partition /usr énorme !!!
toto69
Bonsoir,
Je n'arrive pas à libérer de l'espace sur ma partiiton racine : /usr et énorme !!
$ df -h
Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
udev               1,9G       0  1,9G   0% /dev
tmpfs              392M     37M  355M  10% /run
/dev/sda1           28G     28G     0 100% /
tmpfs              2,0G       0  2,0G   0% /dev/shm
tmpfs              5,0M       0  5,0M   0% /run/lock
tmpfs              1,0M       0  1,0M   0% /run/credentials/systemd-journald.service
tmpfs              1,0M       0  1,0M   0% /run/credentials/systemd-udev-load-credentials.service
tmpfs              1,0M       0  1,0M   0% /run/credentials/systemd-tmpfiles-setup-dev-early.service
tmpfs              1,0M       0  1,0M   0% /run/credentials/systemd-sysctl.service
tmpfs              1,0M       0  1,0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
/dev/sda6           45G    2,6G   40G   6% /home
tmpfs              2,0G    796K  2,0G   1% /tmp
tmpfs              1,0M       0  1,0M   0% /run/credentials/systemd-tmpfiles-setup.service
tmpfs              1,0M       0  1,0M   0% /run/credentials/getty@tty1.service
tmpfs              392M    124K  392M   1% /run/user/1000
$ sudo du -x -h --max-depth=1 /
16K     /media
181M    /boot
4,0K    /mnt
16G     /usr
1,3G    /var
4,0K    /snap
12M     /root
4,0K    /opt
20M     /etc
16K     /lost+found
4,0K    /.cache
8,0K    /srv
17G     /
sudo du -x -h --max-depth=1 /usr/lib
8,0K    /usr/lib/rsyslog
2,8M    /usr/lib/nmap
28K     /usr/lib/dkms
48K     /usr/lib/policykit-1-gnome
59M     /usr/lib/python3.11
4,0K    /usr/lib/gnupg2
24K     /usr/lib/ssl
431M    /usr/lib/firmware
4,0K    /usr/lib/sasl2
32K     /usr/lib/lsb
23M     /usr/lib/udev
4,0K    /usr/lib/policykit-1
194M    /usr/lib/mono
24K     /usr/lib/xserver-xorg-video-intel
226M    /usr/lib/firefox-esr
136K    /usr/lib/cryptsetup
748K    /usr/lib/android-sdk
68K     /usr/lib/mime
32K     /usr/lib/kernel
436K    /usr/lib/mc
12K     /usr/lib/unity-settings-daemon-1.0
20K     /usr/lib/os-prober
28K     /usr/lib/linux-boot-probes
36K     /usr/lib/grub-legacy
32K     /usr/lib/valgrind
208K    /usr/lib/blt2.5
1,2G    /usr/lib/python3
16K     /usr/lib/modprobe.d
4,2M    /usr/lib/discover
130M    /usr/lib/postgresql
68K     /usr/lib/pcrlock.d
2,9G    /usr/lib/x86_64-linux-gnu
376K    /usr/lib/pppd
1,2M    /usr/lib/mysql
40K     /usr/lib/vlock
48M     /usr/lib/snapd
32K     /usr/lib/kali_tweaks
24M     /usr/lib/git-core
8,0K    /usr/lib/environment.d
80K     /usr/lib/pkgconfig
484K    /usr/lib/hashcat-utils
16K     /usr/lib/mozilla
20K     /usr/lib/cryptsetup-nuke-password
4,0K    /usr/lib/cgi-bin
6,7M    /usr/lib/xorg
57M     /usr/lib/gophish
20K     /usr/lib/pm-utils
8,2M    /usr/lib/file
24K     /usr/lib/debug
16K     /usr/lib/ifupdown
12K     /usr/lib/openvpn
8,0K    /usr/lib/cups
4,0K    /usr/lib/java-wrappers
60K     /usr/lib/tasksel
52K     /usr/lib/NetworkManager
4,0K    /usr/lib/compat-ld
3,0M    /usr/lib/linux
12K     /usr/lib/runit-helper
36K     /usr/lib/dpkg
68K     /usr/lib/emacsen-common
12K     /usr/lib/console-setup
572K    /usr/lib/ettercap
3,2M    /usr/lib/pulse-16.1+dfsg1
40K     /usr/lib/sysusers.d
9,7M    /usr/lib/php
484M    /usr/lib/jvm
96K     /usr/lib/mono-source-libs
28K     /usr/lib/sysctl.d
4,0K    /usr/lib/exim4
3,6M    /usr/lib/qt6
160K    /usr/lib/tmpfiles.d
620M    /usr/lib/modules
407M    /usr/lib/llvm-13
16K     /usr/lib/init
4,0K    /usr/lib/gvfs
144K    /usr/lib/polkit-1
20K     /usr/lib/cli
3,5M    /usr/lib/qt5
8,0K    /usr/lib/groff
4,0K    /usr/lib/udisks2
56K     /usr/lib/dbus-1.0
4,0K    /usr/lib/bfd-plugins
206M    /usr/lib/oracle
16K     /usr/lib/gnome-settings-daemon-3.0
2,4M    /usr/lib/openssh
4,0K    /usr/lib/gold-ld
404K    /usr/lib/passing-the-hash
56M     /usr/lib/python3.12
2,0M    /usr/lib/aspell
6,8M    /usr/lib/7zip
4,0K    /usr/lib/cmake
1,2M    /usr/lib/apt
9,7M    /usr/lib/apache2
27M     /usr/lib/python3.10
68K     /usr/lib/binfmt-support
12K     /usr/lib/firewalld
196K    /usr/lib/speech-dispatcher-modules
24K     /usr/lib/tcltk
3,3M    /usr/lib/locale
272K    /usr/lib/pcsc
2,5M    /usr/lib/ipsec
963M    /usr/lib/gcc
42M     /usr/lib/ruby
23M     /usr/lib/python2.7
316K    /usr/lib/man-db
652K    /usr/lib/wine
268K    /usr/lib/python3.13
4,0K    /usr/lib/galera
704K    /usr/lib/gnupg
28K     /usr/lib/binfmt.d
544K    /usr/lib/klibc
75M     /usr/lib/john
3,5M    /usr/lib/grub
24K     /usr/lib/apparmor
12K     /usr/lib/pam.d
84K     /usr/lib/dracut
521M    /usr/lib/llvm-16
8,0K    /usr/lib/ispell
28K     /usr/lib/clang
320K    /usr/lib/X11
431M    /usr/lib/llvm-14
16K     /usr/lib/hdparm
6,8M    /usr/lib/systemd
15M     /usr/lib/i386-linux-gnu
4,0K    /usr/lib/websockify
84K     /usr/lib/os-probes
81M     /usr/lib/hashcat
9,2G    /usr/lib
Habituellement c'est /var le coupable mais là, c'est /usr !!!
Je ne sais pas trop quoi faire ! apt autoclean et autoremove n'y change rien !
Cherche plus en profondeur ce qui prends de la place (visiblement pas dans /usr/lib).
Il existe une commande pour trier les fichiers d'un répertoire par order de taille croissante, sinon fait le depuis un navigateur de fichiers.
franb
Utilise xdiskusage pour savoir d'où vient le problème, ça te donne une image interactive de l'occupation de ton disque et en te déplaçant tu vois rapidement le souci
