vulnérabilité découverte dans sudo
Règles d'utilisation de forum. Annonces importantes.
A flaw in exists in sudo’s -e option (aka sudoedit) that allows a malicious user with sudoedit privileges to edit arbitrary files.
Sudo versions 1.8.0 through 1.9.12p1 inclusive are affected. Versions of sudo prior to 1.8.0 construct the argument vector differently and are not affected.
contournement
It is possible to prevent a user-specified editor from being used by sudoedit by adding the following line to the sudoers file.
Defaults!sudoedit env_delete+="SUDO_EDITOR VISUAL EDITOR"
https://www.sudo.ws/security/advisories/sudoedit_any/
