nftables : Could not process rule: Address family not supported by protocol Le sujet est résolu
idmila
Après avoir installé nftables, le service ne démarre pas et le simple flush d'une ruleset sort en erreur.
J'ai beau chercher, je sèche, si vous avez une petite idée...
root@soekris:/var/log# cat /etc/nftables.conf
#!/usr/sbin/nft -f
flush ruleset
table inet filter {
        chain input {
                type filter hook input priority 0;
                # accept any localhost traffic
                iif lo accept
                # accept traffic originated from us
                ct state established,related accept
                # activate the following line to accept common local services
                #tcp dport { 22, 80, 443 } ct state new accept
                # count and drop any other traffic
                counter drop
root@soekris:/var/log# systemctl status nftables.service
● nftables.service - nftables
   Loaded: loaded (/lib/systemd/system/nftables.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2021-03-17 08:02:57 CET; 8s ago
     Docs: man:nft(8)
           http://wiki.nftables.org
  Process: 7684 ExecStart=/usr/sbin/nft -f /etc/nftables.conf (code=exited, status=1/FAILURE)
 Main PID: 7684 (code=exited, status=1/FAILURE)
Mar 17 08:02:57 soekris.home.moua7.com systemd[1]: Starting nftables...
Mar 17 08:02:57 soekris.home.moua7.com nft[7684]: /etc/nftables.conf:3:1-14: Error: Could not process rule: Address family not supported by protocol
Mar 17 08:02:57 soekris.home.moua7.com nft[7684]: flush ruleset
Mar 17 08:02:57 soekris.home.moua7.com nft[7684]: ^^^^^^^^^^^^^^
Mar 17 08:02:57 soekris.home.moua7.com systemd[1]: nftables.service: Main process exited, code=exited, status=1/FAILURE
Mar 17 08:02:57 soekris.home.moua7.com systemd[1]: nftables.service: Failed with result 'exit-code'.
Mar 17 08:02:57 soekris.home.moua7.com systemd[1]: Failed to start nftables.
root@soekris:/var/log# nft flush ruleset
flush ruleset
root@soekris:/var/log# lsmod | grep ^nf
nft_counter            12475  0
nf_conntrack_ipv6      17453  0
nf_defrag_ipv6         20950  1 nf_conntrack_ipv6
nf_conntrack_ipv4      18040  0
nf_defrag_ipv4         12443  1 nf_conntrack_ipv4
nft_ct                 12674  0
nf_conntrack           73428  3 nft_ct,nf_conntrack_ipv4,nf_conntrack_ipv6
nft_meta               12613  0
nft_hash               16824  0
nft_rbtree             12679  0
nf_tables_inet         12491  0
nf_tables_ipv6         12518  1 nf_tables_inet
nf_tables_bridge       12494  0
nf_tables_ipv4         12557  2 nf_tables_inet
nf_tables              45218  9 nf_tables_inet,nf_tables_ipv4,nf_tables_ipv6,nft_ct,nf_tables_bridge,nft_hash,nft_meta,nft_rbtree,nft_counter
nfnetlink              12853  1 nf_tables
root@soekris:/var/log# ifconfig -a
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.42  netmask 255.255.255.0  broadcast 192.168.1.255
        ether 00:00:24:c8:b3:9c  txqueuelen 0  (Ethernet)
        RX packets 2876152  bytes 367498958 (350.4 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 861934  bytes 156425001 (149.1 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        ether 00:00:24:c8:b3:9c  txqueuelen 1000  (Ethernet)
        RX packets 102489882  bytes 142063090989 (132.3 GiB)
        TX packets 43316588  bytes 9266728364 (8.6 GiB)
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:00:24:c8:b3:9d  txqueuelen 1000  (Ethernet)
        RX packets 42813860  bytes 9173443875 (8.5 GiB)
        TX packets 101787337  bytes 141932905494 (132.1 GiB)
root@soekris:/var/log# cat /etc/network/interfaces
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
iface eth0 inet manual
iface eth1 inet manual
auto br0
iface br0 inet static
        bridge_ports eth0 eth1
        address 192.168.1.42
        gateway 192.168.1.1
Bonjour et Bienvenue :006:
Je suis presque complètement débutant et dans ma courte expérience avec nftables
je rencontre aussi ce genre de problèmes d'erreurs de syntaxe que je ne comprends pas :017:
idmila a écrit : 17 mars 2021, 08:10
flush ruleset
semblerait (conditionnel) indiquer qu'il y a quelque(s) caractère(s) invisible(s) en fin de ligne puisqu'il rajoute quelque(s) " ^ " supplémentaire(s)
C'est peut-être une histoire d'encodage (utf-8) ou de choix de caractères de fin de ligne dans la config de ton éditeur de texte.
Geany p.ex. propose dans les préférences le choix du type de caractère de fin de ligne (Linux/Windows/Mac) ; j'utilise "Linux"
Jusqu'à présent je n'ai pas eu d'erreur sur cette ligne flush ruleset
J'ai fait un test en ajoutant un asterisk " * " comme ça : flush ruleset*
là nft indique clairement le caractère inattendu qui pose problème.
donc dans ton cas c'est la ligne suivante qui doit poser problème.
Regarde cet exemple : Nftables-Examples - Workstation - Gentoo Wiki
ça va peut-être te permettre de débloquer ton affaire.
idmila
Merci de la réponse. J'aurai bien aimé que ce soit une erreur de syntaxe mais ce n'est malheureusement pas le cas puisque la commande de flush tapée sur le terminal renvoi la même erreur.
flush ruleset
Par ailleurs mon éditeur est Emacs :smile:
Effectivement, c'est bizarre ... :017: ,
J'ai testé ton script et ce la ne renvoie pas d'erreur.
j'ai cru d'abord que le problème venait de :
qui aurait du être :
ct state {established,related} accept
mais l'un comme l'autre n'affiche pas d'erreur de syntaxe.
Désolé, je n'ai pas d'autre idée, peut-être purger et réinstaller nftables
idmila
Mon kernel était trop ancien 3.16.81-1. Après un upgrade en 4.19 le problème est résolu.
idmila
Sujet clos.
idmila a écrit : 21 mars 2021, 18:14 Mon kernel était trop ancien 3.16.81-1. Après un upgrade en 4.19 le problème est résolu.
Oui, en général ça fonctionne mieux quand c'est à jour,
... mais pas toujours ! :dirol:
:006:
C'est plus l'époque, mais ça revient tous les ans...
… mais ce qui est sûr, c'est que là, l'esprit y est.
https://www.youtube.com/watch?v=scnqePfFpa8
https://www.youtube.com/watch?v=AySBPCkGyyY
