Serveur Mariadb ne démarre plus après un process InnoDB Le sujet est résolu
bdedardel
sudo  journalctl -u mariadb
06:02:29 <host> systemd[1]: Stopping mariadb.service - MariaDB 10.11.6 database server...
06:02:29 <host> mariadbd[785]: 6:02:29 0 [Note] /usr/sbin/mariadbd (initiated by: unknown): Normal shutdown
06:02:29 <host> mariadbd[785]: 6:02:29 0 [Note] InnoDB: FTS optimize thread exiting.
06:02:29 <host> mariadbd[785]: 6:02:29 0 [Note] InnoDB: Starting shutdown...
06:02:29 <host> mariadbd[785]: 6:02:29 0 [Note] InnoDB: Dumping buffer pool(s) to /home/mysql/ib_buffer_pool
06:02:29 <host> mariadbd[785]: 6:02:29 0 [Note] InnoDB: Buffer pool(s) dump completed at 250316  6:02:29
06:02:30 <host> mariadbd[785]: 6:02:30 0 [Note] InnoDB: Removed temporary tablespace data file: "./ibtmp1"
06:02:30 <host> mariadbd[785]: 6:02:30 0 [Note] InnoDB: Shutdown completed; log sequence number 153575263; transaction id 870235
06:02:30 <host> mariadbd[785]: 6:02:30 0 [Note] /usr/sbin/mariadbd: Shutdown complete
06:02:30 <host> systemd[1]: mariadb.service: Deactivated successfully.
06:02:30 <host> systemd[1]: Stopped mariadb.service - MariaDB 10.11.6 database server.
06:02:30 <host> systemd[1]: mariadb.service: Consumed 11min 27.921s CPU time.
06:02:47 <host> systemd[1]: Starting mariadb.service - MariaDB 10.11.11 database server...
06:02:47 <host> mariadbd[4053495]: 6:02:47 0 [Warning] Can't create test file '/home/mysql/<host>.lower-test' (Errcode: 2 "No such file or directory")
06:02:47 <host> mariadbd[4053495]: [96B blob data]
06:02:47 <host> mariadbd[4053495]: 6:02:47 0 [ERROR] Aborting
A priori, l'erreur provient de : Can't create test file '/home/mysql/<host>.lower-test' (Errcode: 2 "No such file or directory")
A noter :
- j'ai installé les datas dans /home/mysql (comme décrit ici: https://medium.com/@benjamin.dedardel/i ... b45b273b63)
$ ls -la  /home/mysql/
drwxr-xr-x 11 mysql mysql      4096 Mar 18 11:52 .
drwxr-xr-x  7 root  root       4096 Sep 26 17:00 ..
-rw-rw----  1 mysql mysql    450560 Mar 16 06:02 aria_log.00000001
-rw-rw----  1 mysql mysql        52 Mar 16 06:02 aria_log_control
drwx------  2 mysql mysql      4096 Sep 19 07:08 <user>@18db
drwx------  2 mysql mysql     12288 Sep 18 17:54 <user>@21db
drwx------  2 mysql mysql      4096 Sep 19 01:52 <user>@32db
drwx------  2 mysql mysql      4096 Sep 19 09:30 <user>@02db
-rw-r--r--  1 mysql mysql         0 Sep 17 17:13 debian-10.11.flag
drwx------  2 mysql mysql      4096 Oct  9 06:07 admindb
-rw-rw----  1 mysql mysql      8543 Mar 16 06:02 ib_buffer_pool
-rw-rw----  1 mysql mysql 100663296 Mar 16 06:02 ib_logfile0
-rw-rw----  1 mysql mysql  79691776 Mar 16 06:02 ibdata1
-rw-rw----  1 mysql mysql         0 Sep 17 17:13 multi-master.info
drwx------  2 mysql mysql      4096 Sep 17 17:13 mysql
-rw-r--r--  1 mysql mysql        15 Sep 17 17:13 mysql_upgrade_info
drwxr-xr-x  2 mysql mysql      4096 Mar 18 11:52 <host>.lower-test
drwx------  2 mysql mysql      4096 Sep 17 17:13 performance_schema
drwx------  2 mysql mysql     12288 Sep 17 17:13 sys
Comme évoqué ici, viewtopic.php?t=370, j'ai 'supprimé' tous les fichiers du Mar 16 06:02
sudo mv /home/mysql/ib_logfile0 /home/mysql/ib_logfile0.bak
sudo mv /home/mysql/aria_log.00000001 /home/mysql/aria_log.00000001.bak
sudo mv /home/mysql/aria_log_control /home/mysql/aria_log_control.bak
sudo mv /home/mysql/ib_buffer_pool /home/mysql/ib_buffer_pool.bak
sudo mv /home/mysql/ibdata1 /home/mysql/ibdata1.bak
Est-ce que quelqu'un a une idée ??? Je sèche !
bdedardel
$ cat /etc/debian_version
12.10
bdedardel
Résolu :
sudo vi /etc/systemd/system/multi-user.target.wants/mariadb.service
ProtectHome=true => false (je ne sais pas pourquoi ça avait changé !)
sudo systemctl daemon-reload
sudo service mariadb start
Merci d'avoir donné la solution
bdedardel
Mon erreur :
You should avoid editing the MariaDB service file directly in
/etc/systemd/system/multi-user.target.wants/. Instead, create a
systemd override file using the `systemctl edit` command.
