Bluetooth
MixMax
mon BT ne fonctionne pas (aucun adaptateur...).
La commande lspci me renvoie ça:
david@debian:~$ lspci
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 5500 (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection (3) I218-LM (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #6 (rev e3)
00:1c.1 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3)
00:1d.0 USB controller: Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
00:1f.6 Signal processing controller: Intel Corporation Wildcat Point-LP Thermal Management Controller (rev 03)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5227 PCI Express Card Reader (rev 01)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8192EE PCIe Wireless Network Adapter
Quel est la ligne qui correspond au BT ? La dernière ?
donne le retour de
 $ hcitool dev
$ hcitool scan
Si ça peut te mettre sur la piste sur Intel NUC6 les commandes précédentes de sv0t ne donnent rien,
mais avec lshw (je me sers de la gui pour trouver)
Interface sans fil Bluetooth
/0/100/15/0/8
fabriquant: Intel Corp. [8087]
information bus: usb@1:8
version: 0.01
fonctionnalités:
Bluetooth wireless radio,
USB 2.0
configuration:
driver: btusb
maxpower: 100mA
speed: 12Mbit/s
# lshw
              *-usb:2
                   description: Interface sans fil Bluetooth
                   identifiant matériel: 8
                   version: 0.01
                   fonctionnalités: bluetooth usb-2.00
                   configuration: driver=btusb maxpower=100mA speed=12Mbit/s
Avec un peu de bol le tien utilise le même pilote
:003:
Pour info,
lsusb n'a pas trouvé mon BT :017:
Je précise pour hcitool
Sur mon équipement
$ hcitool dev
Devices:
	hci0	18:56:80:AB:34:DD
et
# hcitool scan
Scanning ...
qui ne renvoie rien.
Je te refile un peu au "dépoté" ce que j'ai noté lors de mon install ( c'était mon 1er BT)
$ dpkg-query -l | grep bluetooth
ii  bluetooth                            5.50-1                             all          Bluetooth support (metapackage)
ii  libbluetooth-dev:amd64               5.50-1                             amd64        Development files for using the BlueZ Linux Bluetooth library
ii  libbluetooth3:amd64                  5.50-1                             amd64        Library to use the BlueZ Linux Bluetooth stack
ii  pulseaudio-module-bluetooth          12.2-4                             amd64        Bluetooth module for PulseAudio sound server
dpkg-query -l | grep bluez
ii  bluez                                5.50-1                             amd64        Bluetooth tools and daemons
ii  bluez-firmware                       1.2-4                              all          Firmware for Bluetooth devices
Interface GTK
Commit Log for Sun Mar 31 12:24:49 2019
Les paquets suivants ont été installés :
blueman (2.0.8-1)
Vérification Démon
$ systemctl status bluetooth
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
   Active: active (running) since Sun 2019-03-31 08:38:40 CEST; 3h 16min ago
     Docs: man:bluetoothd(8)
 Main PID: 538 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4915)
   Memory: 3.3M
   CGroup: /system.slice/bluetooth.service
           └─538 /usr/lib/bluetooth/bluetoothd
lines 1-10/10 (END)
Voilà, avec ça tu as la liste des paquets et la vérification du service
Good Luck :040:
Je l'ai trouvé avec lsusb -t
# lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/7p, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 480M
    |__ Port 3: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 3: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 3: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 4: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    |__ Port 8: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
    |__ Port 8: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
c'est le dernier => port 8
MixMax
david@debian:~$ hcitool dev
Devices:
david@debian:~$ hcitool scan
Device is not available: No such device
MixMax
root@debian:/home/david# lshw
debian
    description: Ordinateur Bloc-notes
    produit: 20CLS02M00 (LENOVO_MT_20CL_BU_Think_FM_ThinkPad X250)
    fabriquant: LENOVO
    version: ThinkPad X250
    numéro de série: PC05NCCX
    bits: 64 bits
    fonctionnalités: smbios-2.7 dmi-2.7 smp vsyscall32
    configuration: administrator_password=enabled chassis=notebook family=ThinkPad X250 power-on_password=disabled sku=LENOVO_MT_20CL_BU_Think_FM_ThinkPad X250 uuid=81E11F10-B253-CB11-B624-C8A22546E617
  *-core
       description: Carte mère
       produit: 20CLS02M00
       fabriquant: LENOVO
       identifiant matériel: 0
       version: SDK0E50510 WIN
       numéro de série: L1HF54R040V
       emplacement: Not Available
     *-cache
          description: L1 cache
          identifiant matériel: 3
          emplacement: L1 Cache
          taille: 32KiB
          capacité: 32KiB
          fonctionnalités: synchronous internal write-back data
          configuration: level=1
     *-cpu
          description: CPU
          produit: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
          identifiant matériel: 4
          information bus: cpu@0
          version: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
          numéro de série: None
          emplacement: U3E1
          taille: 2525MHz
          capacité: 2700MHz
          bits: 64 bits
          horloge: 100MHz
          fonctionnalités: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap intel_pt xsaveopt dtherm ida arat pln pts md_clear flush_l1d cpufreq
          configuration: cores=2 enabledcores=2 threads=4
        *-cache:0
             identifiant matériel: 5
             taille: 32KiB
             capacité: 32KiB
             fonctionnalités: synchronous internal write-back instruction
        *-cache:1
             description: L2 cache
             identifiant matériel: 6
             emplacement: L2 Cache
             taille: 256KiB
             capacité: 256KiB
             fonctionnalités: synchronous internal write-back unified
             configuration: level=2
        *-cache:2
             description: L3 cache
             identifiant matériel: 7
             emplacement: L3 Cache
             taille: 3MiB
             capacité: 3MiB
             configuration: level=3
     *-memory
          description: Mémoire Système
          emplacement: Carte mère
          taille: 4GiB
        *-bank
             description: SODIMM DDR3 Synchrone 1600 MHz (0,6 ns)
             produit: M471B5173DB0-YK0
             fabriquant: Samsung
             numéro de série: 21056714
             emplacement: ChannelA-DIMM0
             taille: 4GiB
             bits: 64 bits
             horloge: 1600MHz (0.6ns)
     *-firmware
          description: BIOS
          fabriquant: LENOVO
          identifiant matériel: 30
          version: N10ET28W (1.05 )
          date: 01/23/2015
          taille: 128KiB
          capacité: 16MiB
          fonctionnalités: pci pnp upgrade shadowing cdboot bootselect acpi usb biosbootspecification uefi
     *-pci
          description: Host bridge
          produit: Broadwell-U Host Bridge -OPI
          fabriquant: Intel Corporation
          identifiant matériel: 100
          information bus: pci@0000:00:00.0
          version: 09
          bits: 32 bits
          horloge: 33MHz
          configuration: driver=bdw_uncore
          ressources: irq:0
        *-display
             description: VGA compatible controller
             produit: HD Graphics 5500
             identifiant matériel: 2
             information bus: pci@0000:00:02.0
             version: 09
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             ressources: irq:46 mémoire:f0000000-f0ffffff mémoire:e0000000-efffffff portE/S:4000(taille=64) mémoire:c0000-dffff
        *-multimedia:0
             description: Audio device
             produit: Broadwell-U Audio Controller
             information bus: pci@0000:00:03.0
             version: 09
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi pciexpress bus_master cap_list
             configuration: driver=snd_hda_intel latency=0
             ressources: irq:42 mémoire:f1230000-f1233fff
        *-usb:0
             description: USB controller
             produit: Wildcat Point-LP USB xHCI Controller
             identifiant matériel: 14
             information bus: pci@0000:00:14.0
             version: 03
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             ressources: irq:45 mémoire:f1220000-f122ffff
           *-usbhost:0
                produit: xHCI Host Controller
                fabriquant: Linux 4.19.0-9-amd64 xhci-hcd
                information bus: usb@2
                nom logique: usb2
                version: 4.19
                fonctionnalités: usb-2.00
                configuration: driver=hub slots=11 speed=480Mbit/s
              *-usb:0
                   description: Souris
                   produit: USB Optical Mouse
                   fabriquant: Sunplus Innovation Technology Inc.
                   information bus: usb@2:1
                   version: 0.14
                   configuration: driver=usbhid maxpower=98mA speed=1Mbit/s
              *-usb:1
                   description: Interface réseau sans fil
                   produit: Jolla C
                   fabriquant: Jolla
                   information bus: usb@2:2
                   version: 3.10
                   numéro de série: 3305e0d9
                   configuration: driver=rndis_host maxpower=500mA speed=480Mbit/s
              *-usb:2
                   description: Vidéo
                   produit: Integrated Camera
                   fabriquant: SunplusIT Inc
                   information bus: usb@2:8
                   version: 0.18
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
           *-usbhost:1
                information bus: usb@3
                nom logique: usb3
                version: 4.19
                fonctionnalités: usb-3.00
                configuration: driver=hub slots=4 speed=5000Mbit/s
        *-communication
             description: Communication controller
             produit: Wildcat Point-LP MEI Controller #1
             identifiant matériel: 16
             information bus: pci@0000:00:16.0
             version: 03
             bits: 64 bits
             horloge: 33MHz
             fonctionnalités: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             ressources: irq:47 mémoire:f1239000-f123901f
        *-network
             description: Ethernet interface
             produit: Ethernet Connection (3) I218-LM
             identifiant matériel: 19
             information bus: pci@0000:00:19.0
             nom logique: enp0s25
             version: 03
             numéro de série: 68:f7:28:c2:81:93
             capacité: 1Gbit/s
             bits: 32 bits
             horloge: 33MHz
             fonctionnalités: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
             configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=0.2-3 latency=0 link=no multicast=yes port=twisted pair
             ressources: irq:51 mémoire:f1200000-f121ffff mémoire:f123e000-f123efff portE/S:4080(taille=32)
        *-multimedia:1
             produit: Wildcat Point-LP High Definition Audio Controller
             identifiant matériel: 1b
             information bus: pci@0000:00:1b.0
             version: 03
             bits: 64 bits
             horloge: 33MHz
             configuration: driver=snd_hda_intel latency=32
             ressources: irq:50 mémoire:f1234000-f1237fff
        *-pci:0
             description: PCI bridge
             produit: Wildcat Point-LP PCI Express Root Port #6
             identifiant matériel: 1c
             information bus: pci@0000:00:1c.0
             version: e3
             bits: 32 bits
             horloge: 33MHz
             fonctionnalités: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             ressources: irq:17 mémoire:f1100000-f11fffff
           *-generic
                description: Unassigned class
                produit: RTS5227 PCI Express Card Reader
                fabriquant: Realtek Semiconductor Co., Ltd.
                information bus: pci@0000:02:00.0
                version: 01
                bits: 32 bits
                horloge: 33MHz
                configuration: driver=rtsx_pci latency=0
                ressources: irq:43 mémoire:f1100000-f1100fff
        *-pci:1
             produit: Wildcat Point-LP PCI Express Root Port #3
             identifiant matériel: 1c.1
             information bus: pci@0000:00:1c.1
             version: e3
             bits: 32 bits
             horloge: 33MHz
             ressources: irq:18 portE/S:3000(taille=4096) mémoire:f1000000-f10fffff
           *-network
                produit: RTL8192EE PCIe Wireless Network Adapter
                information bus: pci@0000:03:00.0
                nom logique: wlp3s0
                version: 00
                numéro de série: d8:5d:e2:5c:37:3f
                bits: 64 bits
                horloge: 33MHz
                fonctionnalités: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=rtl8192ee driverversion=4.19.0-9-amd64 firmware=N/A ip=172.28.172.2 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                ressources: irq:57 portE/S:3000(taille=256) mémoire:f1000000-f1003fff
        *-usb:1
             produit: Wildcat Point-LP USB EHCI Controller
             identifiant matériel: 1d
             information bus: pci@0000:00:1d.0
             version: 03
             bits: 32 bits
             horloge: 33MHz
             fonctionnalités: pm debug ehci bus_master cap_list
             configuration: driver=ehci-pci latency=0
             ressources: irq:23 mémoire:f123d000-f123d3ff
           *-usbhost
                produit: EHCI Host Controller
                fabriquant: Linux 4.19.0-9-amd64 ehci_hcd
                nom logique: usb1
                version: 4.19
                configuration: driver=hub slots=3 speed=480Mbit/s
              *-usb
                   description: USB hub
                   information bus: usb@1:1
                   version: 0.03
                   configuration: driver=hub slots=8 speed=480Mbit/s
        *-isa
             description: ISA bridge
             produit: Wildcat Point-LP LPC Controller
             identifiant matériel: 1f
             information bus: pci@0000:00:1f.0
             version: 03
             bits: 32 bits
             horloge: 33MHz
             fonctionnalités: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             ressources: irq:0
        *-sata
             description: SATA controller
             produit: Wildcat Point-LP SATA Controller [AHCI Mode]
             identifiant matériel: 1f.2
             information bus: pci@0000:00:1f.2
             nom logique: scsi0
             version: 03
             bits: 32 bits
             horloge: 66MHz
             fonctionnalités: sata msi pm ahci_1.0 bus_master cap_list emulated
             configuration: driver=ahci latency=0
             ressources: irq:44 portE/S:40a8(taille=8) portE/S:40b4(taille=4) portE/S:40a0(taille=8) portE/S:40b0(taille=4) portE/S:4060(taille=32) mémoire:f123c000-f123c7ff
           *-disk
                description: ATA Disk
                produit: INTEL SSDSC2BW18
                identifiant matériel: 0.0.0
                information bus: scsi@0:0.0.0
                nom logique: /dev/sda
                version: LCSi
                numéro de série: CVCV2274033X180EGN
                taille: 167GiB (180GB)
                fonctionnalités: partitioned partitioned:dos
                configuration: ansiversion=5 logicalsectorsize=512 sectorsize=512 signature=10d2f88a
              *-volume:0
                   description: EXT4 volume
                   fabriquant: Linux
                   information bus: scsi@0:0.0.0,1
                   nom logique: /dev/sda1
                   nom logique: /
                   version: 1.0
                   numéro de série: bd516a13-f767-4f39-befc-1392af771e30
                   taille: 17GiB
                   capacité: 17GiB
                   fonctionnalités: primary bootable journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                   configuration: created=2020-03-06 20:40:38 filesystem=ext4 lastmountpoint=/ modified=2020-05-13 16:27:35 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro mounted=2020-05-13 16:27:35 state=mounted
              *-volume:1
                   description: Linux swap volume
                   information bus: scsi@0:0.0.0,2
                   nom logique: /dev/sda2
                   version: 1
                   numéro de série: 65130f0a-0627-46ff-8850-d74bbefb239f
                   taille: 3813MiB
                   capacité: 3813MiB
                   fonctionnalités: primary nofs swap initialized
                   configuration: filesystem=swap pagesize=4096
              *-volume:2
                   fabriquant: Linux
                   information bus: scsi@0:0.0.0,3
                   nom logique: /dev/sda3
                   nom logique: /home
                   version: 1.0
                   numéro de série: 6c0f8aa4-6cd9-4be0-bd80-9fe6b252f8d4
                   taille: 146GiB
                   capacité: 146GiB
                   fonctionnalités: primary journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                   configuration: created=2017-09-01 20:56:27 filesystem=ext4 lastmountpoint=/home modified=2020-05-13 16:27:36 mount.fstype=ext4 mount.options=rw,relatime mounted=2020-05-13 16:27:36 state=mounted
        *-serial
             description: SMBus
             produit: Wildcat Point-LP SMBus Controller
             identifiant matériel: 1f.3
             information bus: pci@0000:00:1f.3
             version: 03
             bits: 64 bits
             horloge: 33MHz
             configuration: driver=i801_smbus latency=0
             ressources: irq:18 mémoire:f1238000-f12380ff portE/S:efa0(taille=32)
        *-generic
             description: Signal processing controller
             produit: Wildcat Point-LP Thermal Management Controller
             identifiant matériel: 1f.6
             information bus: pci@0000:00:1f.6
             version: 03
             bits: 64 bits
             horloge: 33MHz
             configuration: driver=intel_pch_thermal latency=0
             ressources: irq:18 mémoire:f123b000-f123bfff
     *-pnp00:00
          produit: PnP device PNP0c01
          fonctionnalités: pnp
          configuration: driver=system
     *-pnp00:01
          produit: PnP device PNP0c02
     *-pnp00:02
          produit: PnP device PNP0b00
          configuration: driver=rtc_cmos
     *-pnp00:03
          produit: PnP device LEN0071
          configuration: driver=i8042 kbd
     *-pnp00:04
          produit: PnP device LEN0046
          configuration: driver=i8042 aux
     *-pnp00:05
          produit: PnP device SMO1200
          configuration: driver=tpm_tis
     *-pnp00:06
          identifiant matériel: 9
  *-battery
       produit: 45N1735
       fabriquant: LGC
       emplacement: Rear
       capacité: 47520mWh
       configuration: voltage=10,8V
  *-network
       nom logique: usb0
       numéro de série: 22:b6:a9:05:0d:fc
       fonctionnalités: ethernet physical
       configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=172.28.172.3 link=yes multicast=yes
Je ne vois rien qui concerne du BT là dedans.
Si ça se trouve, mon PC n'a pas de puce BT...
MixMax
david@debian:~$ dpkg-query -l | grep bluetooth
ii  blueman                               2.0.8-1                              amd64        Graphical bluetooth manager
ii  blueproximity                         1.2.5-6                              all          locks/unlocks your desktop tracking a bluetooth device
ii  bluetooth                             5.50-1.2~deb10u1                     all          Bluetooth support (metapackage)
ii  libbluetooth3:amd64                   5.50-1.2~deb10u1                     amd64        Library to use the BlueZ Linux Bluetooth stack
ii  pulseaudio-module-bluetooth           12.2-4+deb10u1                       amd64        Bluetooth module for PulseAudio sound server
ii  python-bluez                          0.22+really0.22-1                    amd64        Python 2 wrappers around BlueZ for rapid bluetooth development
ii  python3-bluez                         0.22+really0.22-1                    amd64        Python 3 wrappers around BlueZ for rapid bluetooth development
david@debian:~$ dpkg-query -l | grep bluez
ii  bluez                                 5.50-1.2~deb10u1                     amd64        Bluetooth tools and daemons
ii  bluez-obexd                           5.50-1.2~deb10u1                     amd64        bluez obex daemon
ii  bluez-test-tools                      5.50-1.2~deb10u1                     amd64        test tools of bluez
ii  bluez-tools                           2.0~20170911.0.7cb788c-2             amd64        Set of tools to manage Bluetooth devices for linux
david@debian:~$ systemctl status bluetooth
   Active: active (running) since Wed 2020-05-13 16:27:59 CEST; 2 days ago
 Main PID: 1224 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4310)
   Memory: 1.4M
           └─1224 /usr/lib/bluetooth/bluetoothd
lines 1-10/10 (END)
MixMax
De ce que j'en comprends, il me manque quelques paquets par rapport à toi. Je vais essayer de compléter et je vais bien voir.
Parce que j'ai l'impression qu'un service BT est actif, non ?
MixMax
/0/100/1c.1/0
produit: RTL8192EE PCIe Wireless Network Adapter [10EC:818B]
fabriquant: Realtek Semiconductor Co., Ltd. [10EC]
nom logique: wlp3s0
version: 00
bits: 64 bits
horloge: 33MHz
fonctionnalités:
	Power Management,
	Message Signalled Interrupts,
	PCI Express,
	bus mastering,
	PCI capabilities listing,
	ethernet,
	Interface physique,
	Réseau sans fil
configuration:
	broadcast: yes
	driver: rtl8192ee
	driverversion: 4.19.0-9-amd64
	firmware: N/A
	ip: 172.28.172.2
	latency: 0
	link: yes
	multicast: yes
	wireless: IEEE 802.11
ressources:
	irq: 57
	portE/S: 3000(taille=256)
	mémoire: f1000000-f1003fff
Sinon, j'ai ça sur lshw (gui), mais quid du BT ?
MixMax
david@debian:~$ lsusb -t
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/11p, 480M
    |__ Port 1: Dev 8, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    |__ Port 2: Dev 10, If 0, Class=Wireless, Driver=rndis_host, 480M
    |__ Port 2: Dev 10, If 1, Class=CDC Data, Driver=rndis_host, 480M
    |__ Port 8: Dev 4, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 8: Dev 4, If 1, Class=Video, Driver=uvcvideo, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
Pareil, tout ça est un peu obscure, pour moi...
MixMax
Et je ne trouve pas bluez-firmware dans synaptic...
edit : bon je l'ai trouvé ailleurs, mais pour stretch, pas pour buster. Ça s'installe, mais ne change rien. Je n'ai toujours aucune connexion BT.
MixMax
En tout cas, merci pour vos retour ! :icon_e_wink:
MixMax a écrit : 15 mai 2020, 20:19 Je ne vois rien qui concerne du BT là dedans.
Oui, c'est bien possible ... si il n'a pas le BT ça va être difficile de le trouver
Tente d'identifier très précisément ton modèle pour voir sur la toile la doc du fabricant.
MixMax a écrit : 15 mai 2020, 20:36 Et je ne trouve pas bluez-firmware dans synaptic...
https://packages.debian.org/buster/bluez-firmware => c'est "non-free"
vérifies dans tes sources ( /etc/apt/sources.list )
que les lignes comportent aussi à la fin : contrib non-free
comme p.ex ;
deb http://deb.debian.org/debian/ buster main contrib non-free
Mais si il n'y a pas de BT ... c'est peut-être plus la peine ... à moins que tu nécessites d'autres paquets non-free :003:
Il faut effectivement avoir les paquets contrib et non-free comme dépot déactivé. De nombreux drivers ou firmware ne sont pas complètement libres, et donc ne peuvent pas être acceptés dans les dépot principaux.
Dans une des sorties de commande que tu as indiqué, il y a marqué firmware:N/A, ce qui est généralement pas normal. La plupard des interfaces BT ont besoin d'un firmware.
Pour vérifier, donne la sortie de
#dmesg | grep firmware
Je ne sais pas si tu as vérifier si les services BT étaient activé (ça servira plus tard, lorsque le device BT sera actif)
#/etc/init.d/bluetooth status
MixMax
# dmesg | grep firmware
[    0.210374] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    5.465376] rtl8192ee: Using firmware rtlwifi/rtl8192eefw.bin
[    5.468889] rtl8192ee 0000:03:00.0: firmware: direct-loading firmware rtlwifi/rtl8192eefw.bin
[    5.486153] psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3
[  947.771518] (NULL device *): firmware: direct-loading firmware rtlwifi/rtl8192eefw.bin
[  949.320626] psmouse serio2: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3
[ 1135.103045] (NULL device *): firmware: direct-loading firmware rtlwifi/rtl8192eefw.bin
[ 1662.758419] (NULL device *): firmware: direct-loading firmware rtlwifi/rtl8192eefw.bin
[ 7344.607605] (NULL device *): firmware: direct-loading firmware rtlwifi/rtl8192eefw.bin
MixMax
# /etc/init.d/bluetooth status
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Wed 2020-05-27 23:11:57 CEST; 1 day 11h ago
 Main PID: 1262 (bluetoothd)
   Status: "Running"
   Memory: 2.2M
           └─1262 /usr/lib/bluetooth/bluetoothd
mai 27 23:11:56 debian systemd[1]: Starting Bluetooth service...
mai 27 23:11:57 debian bluetoothd[1262]: Bluetooth daemon 5.50
mai 27 23:11:57 debian systemd[1]: Started Bluetooth service.
mai 27 23:11:57 debian bluetoothd[1262]: Starting SDP server
mai 27 23:11:57 debian bluetoothd[1262]: Bluetooth management interface 1.1…ized
Hint: Some lines were ellipsized, use -l to show in full.
MixMax
Et trouvé sur le site de Realtek :
https://www.realtek.com/en/component/zo ... e-software
RTL8192EE Software
Windows
For Realtek PCIe WLAN Family Controller. The driver released on the website only supports the following products:
RTL8723BE/RTL8821AE/RTL8822BE/RTL8821CE/RTL8723DE: WLAN/Bluetooth combo solutions, need to install WLAN and Bluetooth drivers
RTL8812AE/RTL8192EE/RTL8188EE: WLAN-only solutions, install WLAN driver
Je crois que ça répond à la question...
