Probleme dependances installation kcalc
Neolex
J'aimerais instaler kcalc sur ma debian mais je n'arrive pas a l'installer, je suis plutot nouveau sur debian ...
Voici l'erreur que j'ai lorsque j'essaye de l'installer
sudo apt install kcalc
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 kcalc : Depends: libkf5xmlgui5 (>= 4.98.0) but it is not going to be installed
E: Unable to correct problems, you have held broken packages
j'ai donc essayé sudo apt-geti nstall -f mais ca n'a rien installé puis :
sudo apt install libkf5xmlgui5
 libkf5xmlgui5 : Depends: qtbase-abi-5-10-0 but it is not installable
E: Unable to correct problems, you have held broken packages.
j'ai donc recherché le paquet requis avec apt-cache search et essayé de l'instaler mais ill est deja installé, jai essayé de le reinstaller mais ca n'a rien changé
sudo apt install libqt5core5a
libqt5core5a is already the newest version (5.11.1+dfsg-6).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
L'un d'entre vous aurez une idée de quoi faire après ça ?
quelques infos a propos de mon systeme :
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux buster/sid"
NAME="Debian GNU/Linux"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
cat /etc/apt/sources.list
###### Debian Main Repos
deb http://deb.debian.org/debian/ unstable main contrib non-free
deb-src http://deb.debian.org/debian/ unstable main contrib non-free
###Steam
deb [arch=i386,amd64] http://repo.steampowered.com/steam/ precise steam
###Wine
deb [arch=i386] https://dl.winehq.org/wine-builds/debian/ sid main
Merci
hybridemoineau
Ton système est en sid, en totalité ou partiellement. Quand on débute, ce n'est pas conseillé.... La sid n'est pas une version intermédiaire un peu bugguée, genre "pas LTS", c'est une version de travail forcément bugguée,
Idem pour wine, ce n'est pas forcément une bonne idée de vouloir à tout prix la dernière version en passant par leur dépôt plutôt que celui de Debian. PLayonlinux fait bien le job aussi
"Sudo" est une commande qui sert à tout sur Ubuntu ou Mint, mais pas sur Debian. Pour te loguer en admin, tape "su", entre ton mot de passe, ctrl+d pour sortir des droits administrateur
Pour essayer de sauver la mise, essaie
aptitude install kcalc
Analyse bien les réponses, refuse les premières si elles te paraissent mauvaises, poste les retours ici éventuellement.
un truc que je ne comprends pas.
Tu as un problème avec qtbase-abi-5-10-0 et tu installes libqt5core5a.
hybridemoineau
C'est une histoire de paquet virtuel, c'est le deuxième qui fournit le premier.
Nous verrons bien ce qu'en dit neolex, qui a aussi posté sur Debian-Facille où il débute depuis 2013 et qui a posté 6 heures olus tard ici alors qu'il n'avait pas encore reçu de réponse.
Nous sommes tous d'éternels débutants ...
Sur ma Sid, avec les dépôts experimental commentés dans le sources.list, la version 4.98.0 de libkf5xmlgui5 n'a pas l'air d'être pour tout de suite :
apt-cache policy libkf5xmlgui5
libkf5xmlgui5:
  Installé : 5.47.0-1
  Candidat : 5.47.0-1
 Table de version :
 *** 5.47.0-1 500
        500 http://ftp.fr.debian.org/debian testing/main amd64 Packages
        500 http://ftp.fr.debian.org/debian sid/main amd64 Packages
        100 /var/lib/dpkg/status
     5.28.0-1 500
        500 http://ftp.fr.debian.org/debian stable/main amd64 Packages
Et est-ce qu'il ne faudrait pas essayer d'en savoir plus sur les paquets cassés ?
vv222
Tout est normal ici, Debian Sid est en pleine transition de Qt 5.10 ver Qt 5.11 et il faut un peu de temps pour que tous les paquets concernés soient mis à jour.
wetaskiwin a écrit : 30 juil. 2018, 18:48 Bonjour,
libkf5xmlgui5:
  Installé : 5.47.0-1
  Candidat : 5.47.0-1
 Table de version :
 *** 5.47.0-1 500
     5.28.0-1 500
Je pense aussi qu'il s'agit de la bonne démarche. Il faudrait vérifier en premier lieu ce qui est cassé, mal installé.
$ dpkg --audit
vv222
De mon côté, tous les paquets Qt 5 ont été mis à jour vers la version 5.11 aujourd’hui, il est possible que la migration soit maintenant terminée.
