[TESTING] OCRFeeder : problème de version GTK ; Python Le sujet est résolu
Je viens d'installer :
les paquets ** sont ceux sélectionnés pour installation, les autres sont les dépendances
fonts-font-awesome (5.0.10+really4.7.0~dfsg-1)
fonts-lato (2.0-2)
gir1.2-goocanvas-2.0 (2.0.4-1)
gir1.2-gtkspell3-3.0 (3.0.9-2)
graphviz (2.40.1-3)
libann0 (1.1.2+doc-7)
libcdt5 (2.40.1-3)
libcgraph6 (2.40.1-3)
libgoocanvas-2.0-9 (2.0.4-1)
libgoocanvas-2.0-common (2.0.4-1)
libgtkspell3-3-0 (3.0.9-2)
libgts-0.7-5 (0.7.6+darcs121130-4)
libgts-bin (0.7.6+darcs121130-4)
libgvc6 (2.40.1-3)
libgvpr2 (2.40.1-3)
libjs-modernizr (2.6.2+ds1-3)
liblab-gamut1 (2.40.1-3)
libpathplan4 (2.40.1-3)
libxdot4 (2.40.1-3)
*** ocrfeeder (0.8.1-4)
*** ocrmypdf (6.2.0-1)
*** ocrmypdf-doc (6.2.0-1)
python-renderpm (3.4.0-3+b2)
python-reportlab (3.4.0-3)
python-reportlab-accel (3.4.0-3+b2)
python-sane (2.8.3-1+b2)
python3-cffi-backend (1.11.5-1+b1)
python3-defusedxml (0.5.0-1)
python3-img2pdf (0.2.3-1)
python3-pypdf2 (1.26.0-2)
python3-renderpm (3.4.0-3+b2)
python3-reportlab (3.4.0-3)
python3-reportlab-accel (3.4.0-3+b2)
python3-ruffus (2.6.3+dfsg-5)
sphinx-rtd-theme-common (0.2.4-1)
tesseract-ocr (4.00~git2481-555f6ffc-1)
tesseract-ocr-eng (1:4.00~git30-7274cfa-1)
*** tesseract-ocr-fra (1:4.00~git30-7274cfa-1)
tesseract-ocr-osd (1:4.00~git30-7274cfa-1)
unpaper (6.1-2+b1)
L'application OCRFeeder ne répondant pas en mode graphique,
j'ai testé la commande :
$ ocrfeeder --version
(ocrfeeder:13034): dbind-WARNING **: 15:59:48.589: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
/usr/lib/python2.7/dist-packages/ocrfeeder/util/lib.py:26: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
  from gi.repository import Gtk
/usr/lib/python2.7/dist-packages/ocrfeeder/studio/widgetPresenter.py:31: PyGIWarning: GooCanvas was imported without specifying a version first. Use gi.require_version('GooCanvas', '2.0') before import to ensure that the right version gets loaded.
  from gi.repository import Gtk, GooCanvas, Gdk, GObject, GLib, GdkPixbuf, GtkSpell
/usr/lib/python2.7/dist-packages/ocrfeeder/studio/widgetPresenter.py:31: PyGIWarning: GtkSpell was imported without specifying a version first. Use gi.require_version('GtkSpell', '3.0') before import to ensure that the right version gets loaded.
ocrfeeder 0.8.1
je suis en testing/xfce
j'ai python 2.7 et 3.6
ainsi que :
libgtk-3-0
libgtk-3-bin
libgtk-3-common
et
libgtk2.0-0
ibgtk2.0-bin
libgtk2.0-common
donc au niveau de GTK et Python les dépendances devraient être couvertes,
je n'ai pas de paquet cassé (selon Synaptic)
et
je n'y entends goutte au(x) problème(s) évoqué par la sortie de la commande $ ocrfeeder --version indiquée plus haut
J'ai bien trouvé ce post pour un problème similaire,
dont la "solution" est de revenir à une autre version de l'application ....
Qu'en pensez-vous ?
Je suis encore assez peu expérimenté avec Testing ....
J'aurais sans-doute du commencer par là => Debian Bug report logs - #827196 - ocrfeeder: Does not launch with supplied .desktop file
Donc dans ce cas là, je suppose qu'il ne reste plus qu'à attendre une mise à jour déboguée :017:
Le probleme est remonté au niveau du createur du logiciel, ça peut prendre du temps. Tu peux essayer de voir si dans SID ou experimental il y a une version plus récente. Si ça ne tire pas trop de dépendance à mettre à jour, tu n'a rien à perdre à le tenter.
Merci,
la version de SID est la même que celle de testing
Pour le moment je vais tenter la version antérieure de stable dans une VM virtualbox,
ça devrait me dépanner.
Décidément ... pas de chance
=> même problème avec la version de stable = 0.8.1-3
