probleme cle usb
taousert72
bonjour
je viens d'installer debian stretch sur mon pc et j'ai un souci avec ma cle usb de 2To
elle ne s'affiche pas sur le bureau mais elle est detectée sur le programme Disques dans la section accessoires mais impossible de la monter
et quand je tape dmesg voila le resultat
[ 6877.752721] usb-storage 8-5:1.0: USB Mass Storage device detected
[ 6877.752932] scsi host6: usb-storage 8-5:1.0
[ 6878.784860] scsi 6:0:0:0: Direct-Access     ChipsBnk Flash Disk       5.00 PQ: 0 ANSI: 2
[ 6878.785649] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 6878.787218] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 7302.065558] usb 8-5: USB disconnect, device number 11
[ 7305.984038] usb 8-5: new high-speed USB device number 12 using ehci-pci
[ 7306.132466] usb 8-5: New USB device found, idVendor=1e3d, idProduct=198a
[ 7306.132470] usb 8-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7306.132879] usb-storage 8-5:1.0: USB Mass Storage device detected
[ 7306.133001] scsi host6: usb-storage 8-5:1.0
[ 7307.136996] scsi 6:0:0:0: Direct-Access     ChipsBnk Flash Disk       5.00 PQ: 0 ANSI: 2
[ 7307.137773] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 7307.139532] sd 6:0:0:0: [sdb] Attached SCSI removable disk
et quand je tape lsusb
Bus 008 Device 012: ID 1e3d:198a Chipsbank Microelectronics Co., Ltd
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 004: ID 03f0:e311 Hewlett-Packard
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 046d:c050 Logitech, Inc. RX 250 Optical Mouse
Bus 001 Device 002: ID 03f0:0024 Hewlett-Packard KU-0316 Keyboard
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
je ne sais pas quoi faire
j'ai tenté fdisk et ca donne ca
root@debian:/home/francoise# fdisk /dev/sdb
Bienvenue dans fdisk (util-linux 2.29.2).
Les modifications resteront en mémoire jusqu'à écriture.
Soyez prudent avant d'utiliser la commande d'écriture.
fdisk: impossible d'ouvrir /dev/sdb: Aucun médium trouvé
je debute sur debian soyez indulgent
merci d'avance
elle ne s'appelle peut étre pas sdb
Pour lister les disques:
lsblk
ou bien
Je suis d'accord avec piratebab :
# lsblk pour voir l'arborescence des disques.
# df pour voir le taux d'utilisation des disques.
# fdisk -l ( L minuscule ) pour savoir les systèmes de fichiers utilisés par les disques. (Il ne faut pas préjuger que la clé est située sur sdb, il faut en savoir la situation avec cette commande )
Avec le résulat complet de ces trois commandes, les membres du site devraient résoudre ce problème, bienvenue parmi nous !
taousert72
bonjour merci de vos reponses mais je ne trouve pas la cle usb sur les resultats des deux lignes de commandes voila le resultat
francoise@debian:~$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 149,1G  0 disk
├─sda1   8:1    0    28G  0 part /
├─sda2   8:2    0     1K  0 part
├─sda5   8:5    0     2G  0 part [SWAP]
└─sda6   8:6    0 119,2G  0 part /home
sr0     11:0    1  1024M  0 rom
francoise@debian:~$
francoise@debian:~$ df
Sys. de fichiers blocs de 1K Utilisé Disponible Uti% Monté sur
udev                  986592       0     986592   0% /dev
tmpfs                 199660    6264     193396   4% /run
/dev/sda1           28704676 5459916   21763596  21% /
tmpfs                 998280   20548     977732   3% /dev/shm
tmpfs                   5120       4       5116   1% /run/lock
tmpfs                 998280       0     998280   0% /sys/fs/cgroup
/dev/sda6          122464880 7670896  108530024   7% /home
tmpfs                 199656      20     199636   1% /run/user/117
tmpfs                 199656      24     199632   1% /run/user/1000
francoise@debian:~$
francoise@debian:~$ fdisk -l
bash: fdisk : commande introuvable
et si j'ai tenté dans le premier message /dev/sdb c est que dans le programme disques il affiche le chemin /dev/sdb mais apparemment ce n'est pas marqué sur /etc/fstab
Pour fdisk -l, il est nécessaire auparavant de se connecter avec une session administrateur ( root session en anglais ).
Il est nécessaire de taper d'abord su Entrée
l'écran du terminal te demanderas ton mot de passe, c'est celui ( root ) que tu as défini lors de l'installation, j'espère que tu l'as noté. Ensuite fdisk -l fonctionnera.
entre le moment ou tu as posté le résultat de dmesg, et les commandes suivantes, es tu retiré.inséré la clef usb ? Car là, elle n'apparaîtrait pas.
essais de la retirer une dizaine de seconde, puis donne la fin de dmesg, et le résultat des autres commandes.
taousert72
resultat fdisk -l
Disque /dev/sda : 149,1 GiB, 160041885696 octets, 312581808 secteurs
Unités : secteur de 1 × 512 = 512 octets
Taille de secteur (logique / physique) : 512 octets / 512 octets
taille d'E/S (minimale / optimale) : 512 octets / 512 octets
Type d'étiquette de disque : dos
Identifiant de disque : 0x471e8398
Périphérique Amorçage    Début       Fin  Secteurs Taille Id Type
/dev/sda1    *            2048  58593279  58591232    28G 83 Linux
/dev/sda2             58595326 312580095 253984770 121,1G  5 Étendue
/dev/sda5             58595328  62674943   4079616     2G 82 partition d'échange Linux / Solaris
/dev/sda6             62676992 312580095 249903104 119,2G 83 Linux
La fonction de stockage n'est pas détectée, comme un lecteur qui serait vide.
A mon avis la clé est HS.
Je regarde si le problème a déjà eu lieu en cherchant avec l'identifiant du vendeur et du produit : idVendor=1e3d, idProduct=198a
https://www.startpage.com/do/search?cat ... opensearch
https://searx.me/?q=idVendor%3D1e3d%2C% ... anguage=fr
https://duckduckgo.com/?q=idVendor%3D1e ... =hg&ia=web
Une hypothèse possible : La clé a été utilisée avec Windows, mais retirée d'un PC Windows de manière non sécurisée.
Ce qui expliquerait qu'elle soit vue avec lsusb et dmesg, mais pas avec fdisk -l car son système de fichier serait corrompu. Dans cette hypothèse, il vaudrait le coup de la remettre dans un PC Windows et ainsi Windows réparerait le système de fichier de la clé et ensuite il faudrait retirer soigneusement la clé de manière sécurisée. Ceci est expliqué sur de nombreux sites web de telle sorte que je n'ai pas à l'expliquer ici.
Non, cette explication ne tient pas. Fdisk ne s'occupe pas des systèmes de fichiers mais seulement de la table de partition. Les messages du noyau relatifs à sdb sont incomplets. Il manque toute la partie qui détecte les caractéristiques du "disque" (identification, capacité, etc.), avant d'essayer de lire quoi que soit dessus. Windows n'en tirera rien de plus.
peut étre une de ces clefs qui se disent grande capacité, et qui en fait sont moins capacitaires que ce qu'elles affichent. Et elles se bloquent d'un coup. J'avais collecté des outils pour les débloquer, mais ils ne tournent que sous win.
En effet piratebab, il y a comme une explication possible car sur ce site de test la clé ChipsBnk Flash Disk VID = 1e3d, PID = 198a n'a pas une capacité de 2 To, mais seulement de 45,23 Go.
https://usbspeed.nirsoft.net/?o=8&vname ... 1&pid=6538
Oui, c'est confirmé les clés USB de marque Chipsbank Microelectronics Co ont déjà été dans le passé des clés pourries ou arnaqueuses voir la fin de ce premier message que j'avais posté sur https://www.debian-fr.org :
https://www.debian-fr.org/t/acheter-une ... -usb/66820
taousert72
y'a t il une possibilité de reparer la cle meme si elle n'est pas detectée
oui, mais il faut une machine windows. Les outils que j'ai trouvé ne fonctionnent pas sosus linux, ni même sous un windows virtualisé.
Essaie celui là
https://www.techspot.com/downloads/6202 ... -tool.html
