Bonjour à tous,
Je tourne actuellement sur Kali Linux, et j'ai installé virtualbox pour pouvoir lancer metasploitable.
Mais j'ai un message d'erreur (enfin plutôt deux)
Premier message d'erreur :
The virtual machine 'Metasploitable' has terminated unexpectedly during startup with exit code 1 (0x1).
Result Code:
NS_ERROR_FAILURE (0X80004005)
Component:
MachineWrap
Interface:
IMachine {300763af-5d6b-46e6-aa96-273eac15538a}
Et le deuxième dans un pop-up :
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please reinstall virtualbox-dkms package and load the kernel module by executing
'modprobe vboxdrv'
as root.
If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
J'ai essayé plusieurs méthode trouvées sur internet, mais rien ne marche.
Pourriez-vous me venir en aide svp ?
Erreur virtualbox
climboy
Re, oui j'ai essayé, mais cela n'a pas marché, et la commande donnée ne marche pas
Et si cela peux aider, voici ce qui est afficher quand j'ai installé virtualbox :
titouan@penguin:~/Downloads$ sudo apt-get install virtualbox -y
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
virtualbox-dkms virtualbox-qt
Suggested packages:
vde2 virtualbox-guest-additions-iso
The following NEW packages will be installed:
virtualbox virtualbox-dkms virtualbox-qt
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/51.1 MB of archives.
After this operation, 188 MB of additional disk space will be used.
Selecting previously unselected package virtualbox-dkms.
(Reading database ... 215472 files and directories currently installed.)
Preparing to unpack .../virtualbox-dkms_7.0.14-dfsg-1+b1_amd64.deb ...
Unpacking virtualbox-dkms (7.0.14-dfsg-1+b1) ...
Selecting previously unselected package virtualbox.
Preparing to unpack .../virtualbox_7.0.14-dfsg-1+b1_amd64.deb ...
Unpacking virtualbox (7.0.14-dfsg-1+b1) ...
Selecting previously unselected package virtualbox-qt.
Preparing to unpack .../virtualbox-qt_7.0.14-dfsg-1+b1_amd64.deb ...
Unpacking virtualbox-qt (7.0.14-dfsg-1+b1) ...
Setting up virtualbox-dkms (7.0.14-dfsg-1+b1) ...
Loading new virtualbox-7.0.14 DKMS files...
It is likely that 6.6.25-01713-g2f237acc8e50 belongs to a chroot's host
Building for
Setting up virtualbox (7.0.14-dfsg-1+b1) ...
Job for virtualbox.service failed because the control process exited with error code.
See "systemctl status virtualbox.service" and "journalctl -xeu virtualbox.service" for details.
invoke-rc.d: initscript virtualbox, action "restart" failed.
× virtualbox.service - LSB: VirtualBox Linux kernel module
Loaded: loaded (/etc/init.d/virtualbox; generated)
Drop-In: /run/systemd/system/service.d
└─zzz-lxc-service.conf
Active: failed (Result: exit-code) since Tue 2024-06-25 08:55:50 CEST; 35ms ago
Invocation: 2a272e36b4dd4859b0baaad10754e08a
Docs: man:systemd-sysv-generator(8)
Process: 20763 ExecStart=/etc/init.d/virtualbox start (code=exited, status=1/FAILURE)
Jun 25 08:55:50 penguin systemd[1]: Starting virtualbox.service - LSB: VirtualBox Linux kernel module...
Jun 25 08:55:50 penguin virtualbox[20763]: Loading VirtualBox kernel modules...
Jun 25 08:55:50 penguin virtualbox[20767]: libkmod: ERROR ../libkmod/libkmod-module.c:1814 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
Jun 25 08:55:50 penguin virtualbox[20767]: Error: could not get list of modules: No such file or directory
Jun 25 08:55:50 penguin virtualbox[20763]: No suitable module for running kernel found ... failed!
Jun 25 08:55:50 penguin virtualbox[20763]: failed!
Jun 25 08:55:50 penguin systemd[1]: virtualbox.service: Control process exited, code=exited, status=1/FAILURE
Jun 25 08:55:50 penguin systemd[1]: virtualbox.service: Failed with result 'exit-code'.
Jun 25 08:55:50 penguin systemd[1]: Failed to start virtualbox.service - LSB: VirtualBox Linux kernel module.
Setting up virtualbox-qt (7.0.14-dfsg-1+b1) ...
Processing triggers for kali-menu (2023.4.7) ...
Processing triggers for desktop-file-utils (0.27-2) ...
Processing triggers for hicolor-icon-theme (0.18-1) ...
Processing triggers for man-db (2.12.1-2) ...
Processing triggers for shared-mime-info (2.4-5) ...
Warning: program compiled against libxml 212 using older 209
Suggested packages:
Building for
climboy
titouan@penguin:~$ sudo apt-get install virtualbox-dkms
virtualbox-dkms est déjà la version la plus récente (7.0.14-dfsg-1+b1).
titouan@penguin:~$ sudo modprobe vboxdrv
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/6.6.25-01713-g2f237acc8e50
Essaie un
sudo apt-get --reinstall install virtualbox-dkms-
climboy
J'ai toujours le même message d'erreur quand je lance la machine, et voici le resultat de la commande :
titouan@penguin:~$ sudo apt-get --reinstall install virtualbox-dkms
0 mis à jour, 0 nouvellement installés, 1 réinstallés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 0 o/738 ko dans les archives.
Après cette opération, 0 o d'espace disque supplémentaires seront utilisés.
(Lecture de la base de données... 216101 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../virtualbox-dkms_7.0.14-dfsg-1+b1_amd64.deb ...
Deleting module virtualbox-7.0.14 completely from the DKMS tree.
Dépaquetage de virtualbox-dkms (7.0.14-dfsg-1+b1) sur (7.0.14-dfsg-1+b1) ...
Paramétrage de virtualbox-dkms (7.0.14-dfsg-1+b1) ...
Building for
Building for
climboy
Voici le resultat des commandes
titouan@penguin:~$ systemctl status virtualbox.service
Active: failed (Result: exit-code) since Wed 2024-06-26 09:44:46 CEST; 8h ago
Invocation: b6262d49d5a4406c855eb0fe7e36a5f9
Process: 292 ExecStart=/etc/init.d/virtualbox start (code=exited, status=1/FAILURE)
Warning: some journal files were not opened due to insufficient permissions.
Hint: You are currently not seeing messages from other users and the system.
Users in groups 'adm', 'systemd-journal' can see all messages.
Pass -q to turn off this notice.
-- No entries --
-- No entries --
Je ne comprends pas ton post, je t'ai proposer 2 commandes différentes pour regarder ce qui se passe, j'ai l'impression que tu as tout mis en un seul paquet.
De plus, la réponse est claire
A refaire en root.
Kali linux est réservée à des personnes maîtrisant un minimum linux, ce qui ne semble pas être ton cas.
Laisse tomber kali, et utilise une distribution plus adaptée à tes connaissances actuelles (par ex lmint LMDE).
Users in groups 'adm', 'systemd-journal' can see all messages.Kali linux est réservée à des personnes maîtrisant un minimum linux, ce qui ne semble pas être ton cas.
kali ne se maitrise pas en quelques heures. De plus, c'est une distribution orientée pentests. Il y a de nombreux pré-requis à maitriser avant d'aborder ce type de distribution.
On a tous commencé par des distributions généralistes grand public (pour moi c'était mandrake), puis on est passé à une distribution demandant un peu d'expérience (debian), pour enfin tester des distributions plus spécialisées (backtrack pour moi, mais aussi Archlinux par curiosité).
Etre débutant n'est pas une tare, juste un état à durée plus ou moins limité.
@climboy
Kali Linux demande effectivement des connaissances et ce n'est pas la distribution idéale pour commencer.
1) Tu as trouvé de l'aide ici puisque tu as obtenu des réponses pertinentes et bienveillantes...
2) Je ne vois aucun merci destiné à la personne qui a pris la peine de te lire et de te répondre...
GenZ ?
@climboy
Non la réponse de Piratebab était juste.climboy a écrit : 26 juin 2024, 21:37 Ta réponse est très vexante... C'est mon rêve de maîtriser ce genre de choses, et j’espérai trouver de l'aide ici. Apparemment, ce n'est pas le cas. Passe une bonne journée.
GenZ ?
