smartctl on /dev/sda
voici la sortie du test sur /dev/sda:
  • root@sda1-sparky:/home/avram# smartctl -l selftest /dev/sda
    smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.11.0-1-amd64] (local build)
    Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
    SMART Self-test log structure revision number 1
    Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
    # 1 Short offline Completed: read failure 90% 38929 2714457
    # 2 Short offline Completed: read failure 90% 38231 2657968
    # 3 Short offline Completed: read failure 90% 38231 2657968
    # 4 Short offline Completed: read failure 90% 38230 2657968
    # 5 Short offline Completed: read failure 90% 38195 2657968
    # 6 Short offline Completed: read failure 90% 38187 2657968
    # 7 Short offline Completed: read failure 40% 38187 2657968
    # 8 Short offline Completed: read failure 90% 38186 2657968
    # 9 Short offline Completed: read failure 90% 38186 2657968
    #10 Short offline Completed: read failure 90% 38186 2650250
    #11 Short offline Completed: read failure 90% 38185 2650250
    #12 Short offline Completed without error 00% 38078 -
    #13 Short offline Completed without error 00% 32588 -
    #14 Short offline Completed without error 00% 22686 -
comment je dois comprendre ce résultat; bon ou pas bon?
marcastro a écrit :read failure 90%
marcastro a écrit : comment je dois comprendre ce résultat; bon ou pas bon?
...quand même , généralement ce n'est pas bon , surement dû a un head crash du disque
regarde les blocks
sudo fsck -cc /dev/sda
