téléchager une playlist commplete depuisyt
pour charger une chanson depuis youtube, j'utilise youtube-del -x.
Mais je dois le faire chansons par chansons . je n'ai pas trouvé l'option pour charger toutes les chansons d'une playlist exemple:
Vous noterez que c'est la version "music" de youtube, je trouve la qualité sonore meilleure que sur la version "video" du site.
Salut !
Je n'utilise jamais de playlist, d'ailleurs il doit y en avoir de plusieurs types (pls, m3u, ...)
et comme je ne vais plus sur YT
Mon unique idée :
$ man youtube-dl | grep -i playlist
              Continue on download errors, for example to skip unavailable videos in a playlist
              Abort downloading of further videos (in the playlist or the command line) if an error occurs
       --flat-playlist
              Do not extract the videos of a playlist, only list them.
       --playlist-start NUMBER
              Playlist video to start at (default is 1)
       --playlist-end NUMBER
              Playlist video to end at (default is last)
       --playlist-items ITEM_SPEC
              Playlist  video  items to download.  Specify indices of the videos in the playlist separated by commas like: "-- playlist-items 1,2,5,8" if you want to download videos indexed 1, 2, 5, 8 in
              the playlist.  You can specify range: " --playlist-items 1-3,7,10-13", it will download the videos at index 1, 2, 3, 7, 10, 11, 12 and 13.
       --no-playlist
              Download only the video, if the URL refers to a video and a playlist.
       --yes-playlist
              Download the playlist, if the URL refers to a video and a playlist.
       --playlist-reverse
              Download playlist videos in reverse order
       --playlist-random
              Download playlist videos in random order
              Simulate, quiet but print JSON information for each command-line argument.  If the URL refers to a playlist, dump the whole playlist information in a single line.
       • playlist (string): Name or id of the playlist that contains the video
       • playlist_index (numeric): Index of the video in the playlist padded with leading zeros according to the total length of the playlist
       • playlist_id (string): Playlist identifier
       • playlist_title (string): Playlist title
       • playlist_uploader (string): Full name of the playlist uploader
       • playlist_uploader_id (string): Nickname or id of the playlist uploader
       Output templates can also contain arbitrary hierarchical path, e.g.  -o '%(playlist)s/%(playlist_index)s - %(title)s.%(ext)s' which will result in downloading each video in a directory correspond‐
              # Download YouTube playlist videos in separate directory indexed by video order in a playlist
              $ youtube-dl -o '%(playlist)s/%(playlist_index)s - %(title)s.%(ext)s' https://www.youtube.com/playlist?list=PLwiyx1dc3P2JR9N8gQaQN_BCvlSlap7re
              # Download all playlists of YouTube channel/user keeping each playlist in separate directory:
              $ youtube-dl -o '%(uploader)s/%(playlist)s/%(playlist_index)s - %(title)s.%(ext)s' https://www.youtube.com/user/TheLinuxFoundation/playlists
              $ youtube-dl -u user -p password -o '~/MyVideos/%(playlist)s/%(chapter_number)s - %(chapter)s/%(title)s.%(ext)s' https://www.udemy.com/java-tutorial/
   I'm getting an error Unable to extract OpenGraph title on YouTube playlists
       YouTube changed their playlist format in March 2014 and later on, so you'll need at least youtube-dl 2014.07.25 to download all YouTube videos.
   How do I download only new videos from a playlist?
       Use  download-archive feature.  With this feature you should initially download the complete playlist with --download-archive /path/to/download/archive/file.txt that will record identifiers of all
              youtube-dl --download-archive archive.txt "https://www.youtube.com/playlist?list=PLwiyx1dc3P2JR9N8gQaQN_BCvlSlap7re"
       will download the complete PLwiyx1dc3P2JR9N8gQaQN_BCvlSlap7re playlist and create a file archive.txt.  Each subsequent run will only download new videos if any:
tout semble en rapport avec des playlistes enregistées sur YT
Connais-tu la différence entre l'option -x que tu utilises
et
le format : -f 140
140 m4a audio only DASH audio , audio@128k
qui doit correspondre à bestaudio ?
Je vais regarder si ce que j'ai sur youtube.music sont bien des playlist.
Je n'ai jamais utilisé l'option -f.
Je vais regarder de plus prêt, car je souhaite télécharger de la meilleure qualité possible (ce qui n'était pas mon besoin jusqu'a présent)
J'ai testé :
youtube-dl -f 140 -o './%(playlist_index)s - %(title)s.%(ext)s' https://www.youtube.com/channel/UCbp9qY ... /playlists
ça m'a bien téléchargé les 4 premiers des 7 fichiers audio de la liste puis :
ERROR: unable to download video data: HTTP Error 403: Forbidden
a mis fin au téléchargement ; ça doit-être inhérent à la liste choisie ???
Solution
J'ai repassé la même commande en supprimant /playlists terminal de l'URL
et ytdl 'a repris correctement le téléchargement.
Résultat 2 listes placées chacune dans son répertoire :
/tests/ytdl$ tree
├── Apophis 2029
│   ├── 1 - Echelle de Turin.m4a
│   ├── 2 - 99942 Apophis 2029.m4a
│   ├── 3 - i21254-09.m4a
│   ├── 4 - MN4.m4a
│   ├── 5 - Le feu du ciel.m4a
│   ├── 6 - Possible Impact.m4a
│   └── 7 -  2036.m4a
└── Dern Universe
    ├── 1 - De la note au cerveau.m4a
    ├── 2 - Echo_hello.m4a
    ├── 3 - Lamentations de la planete Terre.m4a
    └── 4 - Equations from the Pleiades.m4a
2 directories, 12 files
Je ne peux pas tester en ce moment, j'ai des pb de connexion, je suis en litige avec Orange.
J'avais du mal utiliser l'option playlist lors de mes tests
