Jdownloader erreurs java...
DavidGilb
Bonjour, J'ai installé Jdownloader sur ma Debian 12. Désinstallé car il y avait un plantage.
Depuis la ré-install j'obtiens ce message d'erreur au lancement :
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at org.jdownloader.updatev2.JDClassLoaderLauncher.main(JDClassLoaderLauncher.java:156)
at org.jdownloader.update.launcher.JDLauncher.main(JDLauncher.java:8)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:84)
at com.install4j.runtime.launcher.UnixLauncher.start(UnixLauncher.java:69)
at install4j.org.jdownloader.update.launcher.JDLauncher.main(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at org.jdownloader.updatev2.JDClassLoaderLauncher.main(JDClassLoaderLauncher.java:152)
... 8 more
Caused by: org.appwork.storage.StorageException: Can not write to /opt/jd2/cfg/org.jdownloader.update.lastchance.LastChanceConfig.json
at org.appwork.storage.JSonStorage.saveTo(JSonStorage.java:476)
at org.appwork.storage.JsonKeyValueStorage$1.run(JsonKeyValueStorage.java:591)
at org.appwork.storage.config.handler.StorageHandler.enqueueWrite(StorageHandler.java:232)
at org.appwork.storage.JsonKeyValueStorage.save(JsonKeyValueStorage.java:594)
at org.appwork.storage.config.handler.StorageHandler.write(StorageHandler.java:1050)
at org.jdownloader.update.lastchance.LastChanceManager.run(LastChanceManager.java:137)
at org.jdownloader.update.launcher.SecondLevelLauncher.runMain(SecondLevelLauncher.java:248)
at org.jdownloader.update.launcher.JDLauncherViaClassLoader.main(JDLauncherViaClassLoader.java:18)
... 13 more
Caused by: java.io.IOException: failed to create parent for /opt/jd2/cfg/org.jdownloader.update.lastchance.LastChanceConfig.json
at org.appwork.utils.IO$3.execute(IO.java:763)
at org.appwork.utils.NonInterruptibleRunnableException.run(NonInterruptibleRunnableException.java:39)
at org.appwork.utils.NonInterruptibleRunnableException.run(NonInterruptibleRunnableException.java:36)
at org.appwork.utils.NonInterruptibleThread$2.call(NonInterruptibleThread.java:115)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:833)
Suppressed: java.lang.Exception
at org.appwork.utils.NonInterruptibleRunnable.startAndWait(NonInterruptibleRunnable.java:40)
at org.appwork.utils.IO.secureWrite(IO.java:791)
at org.appwork.storage.JSonStorage.saveTo(JSonStorage.java:474)
J'imagine qu'il me faut réparer java mais je ne sais pas coment m'y prendre.
Quelqu'un pourrait m'aider ?
Merci :)
Salut!
DavidGilb a écrit : 28 oct. 2023, 15:27 J'ai installé Jdownloader sur ma Debian 12
Racontes-en un peu plus sur comment tu as installé cette application , c'est quoi ? un fichier *.jar
Recherche quelle version de l'environnement d'exécution Java est requise,...
...enfin ce genre d'info.
Que renvoie :
$ apt list --installed *jdk*
DavidGilb
Bonsoir,
Non c'était un fichier .sh.
Puis j'ai dû installer java car jdownloader fonctionne avec.
En train de lister... Fait
default-jdk-headless/stable,now 2:1.17-74 amd64  [installé, automatique]
default-jdk/stable,now 2:1.17-74 amd64  [installé]
openjdk-17-jdk-headless/stable,now 17.0.8+7-1~deb12u1 amd64  [installé, automatique]
openjdk-17-jdk/stable,now 17.0.8+7-1~deb12u1 amd64  [installé, automatique]
openjdk-17-jre-headless/stable,now 17.0.8+7-1~deb12u1 amd64  [installé, automatique]
openjdk-17-jre/stable,now 17.0.8+7-1~deb12u1 amd64  [installé, automatique]
Au cas où....
tu pourrais essayer d'utiliser Uget qui se trouve dans les dépôts,
c'est certain à 99.9% qu'il va fonctionner sur ton installation ;
pour les fonctionnalités... je ne sais pas, je n'ai plus utilisé autre chose que FF et wget depuis trop longtemps.
DavidGilb
J'ai essayé Uget mais Jdownloader a un petit truc en plus bien pratique.
On copie/colle le lien html d'une page et il recherche toutes les vidéos présentes tout seul...
Très pratique !!
Et je n'ai pas trouvé d'équivalent.
DavidGilb a écrit : 28 oct. 2023, 19:48 On copie/colle le lien html d'une page et il recherche toutes les vidéos présentes tout seul...
Très pratique !!
Tu veux dire l'URL de la page qui contient des liens vers les vidéo,
je crois que la commande yt-dlp fait cela aussi.
Pour ton appli en Java j'ai vu (qqpart???) l'install de la version 18 de openjdk (pas dispo sous Debian), pour la 19 il te faudrait l'épingler une version de sid
Voir les versions => https://packages.debian.org/search?suit ... ds=openjdk
DavidGilb
dezix a écrit : 28 oct. 2023, 20:11 je crois que la commande yt-dlp fait cela aussi.
Top ! Cette commande est exactement ce dont j'ai besoin.
Merci bcp !! :good:
Un lien pour l'explication complète de son utilisation :
https://www.malekal.com/yt-dlp-telechar ... #Sur_Linux
Y-a pas de quoi :003: ,
merci pour le partage du lien.
:006:
Il est aussi (parfois) intéressant de ne télécharger que la piste audio avec p.ex :
yt-dlp -f 140 <url_video>
ou
yt-dlp -f bestaudio <url_video>
man yt-dlp donne toutes les options, et elles sont nombreuses.
Les pistes audio sont parfois dans des formats exotiques. konverter les remet dans des formats plus courants.
