[Problème] Patch Kernel (Arch: amd64)
Drthrax74
Souhaitant compiler mon Kernel, j'ai téléchargé les sources du Kernel 6.15.0 puis appliquer les patchs.
Le patch 6.15.1 est bien passé, mais le patch 6.15.2 m'indique un message que je ne comprends pas.
Quelle serait la méthodologie et la logique pour bien appliquer les patchs.
Merci d'avance.
Préparation :
clear;
cd $HOME;
rm -r  /mnt/data/kernel 2>/dev/null;
mkdir -p /mnt/data/kernel;
cd /mnt/data/kernel;
Téléchargement des fichiers :
clear;
wget https://www.kernel.org/pub/linux/kernel/v6.x/linux-6.15.tar.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.1.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.2.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.3.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.4.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.5.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.6.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.7.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.8.xz;
wget https://www.kernel.org/pub/linux/kernel/v6.x/patch-6.15.9.xz;
Extraction :
clear;
tar xf ./linux-6.15.tar.xz;
unxz  patch-6.15.xz;
unxz patch-6.15.1.xz;
unxz patch-6.15.2.xz;
unxz patch-6.15.3.xz;
unxz patch-6.15.4.xz;
unxz patch-6.15.5.xz;
unxz patch-6.15.6.xz;
unxz patch-6.15.7.xz;
unxz patch-6.15.8.xz;
unxz patch-6.15.9.xz;
Version du Kernel:
clear;
cd ./linux-6.15;
make kernelversion;
# 6.15.0
Patch 1:
patch -p1 < ../patch-6.15.1
make kernelversion;
# 6.15.1
checking file Makefile
checking file arch/arm64/boot/dts/intel/socfpga_agilex5.dtsi
checking file arch/arm64/boot/dts/qcom/ipq9574.dtsi
checking file arch/arm64/boot/dts/qcom/sa8775p.dtsi
checking file arch/arm64/boot/dts/qcom/sm8350.dtsi
checking file arch/arm64/boot/dts/qcom/sm8450.dtsi
checking file arch/arm64/boot/dts/qcom/sm8550.dtsi
checking file arch/arm64/boot/dts/qcom/sm8650.dtsi
checking file arch/arm64/boot/dts/qcom/x1e001de-devkit.dts
checking file arch/arm64/boot/dts/qcom/x1e80100-asus-vivobook-s15.dts
checking file arch/arm64/boot/dts/qcom/x1e80100-dell-xps13-9345.dts
checking file arch/arm64/boot/dts/qcom/x1e80100-hp-omnibook-x14.dts
checking file arch/arm64/boot/dts/qcom/x1e80100-lenovo-yoga-slim7x.dts
checking file arch/arm64/boot/dts/qcom/x1e80100-qcp.dts
checking file arch/arm64/boot/dts/qcom/x1e80100.dtsi
checking file arch/arm64/boot/dts/rockchip/rk3399-puma.dtsi
checking file arch/arm64/boot/dts/rockchip/rk3576.dtsi
checking file arch/arm64/boot/dts/ti/k3-am62-main.dtsi
checking file arch/arm64/boot/dts/ti/k3-am62a-main.dtsi
checking file arch/arm64/boot/dts/ti/k3-am62p-j722s-common-main.dtsi
checking file arch/arm64/boot/dts/ti/k3-am62x-sk-csi2-imx219.dtso
checking file arch/arm64/boot/dts/ti/k3-am62x-sk-csi2-ov5640.dtso
checking file arch/arm64/boot/dts/ti/k3-am62x-sk-csi2-tevi-ov5640.dtso
checking file arch/arm64/boot/dts/ti/k3-am65-main.dtsi
checking file arch/arm64/boot/dts/ti/k3-am68-sk-base-board.dts
checking file arch/arm64/boot/dts/ti/k3-j721e-sk-csi2-dual-imx219.dtso
checking file arch/arm64/boot/dts/ti/k3-j721e-sk.dts
checking file arch/arm64/boot/dts/ti/k3-j722s-evm.dts
checking file arch/arm64/boot/dts/ti/k3-j722s-main.dtsi
checking file arch/arm64/boot/dts/ti/k3-j784s4-j742s2-main-common.dtsi
checking file drivers/iommu/iommu.c
checking file drivers/perf/arm-cmn.c
checking file fs/coredump.c
checking file fs/pidfs.c
checking file include/linux/coredump.h
checking file include/linux/iommu.h
checking file net/sched/sch_hfsc.c
Patch 2:
patch -p1 < ../patch-6.15.2
patching file Documentation/devicetree/bindings/phy/fsl,imx8mq-usb-phy.yaml
patching file Documentation/devicetree/bindings/pwm/adi,axi-pwmgen.yaml
patching file Documentation/devicetree/bindings/remoteproc/qcom,sm8150-pas.yaml
patching file Documentation/devicetree/bindings/usb/cypress,hx3.yaml
patching file Documentation/firmware-guide/acpi/dsd/data-node-references.rst
patching file Documentation/firmware-guide/acpi/dsd/graph.rst
patching file Documentation/firmware-guide/acpi/dsd/leds.rst
patching file Makefile
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED -- saving rejects to file Makefile.rej
patching file arch/arm64/boot/dts/intel/socfpga_agilex5.dtsi
Reversed (or previously applied) patch detected! Assume -R? [n]
Tentative de compilation du Kernel 6.15.0 : (KO)
Sans patch
clear;
export ARCH=x86_64
KERNEL=6.15
WORKDIR=/mnt/data/kernel
cd       $HOME;
rm -r    $WORKDIR 2>/dev/null;
mkdir -p $WORKDIR;
cd       $WORKDIR;
wget https://www.kernel.org/pub/linux/kernel/v6.x/linux-$KERNEL.tar.xz  2>/dev/null;
tar xf ./linux-$KERNEL.tar.xz;
cd $WORKDIR/linux-$KERNEL;
make mrproper;
make oldconfig;
make menuconfig;
make oldconfig;
make prepare;
make -j$(nproc) bzImage;
make -j$(nproc) modules;
sudo make headers_install
sudo make modules_install;
sudo make install;
Comme indiqué dans le message d'erreur, tu tentes d'appliquer un patch déja appliqué, ou annullé.
Drthrax74
Si j'ai bien compris le patch 2 est un ajout du patch 1 dans ce cas présent et donc la partie déjà appliquée pourrait être ignoré ?
Comment on peut savoir si un patch a été annulé ?
Si tu n'as jamais compilé de kernel, tu devrais commencer par plus simple: compiler le kernel déja patché par debian
https://wiki.debian.org/BuildADebianKernelPackage
Et si tout est OK, tu pourras ajouter d'autres patch. De quelle fonctionnalité ssupplémentaires as tu besoin qui ne seraient pas dans le noyau debian ?
Tu peux aussi t'inspirer de ce que font les personnes de chez https://liquorix.net/
Drthrax74
Je souhaite apprends le patchage et pas avoir un kernel tout prêt.
Inspire toi de https://kernel-team.pages.debian.net/ke ... n-official et décortique leur script de configuration des patch. Ca te fera une première expérience
Drthrax74
En utilisant wiggle, j'ai constaté que certain patch supérieur refaisait ce que le patch inférieur faisait et donc ça se répète.
Entre chaque patch, le fichier Makefile est à éditer et modifier la valeur SUBLEVEL = X par la version du patch qu'on a appliqué.
cd linux-6.15
wiggle --replace Makefile Makefile.rej
1 unresolved conflict found
wiggle --replace ./arch/arm64/boot/dts/ti/k3-am68-sk-base-board.dts arch/arm64/boot/dts/ti/k3-am68-sk-base-board.dts.rej
1 already-applied changes ignored
Makefile
J'ai modifié la valeur 1 en 2 dans ce cas présent, car ce paramètre permet de connaitre la version du kernel.
<<<<<<< found
SUBLEVEL = 1
||||||| expected
SUBLEVEL = 0
SUBLEVEL = 2
>>>>>>> replacement
