python3 : script d'affichage des logs d'apache 2
arcturien
bonjour,
je ne sais pas si c'est la bonne section pour poster le script ci-dessous. Libre aux admins de le déplacer...
Comme son nom l'indique, le script ne fait rien d'autre que de mettre en forme les logs d'apache2.
Il lit dans /var/log/apache2/access.log et acces.log.1 .
exemple de sortie :
192.xxx.xxx.xxx - 31 Mar 2022 04:50 - 400                        BAD_REQUEST  -     623 - GET / HTTP/1.0
221.xxx.xxx.xxx - 31 Mar 2022 05:09 - 301                  MOVED_PERMANENTLY  -       0 - POST /cgi-bin/ViewLog.asp HTTP/1.1
221.xxx.xxx.xxx - 31 Mar 2022 05:09 - 400                        BAD_REQUEST  -    1087 - m+-rf+NW_BBBarm7%3b%23&remoteSubmit=Save
121.xxx.xxx.xxx - 31 Mar 2022 05:22 - 301                  MOVED_PERMANENTLY  -       0 - POST /cgi-bin/ViewLog.asp HTTP/1.1
121.xxx.xxx.xxx - 31 Mar 2022 05:22 - 400                        BAD_REQUEST  -    1087 - ame.arm7;rm+-rf+BinName.arm7%3b%23&remoteSubmit=Save
le script :
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# affichage logs apache
import string, re, csv
r_ip = '(\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3})'
r_date = '\[(\d{1,2}\/\D{1,3}\/\d{1,4})\:(\d{1,2}\:\d{1,3})\:(.*)\]'
r_page = ' \"(.*)\" (\d*) (\d*)'
def tableau_codes():
	codes = {	"103":"RESPONSE_CODES",
						"100":"CONTINUE",
						"101":"SWITCHING_PROTOCOLS",
						"102":"PROCESSING",
						"200":"OK",
						"201":"CREATED",
						"202":"ACCEPTED",
						"203":"NON_AUTHORITATIVE",
						"204":"NO_CONTENT",
						"205":"RESET_CONTENT",
						"206":"PARTIAL_CONTENT",
						"207":"MULTI_STATUS",
						"208":"ALREADY_REPORTED",
						"226":"IM_USED",
						"300":"MULTIPLE_CHOICES",
						"301":"MOVED_PERMANENTLY",
						"302":"MOVED_TEMPORARILY",
						"303":"SEE_OTHER",
						"304":"NOT_MODIFIED",
						"305":"USE_PROXY",
						"307":"TEMPORARY_REDIRECT",
						"308":"PERMANENT_REDIRECT",
						"400":"BAD_REQUEST",
						"401":"UNAUTHORIZED",
						"402":"PAYMENT_REQUIRED",
						"403":"FORBIDDEN",
						"404":"NOT_FOUND",
						"405":"METHOD_NOT_ALLOWED",
						"406":"NOT_ACCEPTABLE",
						"407":"PROXY_AUTHENTICATION_REQUIRED",
						"408":"REQUEST_TIME_OUT",
						"409":"CONFLICT",
						"410":"GONE",
						"411":"LENGTH_REQUIRED",
						"412":"PRECONDITION_FAILED",
						"413":"REQUEST_ENTITY_TOO_LARGE",
						"414":"REQUEST_URI_TOO_LARGE",
						"415":"UNSUPPORTED_MEDIA_TYPE",
						"416":"RANGE_NOT_SATISFIABLE",
						"417":"EXPECTATION_FAILED",
						"418":"IM_A_TEAPOT",
						"421":"MISDIRECTED_REQUEST",
						"422":"UNPROCESSABLE_ENTITY",
						"423":"LOCKED",
						"424":"FAILED_DEPENDENCY",
						"425":"TOO_EARLY",
						"426":"UPGRADE_REQUIRED",
						"428":"PRECONDITION_REQUIRED",
						"429":"TOO_MANY_REQUESTS",
						"431":"REQUEST_HEADER_FIELDS_TOO_LARGE",
						"451":"UNAVAILABLE_FOR_LEGAL_REASONS",
						"500":"INTERNAL_SERVER_ERROR",
						"501":"NOT_IMPLEMENTED",
						"502":"BAD_GATEWAY",
						"503":"SERVICE_UNAVAILABLE",
						"504":"GATEWAY_TIME_OUT",
						"505":"VERSION_NOT_SUPPORTED",
						"506":"VARIANT_ALSO_VARIES",
						"507":"INSUFFICIENT_STORAGE",
						"508":"LOOP_DETECTED",
						"510":"NOT_EXTENDED",
						"511":"NETWORK_AUTHENTICATION_REQUIRED"
	return codes
def lit_logs(nom):
	with open(nom, 'r') as f:
		l = f.readlines()
	f.close()
	return l
def zones(ligne):
	if len(ligne) > 0:
		for i in range(0,len(ligne)):
			m = re.search(r,ligne[i])
			if m:
				ip = m.group(1)
				date = m.group(3).replace('/', ' ')
				heure = m.group(4)
				page = m.group(6).replace('%20',' ')
				num_code = m.group(7)
				taille = m.group(8)
				print(ip.rjust(15), '-', date.rjust(11), heure.rjust(5),'-', num_code.rjust(3),' ',codes[str(num_code)].rjust(32),' - ', taille.rjust(6),'-', page[:80])
	else:
		print("Vide.")
r = re.compile(r_ip+'(.*)'+r_date+r_page)
codes = tableau_codes()
zones(lit_logs("/var/log/apache2/access.log.1"))
print ("-----------------------------------------------------------------")
zones(lit_logs("/var/log/apache2/access.log"))
La section est parfaite, et ton script super utile.
Merci acturien!
