hashut
Messages : 25 Inscription : 25 oct. 2017, 11:56
Status :
Hors-ligne
17 nov. 2017, 15:40
Bonjour all
j'ai des erreurs sur GDM3 impossible a lancer
gnome-session
/usr/lib/gnome-session/gnome-session-binary: symbol lookup error: /usr/local/lib/libcairo-gobject.so.2: undefined symbol: cairo_region_destroy
systemctl restart gdm3
l écran clignote 3X et je reviens sur le promt
systemctl status gdm3
● gdm.service - GNOME Display Manager
Loaded: loaded (/lib/systemd/system/gdm.service; static; vendor preset: enabled)
Active: active (running) since Fri 2017-11-17 10:57:23 CET; 4h 41min ago
Main PID: 20032 (gdm3)
Tasks: 3 (limit: 4915)
CGroup: /system.slice/gdm.service
└─20032 /usr/sbin/gdm3
nov. 17 11:07:09 debian.net-utyl.org systemd[1]: Reloading GNOME Display Manager.
nov. 17 11:07:09 debian.net-utyl.org gdm3[20032]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
nov. 17 11:07:09 debian.net-utyl.org gdm3[20032]: GLib-GObject: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
nov. 17 11:07:09 debian.net-utyl.org gdm3[20032]: GLib-GObject: invalid unclassed pointer in cast to 'GdmSettings'
nov. 17 11:07:10 debian.net-utyl.org systemd[1]: Reloaded GNOME Display Manager.
nov. 17 11:10:15 debian.net-utyl.org systemd[1]: Reloading GNOME Display Manager.
nov. 17 11:10:15 debian.net-utyl.org gdm3[20032]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
nov. 17 11:10:15 debian.net-utyl.org gdm3[20032]: GLib-GObject: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
nov. 17 11:10:15 debian.net-utyl.org gdm3[20032]: GLib-GObject: invalid unclassed pointer in cast to 'GdmSettings'
nov. 17 11:10:15 debian.net-utyl.org systemd[1]: Reloaded GNOME Display Manager.
une idée serais la bien venus
merci
Messages : 527 Inscription : 24 août 2016, 19:35
Status :
Hors-ligne
17 nov. 2017, 17:25
Tu pourrais nous indiquer ta version avec les retours de ces commandes
$ uname -a
# cat /etc/debian_version
et ensuite nous indiquer également le résultat de :
# apt-cache policy gdm3
# apt-listbugs list gdm3
# apt-listbugs list libcairo
Si d'autres personnes sont inspirées par ta description qu'elles n'hésitent à intervenir aussi.
hashut
Status :
Hors-ligne
17 nov. 2017, 18:02
uname -a
Linux debian.net-utyl.org 4.9.0-4-amd64 #1 SMP Debian 4.9.51-1 (2017-09-28) x86_64 GNU/Linux
gdm3:
Installé : 3.22.3-3
Candidat : 3.22.3-3
Table de version :
*** 3.22.3-3 500
500 http://ftp.fr.debian.org/debian stretch/main amd64 Packages
100 /var/lib/dpkg/status
bogues de gravité serious sur gdm3 (-> ) <Résolus dans une version donnée>
b1 - #850291 - gdm3: does not work without gnome-session (Corrigé : gdm3/3.22.3-4 gdm3/3.24.2-3)
Résumé :
gdm3(1 bogue)
Systemclt restart gdm3 et systemclt status gdm3
Active: active (running) since Fri 2017-11-17 18:01:36 CET; 6s ago
Process: 924 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status=0/SUCCESS)
Process: 921 ExecStartPre=/bin/sh -c [ "$(cat /etc/X11/default-display-manager 2>/dev/null)" = "/usr/sbin/gdm3" ] (code=exited, status=0/S
Main PID: 928 (gdm3)
Tasks: 4 (limit: 4915)
└─928 /usr/sbin/gdm3
nov. 17 18:01:37 debian.net-utyl.org gdm3[928]: Unable to kill session worker process
nov. 17 18:01:37 debian.net-utyl.org gdm-launch-environment][1122]: pam_unix(gdm-launch-environment:session): session opened for user Debian
nov. 17 18:01:38 debian.net-utyl.org gdm3[928]: GdmDisplay: display lasted 0,458342 seconds
nov. 17 18:01:38 debian.net-utyl.org gdm3[928]: Child process -1145 was already dead.
nov. 17 18:01:38 debian.net-utyl.org gdm3[928]: Child process 1122 was already dead.
nov. 17 18:01:38 debian.net-utyl.org gdm3[928]: Unable to kill session worker process
nov. 17 18:01:38 debian.net-utyl.org gdm-launch-environment][1171]: pam_unix(gdm-launch-environment:session): session opened for user Debian
nov. 17 18:01:38 debian.net-utyl.org gdm3[928]: GdmDisplay: display lasted 0,423847 seconds
nov. 17 18:01:38 debian.net-utyl.org gdm3[928]: GdmLocalDisplayFactory: maximum number of X display failures reached: check X server log for
nov. 17 18:01:38 debian.net-utyl.org gdm3[928]: Child process -1193 was already dead.
Status :
Hors-ligne
17 nov. 2017, 18:26
Si tu lis la description du bug #850291 tu verras qu'elle ressemble à ce que tu décris […]l écran clignote 3X et je reviens sur le promt
https://bugs.debian.org/cgi-bin/bugrepo ... bug=850291
If I try to run gdm3 while gnome-session is not installed, the greeter will not come up. It instead blanks and unblanks the screen repeatedly , presumably as it keeps respawning the greeter. Installing gnome-session fixes it.
En conclusion puisque le bug n'est corrigé qu'à partir de la version de gdm3/3.22.3-4 gdm3/3.24.2-3 et donc pas encore chez toi, il est vraisemblable que le même contournement du bug que celui indiqué par le déclarant du bug fonctionne chez toi, c'est à dire qu'il te faudrait installer gnome-session si mon raisonnement est correct.
donc :
# aptitude install gnome-session
hashut
Status :
Hors-ligne
21 nov. 2017, 16:40
salut
comme je me sert très peut du desktop pour remédier a mon problème j'ai des installer gnome et installer plasma-de
et cela fonctionne
merce a vous pour vos aides
