Nginx ne demarre pas en boot
allan71
Bonjour ,
j'ai passer tout le weekend a comprendre pourquoi mon installation de Nginx ne démarre pas en boot ,
Voici mon installation:
Installation faite sur une VirtualBox VM (Oracle) Debian 8 Jessie.
wget http://nginx.org/download/nginx-1.13.1.tar.gz
wget https://github.com/arut/nginx-rtmp-module/archive/master.zip
tar -zxvf nginx-1.13.1.tar.gz
unzip master.zip
cd nginx-1.13.1
./configure --with-http_ssl_module --add-module=../nginx-rtmp-module-master
make
sudo make install
Installation spécialement pour avoir le module Rtmp , installer en "usr/bin/local/niginx
mon Bash de démarrage que j'ai modifier plusieurs fois sans succès:
#!/bin/bash
### BEGIN INIT INFO
# Provides:                             nginx
# Required-Start:               $all
# Require-Stop:                 $all
# Default-Start:                2 3 4 5
# Default-Stop:                 0 1 6
# Short-Description:    starts the nginx web server
# Description:                  starts nginx using start-stop-daemon
### END INIT INFO
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DAEMON=/usr/local/nginx/sbin/nginx
NAME=nginx
DESC=nginx
test -x $DAEMON || exit 0
# Include nginx defaults if available
if [ -f /etc/defaults/nginx ] ; then
        . /etc/defaults/nginx
fi
set -e
. /lib/lsb/init-functions
case "$1" in
        start)
                echo -n "Starting $DESC: "
                start-stop-daemon --start --quiet --pidfile /usr/local/nginx/logs/$NAME.pid --exec $DAEMON -- $DAEMON_OPTS || true
                echo "$NAME."
        stop)
                echo -n "Stopping $DESC: "
                start-stop-daemon --stop --quiet --pidfile /usr/local/nginx/logs/$NAME.pid --exec $DAEMON || true
                echo "$NAME."
        restart|force-reload)
                echo -n "Restarting $DESC: "
                sleep 1
                start-stop-daemon --start --quiet --pidfile /usr/local/nginxlogs/$NAME.pid --exec $DAEMON -- $DAEMON_OPTS || true
                echo "$NAME."
        reload)
                echo -n "Reloading $DESC configuration: "
                start-stop-daemon --stop --signal HUP --quiet --pidfile /usr/local/nginx/logs/$NAME.pid --exec $DAEMON || true
                echo "$NAME."
        status)
                status_of_proc -p /usr/local/nginx/logs/$NAME.pid "$DAEMON" nginx && exit 0 || exit $?
                N=/etc/init.d/$NAME
                echo "Usage: $N {start|stop|restart|reload|force-reload|status}" >&2
                exit 1
esac
exit 0
J'ai copier celui-ci dans init.d et usr/bin avec les droits 755 ,
entrer la commande:
update-rc.d nginx defaults
Mais elle a pas l'air de fonctionner , il y a aucun retour a la commande :icon_confused:
Sans la commande
sudo /usr/local/nginx/sbin/nginx
cela ne démarre pas :icon_sad:
Bonjour, sur un debian 8, tu devrais avoir systemd comme gestionnaire de service, alors que là, tu parles du vieux systemV.
De plus, pourquoi ne pas utiliser le paquet debian qui t'installe un script de démarrage tout seul ?
Je rejoins @piratebab ; c'est ce chercher les ennuis !
