Par exemple systemctl restart network-manager me ramene en mode console et freez un certzin temps avant de me redemander mon login et avec les lignes suivantes:
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, systemctl default" or "exit" to boot into default mode.
Donnez le mot de passe du superutilisateur pour la maintenance...Code : Tout sélectionner
[ 234.542]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 234.550] Build Operating System: Linux 4.19.0-12-amd64 x86_64 Debian
[ 234.552] Current Operating System: Linux Makina 4.19.0-14-amd64 #1 SMP Debian 4.19.171-2 (2021-01-30) x86_64
[ 234.552] Kernel command line: BOOT_IMAGE=/vmlinuz-4.19.0-14-amd64 root=/dev/mapper/Makina--vg-root ro single nosplash
[ 234.557] Build Date: 01 December 2020 05:59:57PM
[ 234.559] xorg-server 2:1.20.4-1+deb10u2 (https://www.debian.org/support)
[ 234.561] Current version of pixman: 0.36.0
[ 234.565] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 234.565] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 234.573] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 8 18:50:58 2021
[ 234.642] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 234.673] (==) No Layout section. Using the first Screen section.
[ 234.673] (==) No screen section available. Using defaults.
[ 234.673] (**) |-->Screen "Default Screen Section" (0)
[ 234.673] (**) | |-->Monitor "<default monitor>"
[ 234.685] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 234.685] (==) Automatically adding devices
[ 234.685] (==) Automatically enabling devices
[ 234.685] (==) Automatically adding GPU devices
[ 234.685] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 234.722] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 234.722] Entry deleted from font path.
[ 234.727] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 234.727] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 234.727] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 234.727] (II) Loader magic: 0x55afe353be20
[ 234.727] (II) Module ABI versions:
[ 234.727] X.Org ANSI C Emulation: 0.4
[ 234.727] X.Org Video Driver: 24.0
[ 234.727] X.Org XInput driver : 24.1
[ 234.727] X.Org Server Extension : 10.0
[ 234.734] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 234.734] (++) using VT number 1
[ 234.736] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 234.746] (--) PCI:*(0@0:2:0) 8086:0046:17aa:215a rev 2, Mem @ 0xf2000000/4194304, 0xd0000000/268435456, I/O @ 0x00001800/8, BIOS @ 0x????????/131072
[ 234.746] (II) LoadModule: "glx"
[ 234.771] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 234.836] (II) Module glx: vendor="X.Org Foundation"
[ 234.836] compiled for 1.20.4, module version = 1.0.0
[ 234.836] ABI class: X.Org Server Extension, version 10.0
[ 234.836] (==) Matched modesetting as autoconfigured driver 0
[ 234.836] (==) Matched fbdev as autoconfigured driver 1
[ 234.836] (==) Matched vesa as autoconfigured driver 2
[ 234.836] (==) Assigned the driver to the xf86ConfigLayout
[ 234.836] (II) LoadModule: "modesetting"
[ 234.836] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 234.851] (II) Module modesetting: vendor="X.Org Foundation"
[ 234.851] compiled for 1.20.4, module version = 1.20.4
[ 234.851] Module class: X.Org Video Driver
[ 234.851] ABI class: X.Org Video Driver, version 24.0
[ 234.851] (II) LoadModule: "fbdev"
[ 234.851] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 234.867] (II) Module fbdev: vendor="X.Org Foundation"
[ 234.867] compiled for 1.20.0, module version = 0.5.0
[ 234.867] Module class: X.Org Video Driver
[ 234.867] ABI class: X.Org Video Driver, version 24.0
[ 234.867] (II) LoadModule: "vesa"
[ 234.867] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 234.878] (II) Module vesa: vendor="X.Org Foundation"
[ 234.878] compiled for 1.20.1, module version = 2.4.0
[ 234.878] Module class: X.Org Video Driver
[ 234.878] ABI class: X.Org Video Driver, version 24.0
[ 234.878] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 234.878] (II) FBDEV: driver for framebuffer: fbdev
[ 234.878] (II) VESA: driver for VESA chipsets: vesa
[ 234.891] (II) modeset(0): using drv /dev/dri/card0
[ 234.891] (WW) Falling back to old probe method for fbdev
[ 234.891] (II) Loading sub module "fbdevhw"
[ 234.891] (II) LoadModule: "fbdevhw"
[ 234.891] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 234.899] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 234.899] compiled for 1.20.4, module version = 0.0.2
[ 234.899] ABI class: X.Org Video Driver, version 24.0
[ 234.899] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 234.899] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 234.899] (==) modeset(0): RGB weight 888
[ 234.899] (==) modeset(0): Default visual is TrueColor
[ 234.899] (II) Loading sub module "glamoregl"
[ 234.899] (II) LoadModule: "glamoregl"
[ 234.899] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 234.952] (II) Module glamoregl: vendor="X.Org Foundation"
[ 234.952] compiled for 1.20.4, module version = 1.0.1
[ 234.952] ABI class: X.Org ANSI C Emulation, version 0.4
[ 235.477] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel(R) Ironlake Mobile
[ 235.477] (II) modeset(0): glamor initialized
[ 235.477] (II) modeset(0): Output LVDS-1 has no monitor section
[ 235.478] (II) modeset(0): Output VGA-1 has no monitor section
[ 235.670] (II) modeset(0): Output HDMI-1 has no monitor section
[ 235.670] (II) modeset(0): Output DP-1 has no monitor section
[ 235.672] (II) modeset(0): Output HDMI-2 has no monitor section
[ 235.673] (II) modeset(0): Output HDMI-3 has no monitor section
[ 235.673] (II) modeset(0): Output DP-2 has no monitor section
[ 235.673] (II) modeset(0): Output DP-3 has no monitor section
[ 235.674] (II) modeset(0): EDID for output LVDS-1
[ 235.674] (II) modeset(0): Manufacturer: LEN Model: 4036 Serial#: 0
[ 235.674] (II) modeset(0): Year: 2009 Week: 0
[ 235.674] (II) modeset(0): EDID Version: 1.3
[ 235.674] (II) modeset(0): Digital Display Input
[ 235.674] (II) modeset(0): Max Image Size [cm]: horiz.: 30 vert.: 19
[ 235.674] (II) modeset(0): Gamma: 2.20
[ 235.674] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 235.674] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 235.674] (II) modeset(0): First detailed timing is preferred mode
[ 235.674] (II) modeset(0): redX: 0.577 redY: 0.338 greenX: 0.310 greenY: 0.563
[ 235.674] (II) modeset(0): blueX: 0.158 blueY: 0.157 whiteX: 0.313 whiteY: 0.329
[ 235.674] (II) modeset(0): Manufacturer's mask: 0
[ 235.674] (II) modeset(0): Supported detailed timing:
[ 235.674] (II) modeset(0): clock: 114.1 MHz Image Size: 303 x 190 mm
[ 235.674] (II) modeset(0): h_active: 1440 h_sync: 1488 h_sync_end 1520 h_blank_end 2044 h_border: 0
[ 235.674] (II) modeset(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 930 v_border: 0
[ 235.674] (II) modeset(0): h_active: 1440 h_sync: 1488 h_sync_end 1520 h_blank_end 2204 h_border: 0
[ 235.674] (II) modeset(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 1035 v_border: 0
[ 235.674] (II) modeset(0): Unknown vendor-specific block f
[ 235.674] (II) modeset(0): LTN141BT09001
[ 235.674] (II) modeset(0): EDID (in hex):
[ 235.674] (II) modeset(0): 00ffffffffffff0030ae364000000000
[ 235.674] (II) modeset(0): 00130103801e1378eae59593564f9028
[ 235.674] (II) modeset(0): 28505400000001010101010101010101
[ 235.674] (II) modeset(0): 0101010101018e2ca05c52841e303020
[ 235.674] (II) modeset(0): 36002fbe100000198e2ca0fc52848730
[ 235.674] (II) modeset(0): 302036002fbe100000190000000f0095
[ 235.674] (II) modeset(0): 0a32950a281609004ca34254000000fe
[ 235.674] (II) modeset(0): 004c544e3134314254303930303100f0
[ 235.674] (II) modeset(0): Printing probed modes for output LVDS-1
[ 235.674] (II) modeset(0): Modeline "1440x900"x60.0 114.06 1440 1488 1520 2044 900 903 909 930 -hsync -vsync (55.8 kHz eP)
[ 235.674] (II) modeset(0): Modeline "1440x900"x50.0 114.06 1440 1488 1520 2204 900 903 909 1035 -hsync -vsync (51.8 kHz e)
[ 235.674] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
[ 235.674] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 235.674] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 235.674] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 235.674] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 235.674] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 235.674] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 235.674] (II) modeset(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 235.674] (II) modeset(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 235.674] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 235.674] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 235.674] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 235.674] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 235.674] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 235.674] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 235.674] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 235.674] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 235.674] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 235.674] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 235.674] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 235.674] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 235.674] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 235.674] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 235.674] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 235.674] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 235.674] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 235.674] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 235.674] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 235.674] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 235.674] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 235.674] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 235.674] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 235.674] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 235.674] (II) modeset(0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[ 235.674] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 235.674] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 235.675] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 235.675] (II) modeset(0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[ 235.675] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 235.675] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 235.675] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 235.675] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 235.675] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 235.675] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 235.675] (II) modeset(0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[ 235.675] (II) modeset(0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 235.675] (II) modeset(0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 235.675] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 235.675] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 235.675] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 235.675] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 235.675] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 235.675] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 235.675] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 235.675] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 235.675] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 235.675] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 235.675] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 235.675] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 235.675] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 235.675] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 235.675] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 235.676] (II) modeset(0): EDID for output VGA-1
[ 235.870] (II) modeset(0): EDID for output HDMI-1
[ 235.870] (II) modeset(0): EDID for output DP-1
[ 235.872] (II) modeset(0): EDID for output HDMI-2
[ 235.873] (II) modeset(0): EDID for output HDMI-3
[ 235.873] (II) modeset(0): EDID for output DP-2
[ 235.873] (II) modeset(0): EDID for output DP-3
[ 235.873] (II) modeset(0): Output LVDS-1 connected
[ 235.873] (II) modeset(0): Output VGA-1 disconnected
[ 235.873] (II) modeset(0): Output HDMI-1 disconnected
[ 235.873] (II) modeset(0): Output DP-1 disconnected
[ 235.873] (II) modeset(0): Output HDMI-2 disconnected
[ 235.873] (II) modeset(0): Output HDMI-3 disconnected
[ 235.873] (II) modeset(0): Output DP-2 disconnected
[ 235.873] (II) modeset(0): Output DP-3 disconnected
[ 235.873] (II) modeset(0): Using exact sizes for initial modes
[ 235.873] (II) modeset(0): Output LVDS-1 using initial mode 1440x900 +0+0
[ 235.873] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 235.873] (==) modeset(0): DPI set to (96, 96)
[ 235.873] (II) Loading sub module "fb"
[ 235.873] (II) LoadModule: "fb"
[ 235.874] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 235.924] (II) Module fb: vendor="X.Org Foundation"
[ 235.924] compiled for 1.20.4, module version = 1.0.0
[ 235.924] ABI class: X.Org ANSI C Emulation, version 0.4
[ 235.924] (II) UnloadModule: "fbdev"
[ 235.924] (II) Unloading fbdev
[ 235.924] (II) UnloadSubModule: "fbdevhw"
[ 235.924] (II) Unloading fbdevhw
[ 235.924] (II) UnloadModule: "vesa"
[ 235.924] (II) Unloading vesa
[ 236.083] (==) modeset(0): Backing store enabled
[ 236.083] (==) modeset(0): Silken mouse enabled
[ 236.106] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 236.106] (==) modeset(0): DPMS enabled
[ 236.107] (II) modeset(0): [DRI2] Setup complete
[ 236.107] (II) modeset(0): [DRI2] DRI driver: i965
[ 236.107] (II) modeset(0): [DRI2] VDPAU driver: i965
[ 236.107] (II) Initializing extension Generic Event Extension
[ 236.107] (II) Initializing extension SHAPE
[ 236.107] (II) Initializing extension MIT-SHM
[ 236.108] (II) Initializing extension XInputExtension
[ 236.109] (II) Initializing extension XTEST
[ 236.109] (II) Initializing extension BIG-REQUESTS
[ 236.109] (II) Initializing extension SYNC
[ 236.109] (II) Initializing extension XKEYBOARD
[ 236.110] (II) Initializing extension XC-MISC
[ 236.110] (II) Initializing extension SECURITY
[ 236.110] (II) Initializing extension XFIXES
[ 236.111] (II) Initializing extension RENDER
[ 236.111] (II) Initializing extension RANDR
[ 236.111] (II) Initializing extension COMPOSITE
[ 236.112] (II) Initializing extension DAMAGE
[ 236.112] (II) Initializing extension MIT-SCREEN-SAVER
[ 236.112] (II) Initializing extension DOUBLE-BUFFER
[ 236.113] (II) Initializing extension RECORD
[ 236.113] (II) Initializing extension DPMS
[ 236.113] (II) Initializing extension Present
[ 236.113] (II) Initializing extension DRI3
[ 236.114] (II) Initializing extension X-Resource
[ 236.114] (II) Initializing extension XVideo
[ 236.114] (II) Initializing extension XVideo-MotionCompensation
[ 236.114] (II) Initializing extension SELinux
[ 236.114] (II) SELinux: Disabled on system
[ 236.114] (II) Initializing extension GLX
[ 236.124] (II) AIGLX: Loaded and initialized i965
[ 236.124] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 236.124] (II) Initializing extension XFree86-VidModeExtension
[ 236.125] (II) Initializing extension XFree86-DGA
[ 236.125] (II) Initializing extension XFree86-DRI
[ 236.125] (II) Initializing extension DRI2
[ 236.193] (II) modeset(0): Damage tracking initialized
[ 236.193] (II) modeset(0): Setting screen physical size to 381 x 238
[ 236.568] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 236.568] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 236.568] (II) LoadModule: "libinput"
[ 236.568] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 236.612] (II) Module libinput: vendor="X.Org Foundation"
[ 236.612] compiled for 1.20.4, module version = 0.28.2
[ 236.612] Module class: X.Org XInput Driver
[ 236.612] ABI class: X.Org XInput driver, version 24.1
[ 236.612] (II) Using input driver 'libinput' for 'Power Button'
[ 236.612] (**) Power Button: always reports core events
[ 236.612] (**) Option "Device" "/dev/input/event3"
[ 236.613] (**) Option "_source" "server/udev"
[ 236.657] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 236.657] (II) event3 - Power Button: device is a keyboard
[ 236.658] (II) event3 - Power Button: device removed
[ 236.687] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event3"
[ 236.687] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 236.687] (**) Option "xkb_model" "pc105"
[ 236.687] (**) Option "xkb_layout" "fr"
[ 236.687] (**) Option "xkb_variant" "latin9"
[ 236.744] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 236.744] (II) event3 - Power Button: device is a keyboard
[ 236.745] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 236.745] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 236.745] (II) Using input driver 'libinput' for 'Video Bus'
[ 236.745] (**) Video Bus: always reports core events
[ 236.745] (**) Option "Device" "/dev/input/event4"
[ 236.745] (**) Option "_source" "server/udev"
[ 236.747] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 236.747] (II) event4 - Video Bus: device is a keyboard
[ 236.747] (II) event4 - Video Bus: device removed
[ 236.790] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6/event4"
[ 236.790] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 236.790] (**) Option "xkb_model" "pc105"
[ 236.791] (**) Option "xkb_layout" "fr"
[ 236.791] (**) Option "xkb_variant" "latin9"
[ 236.792] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 236.792] (II) event4 - Video Bus: device is a keyboard
[ 236.793] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 236.793] (II) No input driver specified, ignoring this device.
[ 236.793] (II) This device may have been added with another device file.
[ 236.794] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 236.794] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 236.794] (II) Using input driver 'libinput' for 'Sleep Button'
[ 236.794] (**) Sleep Button: always reports core events
[ 236.794] (**) Option "Device" "/dev/input/event2"
[ 236.794] (**) Option "_source" "server/udev"
[ 236.796] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 236.796] (II) event2 - Sleep Button: device is a keyboard
[ 236.796] (II) event2 - Sleep Button: device removed
[ 236.842] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3/event2"
[ 236.842] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 236.842] (**) Option "xkb_model" "pc105"
[ 236.842] (**) Option "xkb_layout" "fr"
[ 236.842] (**) Option "xkb_variant" "latin9"
[ 236.844] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 236.844] (II) event2 - Sleep Button: device is a keyboard
[ 236.846] (II) config/udev: Adding input device HDA Intel MID Mic (/dev/input/event9)
[ 236.846] (II) No input driver specified, ignoring this device.
[ 236.846] (II) This device may have been added with another device file.
[ 236.847] (II) config/udev: Adding input device HDA Intel MID Dock Mic (/dev/input/event10)
[ 236.847] (II) No input driver specified, ignoring this device.
[ 236.847] (II) This device may have been added with another device file.
[ 236.847] (II) config/udev: Adding input device HDA Intel MID Dock Headphone (/dev/input/event11)
[ 236.848] (II) config/udev: Adding input device HDA Intel MID Headphone (/dev/input/event12)
[ 236.848] (II) No input driver specified, ignoring this device.
[ 236.848] (II) This device may have been added with another device file.
[ 236.848] (II) config/udev: Adding input device HDA Intel MID HDMI/DP,pcm=3 (/dev/input/event13)
[ 236.849] (II) No input driver specified, ignoring this device.
[ 236.849] (II) This device may have been added with another device file.
[ 236.849] (II) config/udev: Adding input device HDA Intel MID HDMI/DP,pcm=7 (/dev/input/event14)
[ 236.850] (II) config/udev: Adding input device HDA Intel MID HDMI/DP,pcm=8 (/dev/input/event15)
[ 236.850] (II) No input driver specified, ignoring this device.
[ 236.850] (II) This device may have been added with another device file.
[ 236.850] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 236.850] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 236.850] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 236.850] (**) AT Translated Set 2 keyboard: always reports core events
[ 236.850] (**) Option "Device" "/dev/input/event0"
[ 236.850] (**) Option "_source" "server/udev"
[ 236.852] (II) event0 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 236.852] (II) event0 - AT Translated Set 2 keyboard: device is a keyboard
[ 236.852] (II) event0 - AT Translated Set 2 keyboard: device removed
[ 236.882] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 236.882] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 9)
[ 236.882] (**) Option "xkb_model" "pc105"
[ 236.883] (**) Option "xkb_layout" "fr"
[ 236.883] (**) Option "xkb_variant" "latin9"
[ 236.884] (II) event0 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 236.884] (II) event0 - AT Translated Set 2 keyboard: device is a keyboard
[ 236.886] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event5)
[ 236.886] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 236.886] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 236.886] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 236.886] (**) Option "Device" "/dev/input/event5"
[ 236.886] (**) Option "_source" "server/udev"
[ 236.888] (II) event5 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 236.890] (II) event5 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 236.891] (II) event5 - SynPS/2 Synaptics TouchPad: device removed
[ 236.927] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input5/event5"
[ 236.927] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 10)
[ 236.928] (**) Option "AccelerationScheme" "none"
[ 236.928] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 236.928] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 236.928] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 236.930] (II) event5 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 236.932] (II) event5 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 236.933] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 236.933] (II) No input driver specified, ignoring this device.
[ 236.933] (II) This device may have been added with another device file.
[ 236.934] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/event6)
[ 236.934] (**) TPPS/2 IBM TrackPoint: Applying InputClass "libinput pointer catchall"
[ 236.934] (II) Using input driver 'libinput' for 'TPPS/2 IBM TrackPoint'
[ 236.934] (**) TPPS/2 IBM TrackPoint: always reports core events
[ 236.934] (**) Option "Device" "/dev/input/event6"
[ 236.934] (**) Option "_source" "server/udev"
[ 236.936] (II) event6 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[ 236.936] (II) event6 - TPPS/2 IBM TrackPoint: device is a pointer
[ 236.937] (II) event6 - TPPS/2 IBM TrackPoint: device removed
[ 236.974] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input7/event6"
[ 236.974] (II) XINPUT: Adding extended input device "TPPS/2 IBM TrackPoint" (type: MOUSE, id 11)
[ 236.975] (**) Option "AccelerationScheme" "none"
[ 236.975] (**) TPPS/2 IBM TrackPoint: (accel) selected scheme none/0
[ 236.975] (**) TPPS/2 IBM TrackPoint: (accel) acceleration factor: 2.000
[ 236.975] (**) TPPS/2 IBM TrackPoint: (accel) acceleration threshold: 4
[ 236.977] (II) event6 - TPPS/2 IBM TrackPoint: is tagged by udev as: Mouse Pointingstick
[ 236.977] (II) event6 - TPPS/2 IBM TrackPoint: device is a pointer
[ 236.979] (II) config/udev: Adding input device TPPS/2 IBM TrackPoint (/dev/input/mouse1)
[ 236.979] (II) No input driver specified, ignoring this device.
[ 236.979] (II) This device may have been added with another device file.
[ 236.980] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 236.980] (II) No input driver specified, ignoring this device.
[ 236.980] (II) This device may have been added with another device file.
[ 236.981] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event8)
[ 236.981] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[ 236.981] (II) Using input driver 'libinput' for 'ThinkPad Extra Buttons'
[ 236.981] (**) ThinkPad Extra Buttons: always reports core events
[ 236.981] (**) Option "Device" "/dev/input/event8"
[ 236.981] (**) Option "_source" "server/udev"
[ 236.982] (II) event8 - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[ 236.982] (II) event8 - ThinkPad Extra Buttons: device is a keyboard
[ 236.982] (II) event8 - ThinkPad Extra Buttons: device removed
[ 237.018] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input9/event8"
[ 237.018] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 12)
[ 237.018] (**) Option "xkb_model" "pc105"
[ 237.018] (**) Option "xkb_layout" "fr"
[ 237.018] (**) Option "xkb_variant" "latin9"
[ 237.020] (II) event8 - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[ 237.020] (II) event8 - ThinkPad Extra Buttons: device is a keyboard
[ 237.037] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 240.817] (II) modeset(0): EDID vendor "LEN", prod id 16438
[ 240.817] (II) modeset(0): Printing DDC gathered Modelines:
[ 240.817] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2044 900 903 909 930 -hsync -vsync (55.8 kHz eP)
[ 240.817] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2204 900 903 909 1035 -hsync -vsync (51.8 kHz e)
[ 241.015] (II) modeset(0): EDID vendor "LEN", prod id 16438
[ 241.015] (II) modeset(0): Printing DDC gathered Modelines:
[ 241.015] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2044 900 903 909 930 -hsync -vsync (55.8 kHz eP)
[ 241.015] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2204 900 903 909 1035 -hsync -vsync (51.8 kHz e)
[ 241.220] (II) modeset(0): EDID vendor "LEN", prod id 16438
[ 241.220] (II) modeset(0): Printing DDC gathered Modelines:
[ 241.220] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2044 900 903 909 930 -hsync -vsync (55.8 kHz eP)
[ 241.220] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2204 900 903 909 1035 -hsync -vsync (51.8 kHz e)
[ 241.419] (II) modeset(0): EDID vendor "LEN", prod id 16438
[ 241.419] (II) modeset(0): Printing DDC gathered Modelines:
[ 241.419] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2044 900 903 909 930 -hsync -vsync (55.8 kHz eP)
[ 241.419] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2204 900 903 909 1035 -hsync -vsync (51.8 kHz e)
[ 243.241] (II) modeset(0): EDID vendor "LEN", prod id 16438
[ 243.241] (II) modeset(0): Printing DDC gathered Modelines:
[ 243.241] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2044 900 903 909 930 -hsync -vsync (55.8 kHz eP)
[ 243.241] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2204 900 903 909 1035 -hsync -vsync (51.8 kHz e)
[ 247.037] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 249.121] (II) modeset(0): EDID vendor "LEN", prod id 16438
[ 249.122] (II) modeset(0): Printing DDC gathered Modelines:
[ 249.122] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2044 900 903 909 930 -hsync -vsync (55.8 kHz eP)
[ 249.122] (II) modeset(0): Modeline "1440x900"x0.0 114.06 1440 1488 1520 2204 900 903 909 1035 -hsync -vsync (51.8 kHz e)
[ 257.041] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 267.049] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 277.053] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 287.063] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 297.064] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 307.065] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 317.075] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 318.605] (II) Axis 0 value 1152 is outside expected range [1251, 6108]
See https://wayland.freedesktop.org/libinput/doc/1.12.6/absolute_coordinate_ranges.html for details
[ 327.075] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 337.076] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 347.077] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 357.078] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 367.078] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 377.079] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 387.080] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 397.080] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 407.080] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 417.082] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 427.084] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 437.084] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 447.085] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 457.086] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 467.086] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 477.087] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 487.088] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 497.091] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 507.094] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 517.095] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 527.101] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 537.102] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 547.102] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 557.105] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 567.106] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 577.108] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 587.114] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 597.115] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 607.115] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 617.118] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 627.118] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 637.118] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 647.119] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 657.120] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 667.120] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 677.121] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 687.121] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 697.121] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 707.122] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 717.123] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 727.124] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 737.124] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 747.124] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 757.126] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 767.127] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 777.127] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 787.127] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 797.128] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 807.128] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 817.128] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 827.128] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 837.128] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 847.129] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 857.130] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 867.134] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 877.137] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 887.140] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 897.141] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 907.142] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 917.142] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 927.142] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 937.145] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 947.149] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 957.150] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 967.152] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 977.153] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 987.159] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 997.163] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 1007.167] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 1017.168] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 1027.168] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 1037.174] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 1047.184] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 1057.184] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
[ 1057.608] (II) event3 - Power Button: device removed
[ 1057.643] (II) event4 - Video Bus: device removed
[ 1057.678] (II) event2 - Sleep Button: device removed
[ 1057.710] (II) event0 - AT Translated Set 2 keyboard: device removed
[ 1057.754] (II) event5 - SynPS/2 Synaptics TouchPad: device removed
[ 1057.806] (II) event6 - TPPS/2 IBM TrackPoint: device removed
[ 1057.846] (II) event8 - ThinkPad Extra Buttons: device removed
[ 1057.892] (II) UnloadModule: "libinput"
[ 1057.964] (II) Server terminated successfully (0). Closing log file.Merci de votre aide!
