le paquet dkms suffit.
En mode single user, sans session graphique, je commencerai par virer les paquets xorg, et à ne réinstaller que les paquets nécessaires.
Tu peux avoir la liste des paquets et méta paquets xorg avec cette commande:
aptitude search xorg | grep ^i
Après le choix est entre un affichage pourri et momentanément pas d'affichage. Il faut vivre dangereusement et momentanément.
percute
On va essayer ça, je vous tiens au courant de l'évolution
percute
Bon bon bon, ma tentative s'est soldée par un échec. J'ai viré gnome au cas où (en 640x480, il ne me sert pas à grand-chose). Exit aussi tous les paquets nvidia, dkms et consorts (nvidia-dkms m'installe une version non supportée par ma carte).
Don en gros au point de départ avec des paquets en moins , hi hi, c'est comme quand on bricole il reste toujours une vis dont on ne fait rien.
hybridemoineau
C'est trop vague tout ça...Comment as-tu procédé ? dkms est installé ?
Tu as encore une session graphque ou pas ? Sinon, installe xfce4 même temporairement par exemple.
Surtout, poste le retour des commandes suivantes:
cat /home/ton_nom-d'utilisateur/.xsession-errors
uname -a
percute
oui, j'ai de nouveau une session graphique, la même qu'au commencement, avec le pilote 'nouveau' que j'ai réinstallé. Pour dkms, le paquet est présent, je n'ai viré que nvidia-dkms.
hybridemoineau
percute a écrit : 03 juil. 2017, 23:30 oui, j'ai de nouveau une session graphique, la même qu'au commencement,
C'était quoi au commencement ? Si tu as des graphiques sans Gnome, mais avec je-ne-sais-quoi, c'est sans doute parce que Gnome nécessite je-ne-sais-quelle accélération que nouveau ne prend pas. Il faut choisir entre nouveau et gnome.
percute a écrit : 03 juil. 2017, 23:30 , avec le pilote 'nouveau' que j'ai réinstallé. .
En virant les autres paquets ?
Et sinon, pour le fun
hybridemoineau a écrit : C'est trop vague tout ça...
uname -a
percute
J'ai les graphiques avec le bureau 'mate' sinon, voici les retours des commandes demandées.
i A xorg-docs-core - documentation de base pour le système X Window d’X.Org
i A xorg-sgml-doctools - outils communs pour bâtir de la documentation SGML d’X.Org
i A xserver-xorg - serveur X X.Org
i A xserver-xorg-core - serveur⋅X X.Org – base du serveur
i xserver-xorg-dev - serveur X pour X.Org – fichiers de développement
i A xserver-xorg-input-evdev - serveur⋅X X.org - pilote de clavier et de pointage evdev
i A xserver-xorg-input-libinput - serveur X pour X.Org — pilote d’entrées libinput
i A xserver-xorg-input-mouse - Serveur X X.Org — pilote de souris
i A xserver-xorg-legacy - enveloppe pour le serveur X d’X.Org avec les droits du superutilisateur
i A xserver-xorg-video-fbdev - serveur X X.org - pilote d'affichage fbdev
i xserver-xorg-video-nouveau - serveur X X.org - pilote d'affichage Nouveau
i A xserver-xorg-video-vesa - serveur X X.Org - pilote d'affichage VESA
uname -a
percute
et mon Xsession-errors
session: X session started for phi at mardi 4 juillet 2017, 01:45:44 (UTC+0200)
dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
dbus-update-activation-environment: setting DISPLAY=:0
dbus-update-activation-environment: setting XAUTHORITY=/home/phi/.Xauthority
localuser:phi being added to access control list
dbus-update-activation-environment: setting GTK_MODULES=gail:atk-bridge
gpgconf: warning: can not open config file /home/phi/.gnupg/gpg-agent.conf: Aucun fichier ou dossier de ce type
dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
dbus-update-activation-environment: setting QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
OpenGL version: 2.
dbus-update-activation-environment: setting MAIL=/var/mail/phi
dbus-update-activation-environment: setting USER=phi
dbus-update-activation-environment: setting SHLVL=1
dbus-update-activation-environment: setting HOME=/home/phi
dbus-update-activation-environment: setting XDG_SESSION_COOKIE=aa7f1864c2afd4636edc5b055488bea0-1499108954.579593-2094047149
dbus-update-activation-environment: setting HUSHLOGIN=FALSE
dbus-update-activation-environment: setting LOGNAME=phi
dbus-update-activation-environment: setting _=/usr/bin/startx
dbus-update-activation-environment: setting TERM=linux
dbus-update-activation-environment: setting WINDOWPATH=3
dbus-update-activation-environment: setting PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
dbus-update-activation-environment: setting LANG=fr_FR.UTF-8
dbus-update-activation-environment: setting LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
dbus-update-activation-environment: setting SHELL=/bin/bash
dbus-update-activation-environment: setting GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
dbus-update-activation-environment: setting PWD=/home/phi
dbus-update-activation-environment: setting XDG_DATA_DIRS=/usr/share/mate:/usr/local/share/:/usr/share/
Failed to run gnome-keyring-daemon: L'exécution du processus fils « gnome-keyring-daemon » a échoué (Aucun fichier ou dossier de ce type)
x-session-manager[13966]: WARNING: Unable to find provider '' of required component 'dock'
Avertissement du gestionnaire de fenêtres : Impossible de charger le thème « Fog » : Impossible de trouver un fichier valide pour le thème Fog
Avertissement du gestionnaire de fenêtres : Impossible de charger le thème « Simple » : Impossible de trouver un fichier valide pour le thème Simple
Avertissement du gestionnaire de fenêtres : Impossible de charger le thème « MurrinaLoveGray » : Impossible de trouver un fichier valide pour le thème MurrinaLoveGray
Avertissement du gestionnaire de fenêtres : Impossible de charger le thème « MurrinaCandido » : Impossible de trouver un fichier valide pour le thème MurrinaCandido
Avertissement du gestionnaire de fenêtres : Impossible de charger le thème « Murrine-Sky » : Impossible de trouver un fichier valide pour le thème Murrine-Sky
Avertissement du gestionnaire de fenêtres : Log level 16: g_object_set_valist: object class 'MetaFrames' has no property named 'type'
x-session-manager[13966]: WARNING: Could not launch application 'vmware-user.desktop': Unable to start application: L'exécution du processus fils « /usr/bin/vmware-user-suid-wrapper » a échoué (Aucun fichier ou dossier de ce type)
Starting Dropbox...
(mate-panel:13989): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dropbox isn't running!
Done!
Gtk-Message: Failed to load module "atk-bridge"
[14166:14197:0704/014553:ERROR:nss_util.cc(839)] After loading Root Certs, loaded==false: NSS error code: -8018
Avertissement du gestionnaire de fenêtres : Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x2a00001 (Jeux en li)
Avertissement du gestionnaire de fenêtres : meta_window_activate called by a pager with a 0 timestamp; the pager needs to be fixed.
[WARNING:flash/platform/pepper/pep_module.cpp(63)] SANDBOXED
Fontconfig error: Cannot load default config file
[14166:14166:0704/014617:ERROR:logging.h(813)] Failed to call method: org.freedesktop.DBus.ObjectManager.GetManagedObjects: object_path= /: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out
** (pluma:14513): WARNING **: Could not load theme icon gtk-home: L'icône « gtk-home » n'est pas présente dans le thème Fog
(pluma:14513): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Vector smash protection is enabled.
(polkit-mate-authentication-agent-1:14007): Gtk-CRITICAL **: gtk_widget_set_halign: assertion 'GTK_IS_WIDGET (widget)' failed
(polkit-mate-authentication-agent-1:14007): Gtk-CRITICAL **: gtk_widget_set_valign: assertion 'GTK_IS_WIDGET (widget)' failed
(polkit-mate-authentication-agent-1:14007): Gtk-CRITICAL **: gtk_box_pack: assertion 'GTK_IS_WIDGET (child)' failed
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
Avertissement du gestionnaire de fenêtres : Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x1200007 (S'authenti)
Discarding: 8 over 9
hybridemoineau
D'après le retour des commandes, comme Mate a l'air de fonctionner correctement, j'en déduis que le pilote nouveau n'est pas compatible avec Gnome qui nécessite le max de ta carte graphique, donc le pilote proprio indiqué plus haut par Marcastro (nvidia-glx, je crois)...
percute
Bien, merci à tous pour vos conseils. Après bien des hésitations, j'ai finalement installé le pilote 'nvidia-legacy-304xx-driver' et tout fonctionne comme je le désire.
Pour info si ca peut aider quelqu'un:
1- apt-get remove --purge xserver-xorg-video-nouveau
2- fermer la session X
3- CTRL+ALT+F1(ou F3...)
4- login + mot de passe
5- su + mot de passe
6- init 1
7- mot de passe root
8- dans /etc/X11/xorg.conf.d/xorg.conf on échange dans la section 'device' 'nouveau' par 'nvidia', on enregistre.
9- reboot
10- et hop
note: je n'ai pas de gestionnaire de connexion d'installé (gdm, gdm3 etc) donc pour moi c'est login en utilisateur et 'startx'
