Je me permets de venir vers vous, car je sais que certaines personnes ici utilise ISPCONFIG.
Depuis une MAJ système et logiciel etc… je n’arrive plus à accéder à Roundcube.
Les services de mails fonctionnent pour info.
Si je vais sur : https://xx.xx.xx.xx:8080/webmail
Je me heurte à une erreur 403. « Forbidden You don't have permission to access this resource. »
[Fri Oct 30 09:39:29.926634 2020] [authz_core:error] [pid 28047] [client xx.xxx.xx.xx:59309] AH01630: client denied by server configuration: /var/lib/roundcube/Code : Tout sélectionner
root@SRV:/tmp/ispconfig3_install/install# ls -al /var/lib/roundcube/
total 20
drwxr-xr-x 5 root root 4096 Oct 27 11:19 .
drwxr-xr-x 54 root root 4096 Oct 27 11:19 ..
lrwxrwxrwx 1 root root 14 Aug 11 17:44 config -> /etc/roundcube
lrwxrwxrwx 1 root root 23 Aug 11 17:44 .htaccess -> /etc/roundcube/htaccess
lrwxrwxrwx 1 root root 30 Aug 11 17:44 index.php -> /usr/share/roundcube/index.php
lrwxrwxrwx 1 root root 19 Aug 11 17:44 logs -> ../../log/roundcube
drwxr-xr-x 2 root root 4096 Oct 29 08:29 plugins
lrwxrwxrwx 1 root root 28 Aug 11 17:44 program -> /usr/share/roundcube/program
drwxr-xr-x 2 root root 4096 Oct 27 11:19 skins
drwxr-x--- 2 www-data www-data 4096 Aug 11 17:44 temp
root@SRV:/tmp/ispconfig3_install/install#Code : Tout sélectionner
/etc/apache2/conf-available# cat roundcube.conf
# Those aliases do not work properly with several hosts on your apache server
# Uncomment them to use it or adapt them to your configuration
# Alias /roundcube /var/lib/roundcube
Alias /webmail /var/lib/roundcube
<Directory /var/lib/roundcube/>
Options +FollowSymLinks
# This is needed to parse /var/lib/roundcube/.htaccess. See its
# content before setting AllowOverride to None.
AllowOverride All
<IfVersion >= 2.3>
Require all granted
</IfVersion>
<IfVersion < 2.3>
Order allow,deny
Allow from all
</IfVersion>
</Directory>
# Protecting basic directories:
<Directory /var/lib/roundcube/config>
Options -FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/lib/roundcube/temp>
AllowOverride None
<IfVersion >= 2.3>
Require all denied
</IfVersion>
<IfVersion < 2.3>
Order allow,deny
Deny from all
</IfVersion>
</Directory>
<Directory /var/lib/roundcube/logs>
AllowOverride None
<IfVersion >= 2.3>
Require all denied
</IfVersion>
<IfVersion < 2.3>
Order allow,deny
Deny from all
</IfVersion>
</Directory>https://dump.4network.org/2015/05/0...n ... roundcube/
mais sans succès....
Ca fait des heures que je cherche. Est-ce que vous auriez une piste ? ou idée ?
Merci d'avance
A bientot
