Noyau 4.14 plus de réseau... Le sujet est résolu
J'ai installé le noyau 4.14 sur ma stable (qui n'est évidemment plus tout à fait stable avec le noyau 4.14...).
# uname -r
4.14.0-3-amd64
# dpkg -l | grep '^ii' | grep `uname -r`
ii  linux-headers-4.14.0-3-amd64                                4.14.13-1                                  amd64        Header files for Linux 4.14.0-3-amd64
ii  linux-image-4.14.0-3-amd64                                  4.14.13-1                                  amd64        Linux 4.14 for 64-bit PCs
Bref, après reboot, plus de réseau (Plus d'interface réseau pour être précis...):
# ifconfig -a
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Boucle locale)
        RX packets 368  bytes 81288 (79.3 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 368  bytes 81288 (79.3 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
# /etc/init.d/networking restart
[....] Restarting networking (via systemctl): networking.serviceJob for networking.service failed because the control process exited with error code.
See "systemctl status networking.service" and "journalctl -xe" for details.
 failed!
# systemctl status networking.service
● networking.service - Raise network interfaces
   Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2018-02-05 10:05:15 EAT; 7s ago
     Docs: man:interfaces(5)
  Process: 12284 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
  Process: 12279 ExecStartPre=/bin/sh -c [ "$CONFIGURE_INTERFACES" != "no" ] && [ -n "$(ifquery --read-environment --list --exclude=lo)" ] && udevadm settle (code=exited, status=0/SUCCESS)
 Main PID: 12284 (code=exited, status=1/FAILURE)
févr. 05 10:05:15 nux ifup[12284]: than a configuration issue please read the section on submitting
févr. 05 10:05:15 nux ifup[12284]: bugs on either our web page at www.isc.org or in the README file
févr. 05 10:05:15 nux ifup[12284]: before submitting a bug.  These pages explain the proper
févr. 05 10:05:15 nux ifup[12284]: process and the information we find helpful for debugging..
févr. 05 10:05:15 nux ifup[12284]: exiting.
févr. 05 10:05:15 nux ifup[12284]: ifup: failed to bring up enp3s0
févr. 05 10:05:15 nux systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
févr. 05 10:05:15 nux systemd[1]: Failed to start Raise network interfaces.
févr. 05 10:05:15 nux systemd[1]: networking.service: Unit entered failed state.
févr. 05 10:05:15 nux systemd[1]: networking.service: Failed with result 'exit-code'.
Un coup de grep "failed" dans syslog:
Feb  5 09:59:47 nux systemd-udevd[286]: Process '/usr/sbin/alsactl -E HOME=/run/alsa restore 1' failed with exit code 99.
Feb  5 09:59:47 nux kernel: [    2.328064] ata2.01: failed to resume link (SControl 0)
Feb  5 09:59:47 nux kernel: [    2.328142] ata1.01: failed to resume link (SControl 0)
Feb  5 09:59:47 nux kernel: [   12.132023] kfd kfd: kgd2kfd_probe failed
Feb  5 09:59:48 nux ifup[601]: ifup: failed to bring up enp3s0
Feb  5 09:59:49 nux systemd[1]: networking.service: Unit entered failed state.
Feb  5 09:59:52 nux kernel: [   27.367884] CIFS VFS: cifs_mount failed w/return code = -101
Feb  5 09:59:52 nux systemd[1]: Dependency failed for Remote File Systems.
Feb  5 09:59:52 nux systemd[1]: remote-fs.target: Job remote-fs.target/start failed with result 'dependency'.
Feb  5 09:59:52 nux systemd[1]: home-laurent-NAS-public.mount: Unit entered failed state.
Feb  5 10:00:04 nux colord[750]: failed to get session [pid 595]: Aucun périphérique ou adresse
Feb  5 10:00:05 nux colord[750]: failed to get session [pid 595]: Aucun périphérique ou adresse
Feb  5 10:00:09 nux systemd[1]: fail2ban.service: Unit entered failed state.
Feb  5 10:00:10 nux systemd[1]: fail2ban.service: Unit entered failed state.
Feb  5 10:00:11 nux systemd[1]: fail2ban.service: Unit entered failed state.
Feb  5 10:00:36 nux amavis[1879]: (01879-01) (!)connect to /var/run/clamav/clamd.ctl failed, attempt #1: Can't connect to a UNIX socket /var/run/clamav/clamd.ctl: No such file or directory
Feb  5 10:00:36 nux amavis[1881]: (01881-01) (!)connect to /var/run/clamav/clamd.ctl failed, attempt #1: Can't connect to a UNIX socket /var/run/clamav/clamd.ctl: No such file or directory
Feb  5 10:00:38 nux freshclam[589]: Update failed. Your network may be down or none of the mirrors listed in /etc/clamav/freshclam.conf is working. Check http://www.clamav.net/doc/mirrors-faq.html for possible reasons.
Feb  5 10:00:51 nux dbus-daemon[5701]: [session uid=1000 pid=5683] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Feb  5 10:00:53 nux dbus-daemon[6242]: [session uid=1000 pid=6234] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Feb  5 10:05:15 nux ifup[12284]: ifup: failed to bring up enp3s0
Feb  5 10:05:15 nux systemd[1]: networking.service: Unit entered failed state.
Carte réseau "classique":
$ lspci | grep Ethernet
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 11)
Même punition avec le noyau linux-image-4.14.0-0.bpo.2-amd64.
Auriez-vous une idée du problème? J'ai pensé à apparmor, mais sans trop de conviction...
Donc, ton lien est 'enp3s0'... il n'arrive pas à monter !
Un coup de dmesg pour voir si le système le prend correctement en charge ?!
PengouinPdt a écrit : 05 févr. 2018, 12:45Donc, ton lien est 'enp3s0'... il n'arrive pas à monter !
Oui, c'est bien enp3s0. J'ai d'abord cru à un problème de nommage de l'interface (j'ai changé récemment la carte graphique, et j'ai eu droit à enp2s0 pendant un moment.
C'est revenu sur enp3s0...
Je redémarre (deux fois) et je reviens (comme j'ai pas de réseau avec le noyau 4.14 c'est pas super pratique de répondre ici rapidement... :icon_mrgreen: )
Je ne vois rien au sujet de la carte réseau, mais je passe probablement à côté.
[    0.000000] microcode: microcode updated early to revision 0x22, date = 2017-01-27
[    0.000000] Linux version 4.14.0-3-amd64 (debian-kernel@lists.debian.org) (gcc version 7.2.0 (Debian 7.2.0-19)) #1 SMP Debian 4.14.13-1 (2018-01-14)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.14.0-3-amd64 root=UUID=67dd4135-b99d-426f-8a19-a61b8b663143 ro quiet nouveau.modeset=0
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ca360fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ca361000-0x00000000ca367fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000ca368000-0x00000000caab3fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000caab4000-0x00000000caceafff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000caceb000-0x00000000dd619fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000dd61a000-0x00000000dd81cfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dd81d000-0x00000000dd86dfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000dd86e000-0x00000000dd915fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000dd916000-0x00000000ddf7ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ddf80000-0x00000000ddffefff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000ddfff000-0x00000000ddffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.31 by American Megatrends
[    0.000000] efi:  ACPI=0xdd8f2000  ACPI 2.0=0xdd8f2000  SMBIOS=0xf04c0  MPS=0xfd4d0
[    0.000000] random: fast init done
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./H81M-VG4 R2.0, BIOS C1.40 08/13/2015
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x41f000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-D3FFF write-protect
[    0.000000]   D4000-DFFFF uncachable
[    0.000000]   E0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask 7C00000000 write-back
[    0.000000]   1 base 0400000000 mask 7FF0000000 write-back
[    0.000000]   2 base 0410000000 mask 7FF8000000 write-back
[    0.000000]   3 base 0418000000 mask 7FFC000000 write-back
[    0.000000]   4 base 041C000000 mask 7FFE000000 write-back
[    0.000000]   5 base 041E000000 mask 7FFF000000 write-back
[    0.000000]   6 base 00E0000000 mask 7FE0000000 uncachable
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0xde000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fd780-0x000fd78f] mapped at [ffffffffff240780]
[    0.000000] Base memory trampoline at [ffff9d2b80098000] 98000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x14c005000, 0x14c005fff] PGTABLE
[    0.000000] BRK [0x14c006000, 0x14c006fff] PGTABLE
[    0.000000] BRK [0x14c007000, 0x14c007fff] PGTABLE
[    0.000000] BRK [0x14c008000, 0x14c008fff] PGTABLE
[    0.000000] BRK [0x14c009000, 0x14c009fff] PGTABLE
[    0.000000] BRK [0x14c00a000, 0x14c00afff] PGTABLE
[    0.000000] BRK [0x14c00b000, 0x14c00bfff] PGTABLE
[    0.000000] BRK [0x14c00c000, 0x14c00cfff] PGTABLE
[    0.000000] BRK [0x14c00d000, 0x14c00dfff] PGTABLE
[    0.000000] BRK [0x14c00e000, 0x14c00efff] PGTABLE
[    0.000000] BRK [0x14c00f000, 0x14c00ffff] PGTABLE
[    0.000000] BRK [0x14c010000, 0x14c010fff] PGTABLE
[    0.000000] Secure boot could not be determined
[    0.000000] RAMDISK: [mem 0x352e7000-0x3696afff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000DD8F2000 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000DD8F2080 000084 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000DD8FC7D0 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000DD8F21A0 00A62F (v02 ALASKA A M I    00000140 INTL 20091112)
[    0.000000] ACPI: FACS 0x00000000DD914080 000040
[    0.000000] ACPI: APIC 0x00000000DD8FC8E0 000072 (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x00000000DD8FC958 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DD8FC9A0 000539 (v01 PmRef  Cpu0Ist  00003000 INTL 20051117)
[    0.000000] ACPI: SSDT 0x00000000DD8FCEE0 000AD8 (v01 PmRef  CpuPm    00003000 INTL 20051117)
[    0.000000] ACPI: SSDT 0x00000000DD8FD9B8 0001C7 (v01 PmRef  LakeTiny 00003000 INTL 20051117)
[    0.000000] ACPI: MCFG 0x00000000DD8FDB80 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0x00000000DD8FDBC0 000038 (v01 ALASKA A M I    01072009 AMI. 00000005)
[    0.000000] ACPI: SSDT 0x00000000DD8FDBF8 000495 (v01 IdeRef IdeTable 00001000 INTL 20091112)
[    0.000000] ACPI: SSDT 0x00000000DD8FE090 003493 (v01 SaSsdt SaSsdt   00003000 INTL 20091112)
[    0.000000] ACPI: AAFT 0x00000000DD901528 000208 (v01 ALASKA OEMAAFT  01072009 MSFT 00000097)
[    0.000000] ACPI: BGRT 0x00000000DD901730 000038 (v00 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000041effffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x41effb000-0x41effffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000041effffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.000000]   node   0: [mem 0x0000000000059000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000ca360fff]
[    0.000000]   node   0: [mem 0x00000000ca368000-0x00000000caab3fff]
[    0.000000]   node   0: [mem 0x00000000caceb000-0x00000000dd619fff]
[    0.000000]   node   0: [mem 0x00000000dd81d000-0x00000000dd86dfff]
[    0.000000]   node   0: [mem 0x00000000ddfff000-0x00000000ddffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000041effffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
[    0.000000] On node 0 totalpages: 4178891
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 24 pages reserved
[    0.000000]   DMA zone: 3997 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 14097 pages used for memmap
[    0.000000]   DMA32 zone: 902190 pages, LIFO batch:31
[    0.000000]   Normal zone: 51136 pages used for memmap
[    0.000000]   Normal zone: 3272704 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x1808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xca361000-0xca367fff]
[    0.000000] PM: Registered nosave memory: [mem 0xcaab4000-0xcaceafff]
[    0.000000] PM: Registered nosave memory: [mem 0xdd61a000-0xdd81cfff]
[    0.000000] PM: Registered nosave memory: [mem 0xdd86e000-0xdd915fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdd916000-0xddf7ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xddf80000-0xddffefff]
[    0.000000] PM: Registered nosave memory: [mem 0xde000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0xde000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 44 pages/cpu @ffff9d2f9ec00000 s142232 r8192 d29800 u524288
[    0.000000] pcpu-alloc: s142232 r8192 d29800 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4113570
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.14.0-3-amd64 root=UUID=67dd4135-b99d-426f-8a19-a61b8b663143 ro quiet nouveau.modeset=0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 16143068K/16715564K available (10252K kernel code, 1146K rwdata, 3040K rodata, 1508K init, 664K bss, 572496K reserved, 0K cma-reserved)
[    0.000000] Kernel/User page tables isolation: enabled
[    0.000000] ftrace: allocating 29024 entries in 114 pages
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 33024, nr_irqs: 456, preallocated irqs: 16
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.004000] tsc: Detected 3199.215 MHz processor
[    0.004000] Calibrating delay loop (skipped), value calculated using timer frequency.. 6398.43 BogoMIPS (lpj=12796860)
[    0.004000] pid_max: default: 32768 minimum: 301
[    0.004000] ACPI: Core revision 20170728
[    0.011502] ACPI: 6 ACPI AML tables successfully acquired and loaded
[    0.011937] Security Framework initialized
[    0.011938] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.011949] AppArmor: AppArmor initialized
[    0.013930] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.014902] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.014942] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.014976] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.015124] CPU: Physical Processor ID: 0
[    0.015124] CPU: Processor Core ID: 0
[    0.015130] mce: CPU supports 9 MCE banks
[    0.015137] CPU0: Thermal monitoring enabled (TM1)
[    0.015148] process: using mwait in idle threads
[    0.015150] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[    0.015150] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[    0.015325] Freeing SMP alternatives memory: 28K
[    0.023015] smpboot: Max logical packages: 1
[    0.023081] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.023496] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.063189] TSC deadline timer enabled
[    0.063190] smpboot: CPU0: Intel(R) Core(TM) i5-4460  CPU @ 3.20GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[    0.063234] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.063264] ... version:                3
[    0.063264] ... bit width:              48
[    0.063265] ... generic registers:      8
[    0.063265] ... value mask:             0000ffffffffffff
[    0.063266] ... max period:             00007fffffffffff
[    0.063266] ... fixed-purpose events:   3
[    0.063266] ... event mask:             00000007000000ff
[    0.063289] Hierarchical SRCU implementation.
[    0.063786] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.063796] smp: Bringing up secondary CPUs ...
[    0.063848] x86: Booting SMP configuration:
[    0.063848] .... node  #0, CPUs:      #1 #2 #3
[    0.064546] smp: Brought up 1 node, 4 CPUs
[    0.064546] smpboot: Total of 4 processors activated (25593.72 BogoMIPS)
[    0.066403] devtmpfs: initialized
[    0.066403] x86/mm: Memory block size: 128MB
[    0.068274] PM: Registering ACPI NVS region [mem 0xca361000-0xca367fff] (28672 bytes)
[    0.068274] PM: Registering ACPI NVS region [mem 0xdd86e000-0xdd915fff] (688128 bytes)
[    0.068274] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.068274] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.068274] pinctrl core: initialized pinctrl subsystem
[    0.068274] NET: Registered protocol family 16
[    0.068274] cpuidle: using governor ladder
[    0.068274] cpuidle: using governor menu
[    0.068274] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.068274] ACPI: bus type PCI registered
[    0.068274] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.068274] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.068274] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.068274] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.068274] PCI: Using configuration type 1 for base access
[    0.068274] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.068621] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.068621] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.068621] ACPI: Added _OSI(Module Device)
[    0.068621] ACPI: Added _OSI(Processor Device)
[    0.068621] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.068621] ACPI: Added _OSI(Processor Aggregator Device)
[    0.068621] ACPI: Executed 1 blocks of module-level executable AML code
[    0.069568] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.072079] ACPI: Dynamic OEM Table Load:
[    0.072083] ACPI: SSDT 0xFFFF9D2F8C026000 0003D3 (v01 PmRef  Cpu0Cst  00003001 INTL 20051117)
[    0.072185] ACPI: Dynamic OEM Table Load:
[    0.072189] ACPI: SSDT 0xFFFF9D2F8C15E000 0005AA (v01 PmRef  ApIst    00003000 INTL 20051117)
[    0.072395] ACPI: Dynamic OEM Table Load:
[    0.072395] ACPI: SSDT 0xFFFF9D2F8C1F6800 000119 (v01 PmRef  ApCst    00003000 INTL 20051117)
[    0.072589] ACPI: Interpreter enabled
[    0.072609] ACPI: (supports S0 S3 S4 S5)
[    0.072610] ACPI: Using IOAPIC for interrupt routing
[    0.072651] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.072830] ACPI: Enabled 8 GPEs in block 00 to 3F
[    0.077719] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.077722] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.077876] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[    0.077975] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[    0.077975] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.078284] PCI host bridge to bus 0000:00
[    0.078286] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.078287] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.078288] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.078288] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.078289] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.078290] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.078290] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[    0.078291] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.078296] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.078363] pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
[    0.078389] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.078460] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[    0.078477] pci 0000:00:14.0: reg 0x10: [mem 0xf0200000-0xf020ffff 64bit]
[    0.078526] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.078578] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[    0.078595] pci 0000:00:16.0: reg 0x10: [mem 0xf0219000-0xf021900f 64bit]
[    0.078647] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.078706] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[    0.078723] pci 0000:00:1a.0: reg 0x10: [mem 0xf0217000-0xf02173ff]
[    0.078793] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.078847] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[    0.078861] pci 0000:00:1b.0: reg 0x10: [mem 0xf0210000-0xf0213fff 64bit]
[    0.078910] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.078966] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[    0.079023] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.079107] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[    0.079164] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.079247] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[    0.079265] pci 0000:00:1d.0: reg 0x10: [mem 0xf0216000-0xf02163ff]
[    0.079335] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.079390] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[    0.079527] pci 0000:00:1f.2: [8086:8c00] type 00 class 0x01018f
[    0.079539] pci 0000:00:1f.2: reg 0x10: [io  0xf070-0xf077]
[    0.079544] pci 0000:00:1f.2: reg 0x14: [io  0xf060-0xf063]
[    0.079549] pci 0000:00:1f.2: reg 0x18: [io  0xf050-0xf057]
[    0.079555] pci 0000:00:1f.2: reg 0x1c: [io  0xf040-0xf043]
[    0.079560] pci 0000:00:1f.2: reg 0x20: [io  0xf030-0xf03f]
[    0.079565] pci 0000:00:1f.2: reg 0x24: [io  0xf020-0xf02f]
[    0.079629] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[    0.079643] pci 0000:00:1f.3: reg 0x10: [mem 0xf0215000-0xf02150ff 64bit]
[    0.079659] pci 0000:00:1f.3: reg 0x20: [io  0xf000-0xf01f]
[    0.079747] pci 0000:01:00.0: [1002:683f] type 00 class 0x030000
[    0.079760] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.079767] pci 0000:01:00.0: reg 0x18: [mem 0xf0000000-0xf003ffff 64bit]
[    0.079771] pci 0000:01:00.0: reg 0x20: [io  0xe000-0xe0ff]
[    0.079779] pci 0000:01:00.0: reg 0x30: [mem 0xf0040000-0xf005ffff pref]
[    0.079787] pci 0000:01:00.0: BAR 0: assigned to efifb
[    0.079810] pci 0000:01:00.0: supports D1 D2
[    0.079811] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
[    0.079846] pci 0000:01:00.1: [1002:aab0] type 00 class 0x040300
[    0.079858] pci 0000:01:00.1: reg 0x10: [mem 0xf0060000-0xf0063fff 64bit]
[    0.079903] pci 0000:01:00.1: supports D1 D2
[    0.092021] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.092022] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.092023] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xf00fffff]
[    0.092054] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.092100] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[    0.092127] pci 0000:03:00.0: reg 0x10: [io  0xd000-0xd0ff]
[    0.092152] pci 0000:03:00.0: reg 0x18: [mem 0xf0104000-0xf0104fff 64bit]
[    0.092167] pci 0000:03:00.0: reg 0x20: [mem 0xf0100000-0xf0103fff 64bit pref]
[    0.092254] pci 0000:03:00.0: supports D1 D2
[    0.092254] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.104030] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.104032] pci 0000:00:1c.3:   bridge window [io  0xd000-0xdfff]
[    0.104035] pci 0000:00:1c.3:   bridge window [mem 0xf0100000-0xf01fffff]
[    0.104527] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.104561] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.104593] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.104626] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.104657] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.104690] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.104722] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.104754] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 10 11 12 14 15)
[    0.104935] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.104935] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.104935] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.104935] vgaarb: loaded
[    0.104935] EDAC MC: Ver: 3.0.0
[    0.108009] Registered efivars operations
[    0.112009] PCI: Using ACPI for IRQ routing
[    0.113230] PCI: pci_cache_line_size set to 64 bytes
[    0.113259] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.113259] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.113260] e820: reserve RAM buffer [mem 0xca361000-0xcbffffff]
[    0.113261] e820: reserve RAM buffer [mem 0xcaab4000-0xcbffffff]
[    0.113261] e820: reserve RAM buffer [mem 0xdd61a000-0xdfffffff]
[    0.113262] e820: reserve RAM buffer [mem 0xdd86e000-0xdfffffff]
[    0.113263] e820: reserve RAM buffer [mem 0xde000000-0xdfffffff]
[    0.113263] e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
[    0.113331] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.113331] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.117012] clocksource: Switched to clocksource hpet
[    0.122295] VFS: Disk quotas dquot_6.6.0
[    0.122308] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.122373] AppArmor: AppArmor Filesystem Enabled
[    0.122382] pnp: PnP ACPI init
[    0.122441] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.122444] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.122551] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.122552] system 00:01: [io  0xffff] has been reserved
[    0.122553] system 00:01: [io  0xffff] has been reserved
[    0.122554] system 00:01: [io  0xffff] has been reserved
[    0.122555] system 00:01: [io  0x1c00-0x1cfe] has been reserved
[    0.122556] system 00:01: [io  0x1d00-0x1dfe] has been reserved
[    0.122557] system 00:01: [io  0x1e00-0x1efe] has been reserved
[    0.122558] system 00:01: [io  0x1f00-0x1ffe] has been reserved
[    0.122559] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.122560] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.122562] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.122577] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.122607] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.122609] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.122657] system 00:04: [io  0x0290-0x029f] has been reserved
[    0.122659] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.122740] system 00:05: [io  0x04d0-0x04d1] has been reserved
[    0.122742] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123035] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.123036] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.123038] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.123039] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.123040] system 00:06: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.123041] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.123041] system 00:06: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.123042] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.123043] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.123044] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.123045] system 00:06: [mem 0xf7fef000-0xf7feffff] has been reserved
[    0.123046] system 00:06: [mem 0xf7ff0000-0xf7ff0fff] has been reserved
[    0.123048] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.123220] pnp: PnP ACPI: found 7 devices
[    0.128832] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.128843] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 02] add_size 1000
[    0.128845] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.128846] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[    0.128855] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf0300000-0xf04fffff]
[    0.128858] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf0500000-0xf06fffff 64bit pref]
[    0.128860] pci 0000:00:1c.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.128862] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.128863] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.128864] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xf00fffff]
[    0.128867] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.128869] pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
[    0.128872] pci 0000:00:1c.0:   bridge window [mem 0xf0300000-0xf04fffff]
[    0.128874] pci 0000:00:1c.0:   bridge window [mem 0xf0500000-0xf06fffff 64bit pref]
[    0.128878] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.128880] pci 0000:00:1c.3:   bridge window [io  0xd000-0xdfff]
[    0.128883] pci 0000:00:1c.3:   bridge window [mem 0xf0100000-0xf01fffff]
[    0.128889] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.128890] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.128891] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.128891] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff window]
[    0.128892] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff window]
[    0.128893] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff window]
[    0.128893] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfeafffff window]
[    0.128894] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.128895] pci_bus 0000:01: resource 1 [mem 0xe0000000-0xf00fffff]
[    0.128896] pci_bus 0000:02: resource 0 [io  0x2000-0x2fff]
[    0.128896] pci_bus 0000:02: resource 1 [mem 0xf0300000-0xf04fffff]
[    0.128897] pci_bus 0000:02: resource 2 [mem 0xf0500000-0xf06fffff 64bit pref]
[    0.128898] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[    0.128898] pci_bus 0000:03: resource 1 [mem 0xf0100000-0xf01fffff]
[    0.128973] NET: Registered protocol family 2
[    0.129077] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.129199] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.129296] TCP: Hash tables configured (established 131072 bind 65536)
[    0.129318] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    0.129349] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    0.129407] NET: Registered protocol family 1
[    0.176080] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.176085] PCI: CLS 64 bytes, default 64
[    0.176111] Unpacking initramfs...
[    0.467138] Freeing initrd memory: 23056K
[    0.467141] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.467143] software IO TLB [mem 0xcccd9000-0xd0cd9000] (64MB) mapped at [ffff9d2c4ccd9000-ffff9d2c50cd8fff]
[    0.467382] audit: initializing netlink subsys (disabled)
[    0.467420] audit: type=2000 audit(1517834252.464:1): state=initialized audit_enabled=0 res=1
[    0.467646] workingset: timestamp_bits=40 max_order=22 bucket_order=0
[    0.467676] zbud: loaded
[    0.694650] Key type asymmetric registered
[    0.694651] Asymmetric key parser 'x509' registered
[    0.694661] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.694680] io scheduler noop registered
[    0.694680] io scheduler deadline registered
[    0.694689] io scheduler cfq registered (default)
[    0.694690] io scheduler mq-deadline registered
[    0.695042] efifb: probing for efifb
[    0.695052] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[    0.695053] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    0.695053] efifb: scrolling: redraw
[    0.695054] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.696403] Console: switching to colour frame buffer device 128x48
[    0.697667] fb0: EFI VGA frame buffer device
[    0.697673] intel_idle: MWAIT substates: 0x42120
[    0.697673] intel_idle: v0.4.1 model 0x3C
[    0.697775] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.697931] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.698184] Linux agpgart interface v0.103
[    0.698215] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.698215] AMD IOMMUv2 functionality not available on this system
[    0.698403] i8042: PNP: No PS/2 controller found.
[    0.698441] mousedev: PS/2 mouse device common for all mice
[    0.698461] rtc_cmos 00:02: RTC can wake from S4
[    0.698560] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    0.698583] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.698589] intel_pstate: Intel P-state driver initializing
[    0.698726] ledtrig-cpu: registered to indicate activity on CPUs
[    0.699230] NET: Registered protocol family 10
[    0.699662] Segment Routing with IPv6
[    0.699695] mip6: Mobile IPv6
[    0.699699] NET: Registered protocol family 17
[    0.699703] mpls_gso: MPLS GSO support
[    0.700418] microcode: sig=0x306c3, pf=0x2, revision=0x22
[    0.700601] microcode: Microcode Update Driver: v2.2.
[    0.700624] sched_clock: Marking stable (700587886, 0)->(707398353, -6810467)
[    0.701279] registered taskstats version 1
[    0.701310] zswap: loaded using pool lzo/zbud
[    0.701476] AppArmor: AppArmor sha1 policy hashing enabled
[    0.701481] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[    0.702099] rtc_cmos 00:02: setting system clock to 2018-02-05 12:37:33 UTC (1517834253)
[    0.706106] Freeing unused kernel memory: 1508K
[    0.706108] Write protecting the kernel read-only data: 16384k
[    0.707325] Freeing unused kernel memory: 2012K
[    0.712490] Freeing unused kernel memory: 1056K
[    0.716237] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.716237] x86/mm: Checking user space page tables
[    0.719839] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.751809] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[    0.751824] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    0.752424] ACPI: bus type USB registered
[    0.752440] usbcore: registered new interface driver usbfs
[    0.752448] usbcore: registered new interface driver hub
[    0.752845] usbcore: registered new device driver usb
[    0.753302] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.753749] ehci-pci: EHCI PCI platform driver
[    0.753847] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.753850] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.753859] ehci-pci 0000:00:1a.0: debug port 2
[    0.754283] SCSI subsystem initialized
[    0.755905] libata version 3.00 loaded.
[    0.756175] AVX2 version of gcm_enc/dec engaged.
[    0.756175] AES CTR mode by8 optimization enabled
[    0.757768] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    0.758021] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf0217000
[    0.776006] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.776167] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.776168] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.776169] usb usb1: Product: EHCI Host Controller
[    0.776169] usb usb1: Manufacturer: Linux 4.14.0-3-amd64 ehci_hcd
[    0.776178] usb usb1: SerialNumber: 0000:00:1a.0
[    0.776333] hub 1-0:1.0: USB hub found
[    0.776362] hub 1-0:1.0: 2 ports detected
[    0.776747] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.776750] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    0.776758] ehci-pci 0000:00:1d.0: debug port 2
[    0.780653] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    0.780771] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf0216000
[    0.800069] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.800111] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.800113] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.800114] usb usb2: Product: EHCI Host Controller
[    0.800115] usb usb2: Manufacturer: Linux 4.14.0-3-amd64 ehci_hcd
[    0.800117] usb usb2: SerialNumber: 0000:00:1d.0
[    0.800339] hub 2-0:1.0: USB hub found
[    0.800345] hub 2-0:1.0: 2 ports detected
[    0.800537] ata_piix 0000:00:1f.2: version 2.13
[    0.800650] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    0.960702] scsi host0: ata_piix
[    0.961130] scsi host1: ata_piix
[    0.961227] ata1: SATA max UDMA/133 cmd 0xf070 ctl 0xf060 bmdma 0xf030 irq 19
[    0.961232] ata2: SATA max UDMA/133 cmd 0xf050 ctl 0xf040 bmdma 0xf038 irq 19
[    0.961502] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.961512] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    0.962612] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[    0.962618] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.963002] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    0.963006] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.963008] usb usb3: Product: xHCI Host Controller
[    0.963010] usb usb3: Manufacturer: Linux 4.14.0-3-amd64 xhci-hcd
[    0.963012] usb usb3: SerialNumber: 0000:00:14.0
[    0.963270] hub 3-0:1.0: USB hub found
[    0.963324] hub 3-0:1.0: 10 ports detected
[    0.964624] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.964630] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    0.964690] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    0.964692] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.964694] usb usb4: Product: xHCI Host Controller
[    0.964696] usb usb4: Manufacturer: Linux 4.14.0-3-amd64 xhci-hcd
[    0.964698] usb usb4: SerialNumber: 0000:00:14.0
[    0.965034] hub 4-0:1.0: USB hub found
[    0.965047] hub 4-0:1.0: 2 ports detected
[    1.112053] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.136050] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    1.268767] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[    1.268771] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.269290] hub 1-1:1.0: USB hub found
[    1.269418] hub 1-1:1.0: 4 ports detected
[    1.292772] usb 2-1: New USB device found, idVendor=8087, idProduct=8000
[    1.292776] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.293145] hub 2-1:1.0: USB hub found
[    1.293329] hub 2-1:1.0: 6 ports detected
[    1.300052] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[    1.468032] tsc: Refined TSC clocksource calibration: 3199.071 MHz
[    1.468044] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2e1cdc1a1cd, max_idle_ns: 440795258279 ns
[    1.665612] usb 3-1: New USB device found, idVendor=046d, idProduct=0825
[    1.665617] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[    1.665620] usb 3-1: SerialNumber: 27802EE0
[    1.792037] usb 3-3: new low-speed USB device number 3 using xhci_hcd
[    1.945623] usb 3-3: New USB device found, idVendor=0665, idProduct=5161
[    1.945628] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.945631] usb 3-3: Product: USB to Serial
[    1.945633] usb 3-3: Manufacturer: INNO TECH
[    1.952390] hidraw: raw HID events driver (C) Jiri Kosina
[    1.955921] usbcore: registered new interface driver usbhid
[    1.955923] usbhid: USB HID core driver
[    1.957387] hid-generic 0003:0665:5161.0001: hiddev0,hidraw0: USB HID v1.00 Device [INNO TECH USB to Serial] on usb-0000:00:14.0-3/input0
[    2.076019] usb 3-5: new high-speed USB device number 4 using xhci_hcd
[    2.227180] usb 3-5: New USB device found, idVendor=2101, idProduct=8500
[    2.227184] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.227186] usb 3-5: Product: USB2.0 Hub
[    2.227188] usb 3-5: Manufacturer: Action Star
[    2.228031] hub 3-5:1.0: USB hub found
[    2.228487] hub 3-5:1.0: 5 ports detected
[    2.316037] ata1.01: failed to resume link (SControl 0)
[    2.316118] ata2.01: failed to resume link (SControl 0)
[    2.476103] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.476118] ata2.01: SATA link down (SStatus 0 SControl 0)
[    2.476287] ata1.00: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.476301] ata1.01: SATA link down (SStatus 0 SControl 0)
[    2.479011] ata1.00: ATA-8: TOSHIBA DT01ACA100, MS2OA750, max UDMA/133
[    2.479015] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    2.484024] ata1.00: configured for UDMA/133
[    2.484399] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA DT01ACA1 A750 PQ: 0 ANSI: 5
[    2.492256] clocksource: Switched to clocksource tsc
[    2.496410] ata2.00: ATA-8: SAMSUNG HD501LJ, CR100-10, max UDMA7
[    2.496414] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    2.499204] ata2.00: configured for UDMA/133
[    2.499536] scsi 1:0:0:0: Direct-Access     ATA      SAMSUNG HD501LJ  0-10 PQ: 0 ANSI: 5
[    2.503816] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    2.503820] sd 1:0:0:0: [sdb] Write Protect is off
[    2.503821] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.503827] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.503885] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.503886] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    2.503896] sd 0:0:0:0: [sda] Write Protect is off
[    2.503897] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.503908] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.520002] usb 3-5.1: new high-speed USB device number 5 using xhci_hcd
[    2.530569]  sda: sda1 sda2
[    2.531139] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.552643]  sdb: sdb1 sdb2 sdb3 sdb4 sdb5 sdb6 sdb7 sdb8
[    2.553001] sd 1:0:0:0: [sdb] Attached SCSI disk
[    2.623333] usb 3-5.1: New USB device found, idVendor=2101, idProduct=8501
[    2.623345] usb 3-5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.623346] usb 3-5.1: Product: USB HID
[    2.623347] usb 3-5.1: Manufacturer: Action Star
[    2.625395] hid-generic 0003:2101:8501.0002: hiddev1,hidraw1: USB HID v1.11 Device [Action Star USB HID] on usb-0000:00:14.0-5.1/input0
[    2.704002] usb 3-5.3: new low-speed USB device number 6 using xhci_hcd
[    2.807627] usb 3-5.3: New USB device found, idVendor=15d9, idProduct=0a4e
[    2.807628] usb 3-5.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.807629] usb 3-5.3: Product:  USB OPTICAL MOUSE
[    2.810254] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.3/3-5.3:1.0/0003:15D9:0A4E.0003/input/input0
[    2.810423] hid-generic 0003:15D9:0A4E.0003: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:14.0-5.3/input0
[    2.887992] usb 3-5.4: new low-speed USB device number 7 using xhci_hcd
[    2.993241] usb 3-5.4: New USB device found, idVendor=1a2c, idProduct=0b2a
[    2.993253] usb 3-5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.993254] usb 3-5.4: Product: USB Keyboard
[    2.993255] usb 3-5.4: Manufacturer: SEM
[    2.996040] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.4/3-5.4:1.0/0003:1A2C:0B2A.0004/input/input1
[    3.056111] hid-generic 0003:1A2C:0B2A.0004: input,hidraw3: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:00:14.0-5.4/input0
[    3.058120] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5.4/3-5.4:1.1/0003:1A2C:0B2A.0005/input/input2
[    3.116105] hid-generic 0003:1A2C:0B2A.0005: input,hidraw4: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:00:14.0-5.4/input1
[    3.234120] PM: Starting manual resume from disk
[    3.234299] PM: Image not found (code -22)
[    3.460226] EXT4-fs (sdb6): mounted filesystem with ordered data mode. Opts: (null)
[    4.609501] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.789885] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    4.808100] systemd[1]: Detected architecture x86-64.
[    4.825200] systemd[1]: Set hostname to <nux>.
[    4.997321] random: crng init done
[    7.531829] systemd[1]: NetworkManager-wait-online.service: Cannot add dependency job, ignoring: Unit NetworkManager-wait-online.service is masked.
[    7.531925] systemd[1]: NetworkManager.service: Cannot add dependency job, ignoring: Unit NetworkManager.service is masked.
[    7.533856] systemd[1]: Created slice User and Session Slice.
[    7.534067] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.534202] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.534530] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.534618] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.775790] EXT4-fs (sdb6): re-mounted. Opts: errors=remount-ro
[    8.054761] systemd-journald[242]: Received request to flush runtime journal from PID 1
[    8.105041] lp: driver loaded but no devices found
[    8.448553] ppdev: user-space parallel port driver
[    8.937604] [drm] radeon kernel modesetting enabled.
[    9.461886] CRAT table not found
[    9.461888] Finished initializing topology ret=0
[    9.461912] kfd kfd: Initialized module
[    9.469749] checking generic (e0000000 300000) vs hw (e0000000 10000000)
[    9.469752] fb: switching to radeondrmfb from EFI VGA
[    9.469786] Console: switching to colour dummy device 80x25
[    9.470689] [drm] initializing kernel modesetting (VERDE 0x1002:0x683F 0x174B:0xA001 0x00).
[    9.470752] resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000d4000-0x000d7fff window]
[    9.470760] caller pci_map_rom+0x58/0xd0 mapping multiple BARs
[    9.470882] ATOM BIOS: C90601
[    9.471064] radeon 0000:01:00.0: VRAM: 4096M 0x0000000000000000 - 0x00000000FFFFFFFF (4096M used)
[    9.471068] radeon 0000:01:00.0: GTT: 2048M 0x0000000100000000 - 0x000000017FFFFFFF
[    9.471076] [drm] Detected VRAM RAM=4096M, BAR=256M
[    9.471077] [drm] RAM width 128bits DDR
[    9.471245] [TTM] Zone  kernel: Available graphics memory: 8183118 kiB
[    9.471246] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
[    9.471248] [TTM] Initializing pool allocator
[    9.471255] [TTM] Initializing DMA pool allocator
[    9.471289] [drm] radeon: 4096M of VRAM memory ready
[    9.471291] [drm] radeon: 2048M of GTT memory ready.
[    9.471307] [drm] Loading verde Microcode
[    9.514530] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/verde_pfp.bin
[    9.539697] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/verde_me.bin
[    9.544967] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/verde_ce.bin
[    9.556831] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/verde_rlc.bin
[    9.557638] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/verde_mc.bin
[    9.558444] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/verde_smc.bin
[    9.558453] [drm] Internal thermal controller with fan control
[    9.558571] [drm] probing gen 2 caps for device 8086:c01 = 261ad02/6
[    9.568754] [drm] radeon: dpm initialized
[    9.578800] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/TAHITI_uvd.bin
[    9.596111] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/TAHITI_vce.bin
[    9.597610] [drm] Found VCE firmware/feedback version 50.0.1 / 17!
[    9.597622] [drm] GART: num cpu pages 524288, num gpu pages 524288
[    9.598404] [drm] probing gen 2 caps for device 8086:c01 = 261ad02/6
[    9.598407] [drm] PCIE gen 2 link speeds already enabled
[    9.620270] [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
[    9.620374] radeon 0000:01:00.0: WB enabled
[    9.620376] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000100000c00 and cpu addr 0xffff9d2f8bae6c00
[    9.620377] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000100000c04 and cpu addr 0xffff9d2f8bae6c04
[    9.620378] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000100000c08 and cpu addr 0xffff9d2f8bae6c08
[    9.620379] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000100000c0c and cpu addr 0xffff9d2f8bae6c0c
[    9.620379] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000100000c10 and cpu addr 0xffff9d2f8bae6c10
[    9.620777] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18 and cpu addr 0xffffb760c2435a18
[    9.640810] radeon 0000:01:00.0: fence driver on ring 6 use gpu addr 0x0000000100000c18 and cpu addr 0xffff9d2f8bae6c18
[    9.640811] radeon 0000:01:00.0: fence driver on ring 7 use gpu addr 0x0000000100000c1c and cpu addr 0xffff9d2f8bae6c1c
[    9.640812] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    9.640813] [drm] Driver supports precise vblank timestamp query.
[    9.640813] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[    9.640838] radeon 0000:01:00.0: radeon: using MSI.
[    9.640857] [drm] radeon: irq initialized.
[    9.665714] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[    9.665721] ACPI: Power Button [PWRB]
[    9.665750] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[    9.665757] ACPI: Power Button [PWRF]
[    9.679639] EFI Variables Facility v0.08 2004-May-17
[    9.734236] input: PC Speaker as /devices/platform/pcspkr/input/input5
[    9.750086] pstore: using zlib compression
[    9.753442] pstore: Registered efi as persistent store backend
[   10.104344] [drm] ring test on 0 succeeded in 1 usecs
[   10.104348] [drm] ring test on 1 succeeded in 1 usecs
[   10.104351] [drm] ring test on 2 succeeded in 1 usecs
[   10.104373] [drm] ring test on 3 succeeded in 9 usecs
[   10.104388] [drm] ring test on 4 succeeded in 13 usecs
[   10.166966] usb 3-3: USB disconnect, device number 3
[   10.280081] [drm] ring test on 5 succeeded in 2 usecs
[   10.280085] [drm] UVD initialized successfully.
[   10.389313] [drm] ring test on 6 succeeded in 21 usecs
[   10.389325] [drm] ring test on 7 succeeded in 4 usecs
[   10.389326] [drm] VCE initialized successfully.
[   10.389497] [drm] ib test on ring 0 succeeded in 0 usecs
[   10.389533] [drm] ib test on ring 1 succeeded in 0 usecs
[   10.389568] [drm] ib test on ring 2 succeeded in 0 usecs
[   10.389602] [drm] ib test on ring 3 succeeded in 0 usecs
[   10.389636] [drm] ib test on ring 4 succeeded in 0 usecs
[   10.394522] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[   10.394523] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   10.394523] RAPL PMU: hw unit of domain package 2^-14 Joules
[   10.394524] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   10.394524] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   10.400711] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   10.401429] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   10.899823] media: Linux media interface: v0.10
[   10.929274] Linux video capture interface: v2.00
[   11.068019] [drm] ib test on ring 5 succeeded
[   11.564273] fuse init (API version 7.26)
[   11.580016] [drm] ib test on ring 6 succeeded
[   11.663704] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   11.775990] usb 3-3: new low-speed USB device number 8 using xhci_hcd
[   11.929208] usb 3-3: New USB device found, idVendor=0665, idProduct=5161
[   11.929209] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   11.929210] usb 3-3: Product: USB to Serial
[   11.929211] usb 3-3: Manufacturer: INNO TECH
[   11.933204] hid-generic 0003:0665:5161.0006: hiddev0,hidraw0: USB HID v1.00 Device [INNO TECH USB to Serial] on usb-0000:00:14.0-3/input0
[   12.092082] [drm] ib test on ring 7 succeeded
[   12.092322] [drm] Radeon Display Connectors
[   12.092323] [drm] Connector 0:
[   12.092323] [drm]   HDMI-A-1
[   12.092323] [drm]   HPD1
[   12.092324] [drm]   DDC: 0x6540 0x6540 0x6544 0x6544 0x6548 0x6548 0x654c 0x654c
[   12.092324] [drm]   Encoders:
[   12.092325] [drm]     DFP1: INTERNAL_UNIPHY
[   12.092325] [drm] Connector 1:
[   12.092325] [drm]   DVI-D-1
[   12.092325] [drm]   HPD2
[   12.092326] [drm]   DDC: 0x6530 0x6530 0x6534 0x6534 0x6538 0x6538 0x653c 0x653c
[   12.092326] [drm]   Encoders:
[   12.092327] [drm]     DFP2: INTERNAL_UNIPHY
[   12.092327] [drm] Connector 2:
[   12.092327] [drm]   VGA-1
[   12.092328] [drm]   DDC: 0x65c0 0x65c0 0x65c4 0x65c4 0x65c8 0x65c8 0x65cc 0x65cc
[   12.092328] [drm]   Encoders:
[   12.092328] [drm]     CRT1: INTERNAL_KLDSCP_DAC1
[   12.189397] [drm] fb mappable at 0xE05D9000
[   12.189398] [drm] vram apper at 0xE0000000
[   12.189398] [drm] size 8294400
[   12.189398] [drm] fb depth is 24
[   12.189399] [drm]    pitch is 7680
[   12.189507] fbcon: radeondrmfb (fb0) is primary device
[   12.240500] Console: switching to colour frame buffer device 200x56
[   12.242740] radeon 0000:01:00.0: fb0: radeondrmfb frame buffer device
[   12.260032] kfd kfd: DID 683f is missing in supported_devices
[   12.260033] kfd kfd: kgd2kfd_probe failed
[   12.260065] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
[   12.260124] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   12.263056] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20170728/utaddress-247)
[   12.263060] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   12.263062] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20170728/utaddress-247)
[   12.263064] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20170728/utaddress-247)
[   12.263066] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   12.263066] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20170728/utaddress-247)
[   12.263068] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20170728/utaddress-247)
[   12.263069] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20170728/utaddress-247)
[   12.263071] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   12.263071] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20170728/utaddress-247)
[   12.263073] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20170728/utaddress-247)
[   12.263075] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20170728/utaddress-247)
[   12.263076] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   12.263077] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   12.263239] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[   12.263376] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   12.263377] snd_hda_intel 0000:01:00.1: Force to non-snoop mode
[   12.316318] EXT4-fs (sdb7): mounted filesystem with ordered data mode. Opts: (null)
[   12.340011] usb 3-1: set resolution quirk: cval->res = 384
[   12.340102] usbcore: registered new interface driver snd-usb-audio
[   12.340111] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
[   12.354655] uvcvideo 3-1:1.0: Entity type for entity Extension 4 was not initialized!
[   12.354657] uvcvideo 3-1:1.0: Entity type for entity Extension 6 was not initialized!
[   12.354658] uvcvideo 3-1:1.0: Entity type for entity Extension 7 was not initialized!
[   12.354658] uvcvideo 3-1:1.0: Entity type for entity Processing 2 was not initialized!
[   12.354659] uvcvideo 3-1:1.0: Entity type for entity Extension 3 was not initialized!
[   12.354660] uvcvideo 3-1:1.0: Entity type for entity Camera 1 was not initialized!
[   12.354716] input: UVC Camera (046d:0825) as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/input/input6
[   12.354753] usbcore: registered new interface driver uvcvideo
[   12.354753] USB Video Class driver (1.1.1)
[   12.536117] Adding 16383996k swap on /dev/sdb5.  Priority:-2 extents:1 across:16383996k FS
[   12.551687] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input7
[   12.695273] iTCO_vendor_support: vendor-support=0
[   13.015333] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[   13.015334] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   13.015335] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   13.015336] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   13.015336] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   13.015337] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[   13.015338] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[   13.015339] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[   13.024141] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[   13.024181] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[   13.024210] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   13.028530] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   13.028561] iTCO_wdt: Found a Lynx Point TCO device (Version=2, TCOBASE=0x1860)
[   13.028623] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   13.201789] [drm] amdgpu kernel modesetting enabled.
[   14.175849] intel_rapl: Found RAPL domain package
[   14.175850] intel_rapl: Found RAPL domain core
[   14.175851] intel_rapl: Found RAPL domain dram
[   17.006702] audit: type=1400 audit(1517834269.798:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=527 comm="apparmor_parser"
[   17.007597] audit: type=1400 audit(1517834269.798:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=523 comm="apparmor_parser"
[   17.043411] audit: type=1400 audit(1517834269.834:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=531 comm="apparmor_parser"
[   17.071122] audit: type=1400 audit(1517834269.862:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/freshclam" pid=525 comm="apparmor_parser"
[   17.161341] audit: type=1400 audit(1517834269.954:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/clamd" pid=535 comm="apparmor_parser"
[   17.238918] audit: type=1400 audit(1517834270.030:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=537 comm="apparmor_parser"
[   17.410143] audit: type=1400 audit(1517834270.202:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/telepathy/mission-control-5" pid=533 comm="apparmor_parser"
[   17.410616] audit: type=1400 audit(1517834270.202:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/telepathy/telepathy-*" pid=533 comm="apparmor_parser"
[   17.410983] audit: type=1400 audit(1517834270.202:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/telepathy/telepathy-*//pxgsettings" pid=533 comm="apparmor_parser"
[   17.411165] audit: type=1400 audit(1517834270.202:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/telepathy/telepathy-*//sanitized_helper" pid=533 comm="apparmor_parser"
[   21.501750] usb 3-3: USB disconnect, device number 8
[   22.354521] vboxdrv: loading out-of-tree module taints kernel.
[   22.359653] vboxdrv: Found 4 processor cores
[   22.376246] vboxdrv: TSC mode is Invariant, tentative frequency 3199073441 Hz
[   22.376247] vboxdrv: Successfully loaded version 5.2.6 (interface 0x00290000)
[   22.813570] VBoxNetFlt: Successfully started.
[   22.847210] VBoxNetAdp: Successfully started.
[   22.874270] VBoxPciLinuxInit
[   22.902331] vboxpci: IOMMU not found (not registered)
[   23.108028] usb 3-3: new low-speed USB device number 9 using xhci_hcd
[   23.269214] usb 3-3: New USB device found, idVendor=0665, idProduct=5161
[   23.269215] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   23.269216] usb 3-3: Product: USB to Serial
[   23.269216] usb 3-3: Manufacturer: INNO TECH
[   23.273613] hid-generic 0003:0665:5161.0007: hiddev0,hidraw0: USB HID v1.00 Device [INNO TECH USB to Serial] on usb-0000:00:14.0-3/input0
[   26.537887] FS-Cache: Loaded
[   26.652490] Key type dns_resolver registered
[   26.787755] FS-Cache: Netfs 'cifs' registered for caching
[   26.787779] Key type cifs.spnego registered
[   26.787781] Key type cifs.idmap registered
[   26.787919] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
[   26.816404] CIFS VFS: Error connecting to socket. Aborting operation.
[   26.816405] CIFS VFS: cifs_mount failed w/return code = -101
Ceci, mais ça n'aide pas beaucoup...
Bon, j'ai trouvé... :icon_biggrin:
# apt remove --purge r8168-dkms
J'utilise donc maintenant le module r8169 "classique".
# lsmod | grep r8169
r8169                  90112  0
mii                    16384  1 r8169
je ne sais pas pourquoi le module r8168 n'a pas été créé par DKMS à l'installation du nouveau noyau.
Mystère et boule de gomme, je verrais ça plus tard.
comme quoi, avant de chercher une cause tordue, il faut revenir aux fondamentaux!
