Après un upgrade jessie->stretch sur un VPS VMWARE j'ai 3 services en panne sont rsyslog. Voici ce que rapporte systemd:
vm293 ~ > systemctl reset-failed
vm293 ~ > systemctl start rsyslog
Job for rsyslog.service failed because the control process exited with error code.
See "systemctl status rsyslog.service" and "journalctl -xe" for details.
vm293 ~ > journalctl -xe
-- L'unité (unit) rsyslog.service a terminé son arrêt.
oct. 16 11:47:42 vm293 systemd[1]: Starting System Logging Service...
-- Subject: L'unité (unit) rsyslog.service a commencé à démarrer
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- L'unité (unit) rsyslog.service a commencé à démarrer.
oct. 16 11:47:42 vm293 systemd[1]: rsyslog.service: Main process exited, code=exited, status=1/FAILURE
oct. 16 11:47:42 vm293 systemd[1]: Failed to start System Logging Service.
-- Subject: L'unité (unit) rsyslog.service a échoué
-- L'unité (unit) rsyslog.service a échoué, avec le résultat failed.
oct. 16 11:47:42 vm293 systemd[1]: rsyslog.service: Unit entered failed state.
oct. 16 11:47:42 vm293 systemd[1]: rsyslog.service: Failed with result 'exit-code'.
oct. 16 11:47:42 vm293 systemd[1]: rsyslog.service: Service hold-off time over, scheduling restart.
oct. 16 11:47:42 vm293 systemd[1]: Stopped System Logging Service.
-- Subject: L'unité (unit) rsyslog.service a terminé son arrêt
oct. 16 11:47:42 vm293 systemd[1]: rsyslog.service: Start request repeated too quickly.
oct. 16 11:47:42 vm293 systemd[1]: syslog.socket: Unit entered failed state.
