Emplacement logs mails Le sujet est résolu
Serveur Debian 12 à jour (Facile pendant le freeze...)
Serveur mail en place (Postfix/Dovecot et tout le bazar)
J'ai eu la surprise hier soir de trouver les logs concernant le serveur mail dans syslog et non dans mail.*
Dernier log enregistré dans /var/log/mail.info
Mar 22 07:39:35 mail dovecot: imap-login: Aborted login (no auth attempts in 0 secs): user=<>, rip=2001:41d0:203:1467::1200, lip=2a01:4f8:191:64a1::2, TLS, session=<ar1nbHf3rJ0gAUHQAgMUZwAAAAAAABIA>
Paquets installés au même moment:
Start-Date: 2023-03-22  07:39:19
Commandline: apt install quota quotatool rake rar readline-common redis-server redis-tools reportbug resolvconf rkhunter rspamd rsync rsyslog ruby-minitest ruby-net-telnet ruby-power-assert ruby-rack ruby-rubygems ruby-test-unit sed sensible-utils shared-mime-info
Il y a évidemment rsyslog dans le lot.
# apt policy rsyslog
rsyslog:
  Installé : 8.2302.0-1
  Candidat : 8.2302.0-1
 Table de version :
 *** 8.2302.0-1 500
        500 https://deb.debian.org/debian bookworm/main amd64 Packages
        100 /var/lib/dpkg/status
     8.2102.0-2+deb11u1 500
        500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
        500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
Pourtant la configuration à l'air OK de mon point de vue # cat /etc/rsyslog.conf :017:
# /etc/rsyslog.conf configuration file for rsyslog
# For more information install rsyslog-doc and see
# /usr/share/doc/rsyslog-doc/html/configuration/index.html
#### MODULES ####
module(load="imuxsock") # provides support for local system logging
module(load="imklog")   # provides kernel logging support
#module(load="immark")  # provides --MARK-- message capability
# provides UDP syslog reception
#module(load="imudp")
#input(type="imudp" port="514")
# provides TCP syslog reception
#module(load="imtcp")
#input(type="imtcp" port="514")
#### GLOBAL DIRECTIVES ####
# Set the default permissions for all log files.
$FileOwner root
$FileGroup adm
$FileCreateMode 0640
$DirCreateMode 0755
$Umask 0022
# Where to place spool and state files
$WorkDirectory /var/spool/rsyslog
# Include all config files in /etc/rsyslog.d/
$IncludeConfig /etc/rsyslog.d/*.conf
#### RULES ####
# Log anything besides private authentication messages to a single log file
*.*;auth,authpriv.none		-/var/log/syslog
# Log commonly used facilities to their own log file
auth,authpriv.*			/var/log/auth.log
cron.*				-/var/log/cron.log
kern.*				-/var/log/kern.log
mail.*				-/var/log/mail.log
user.*				-/var/log/user.log
# Emergencies are sent to everybody logged in.
*.emerg				:omusrmsg:*
Comment revenir à la configuration "normale" (Logs du serveur mail dans mail.*) ?
J'aurais pu chercher d'avantage, mais vous avez peut-être la solution à portée de la main ? :003:
Re,
J'ai trouvé la solution:
# Logging for the mail system.  Split it up so that
# it is easy to write scripts to parse these files.
mail.info                       -/var/log/mail.info
mail.warn                       -/var/log/mail.warn
mail.err                        /var/log/mail.err
Ces trois lignes sont présentes sur un serveur Bullseye (et pas dans Bookworm)
Rsyslog 8.2102.0-2+deb11u1 vs Rsyslog 8.2302.0-1
La conf par défaut à du changer, car d'un côté comme de l'autre (De mémoire) je n'ai jamais touché à la conf de Rsyslog
OK, Merci c'est noté
:good:
dezix a écrit : 20 avr. 2023, 12:43 OK, Merci c'est noté
:good:
You're welcome Dear ! :wink:
lol a écrit : 20 avr. 2023, 12:21 La conf par défaut à du changer, car d'un côté comme de l'autre (De mémoire) je n'ai jamais touché à la conf de Rsyslog
Je confirme:
Les 3 lignes suivantes sont présentes dans le fichier de conf du package Rsyslog 8.2102.0-2+deb11u1 (Et pas dans le package Rsyslog 8.2302.0-1)
Ha ben c'est bien dommage. A une époque j'avais un soucis, et le fichier email.log enflait démesurément. Heureusement que je surveillais régulièrement /var/log, sinon je me serais retrouver à court d'espace disque!
J'ai rapidement identifié le coupable et réglé le pb.
Mais maintenant si c'est noyé dans un fichier de log général, ce sera plus compliqué à traiter manuellement.
Ca doit étre une modif pour faciliter le traitement automatique des logs.
piratebab a écrit : 20 avr. 2023, 15:54 Ca doit étre une modif pour faciliter le traitement automatique des logs.
Possible oui. Bien que ce ce choix ne me sied pas ! :wink:
Mais c'est vrai que de plus en plus de logiciels de sécurités scrutent les logs et c'est plus simple si c'est centralisé et normalisé.
