gfroid
Messages : 420 Inscription : 11 juin 2016, 02:43
Status :
Hors-ligne
01 nov. 2016, 18:16
Salut la communauté debian,
j'ai un petit soucis avec l'update de flash player...
update-flashplugin-nonfree --status
Flash Player version installed on this system : 11.2.202.635
Flash Player version available on upstream site: 11.2.202.643
flash-mozilla.so - auto mode
link currently points to /usr/lib/flashplugin-nonfree/libflashplayer.so
/usr/lib/flashplugin-nonfree/libflashplayer.so - priority 50
Current 'best' version is '/usr/lib/flashplugin-nonfree/libflashplayer.so'.
update-flashplugin-nonfree --install --verbose
options : --install --verbose --
temporary directory: /tmp/flashplugin-nonfree.CzwCnN6Mdp
importing public key ...
selected action = --install
installed version = 11.2.202.635
upstream version = 11.2.202.643
wgetoptions= -nd -P . -v --progress=dot:default
downloading http://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp.11.2.202.643.sha512.amd64.pgp.asc ...
--2016-11-01 12:50:42-- http://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp.11.2.202.643.sha512.amd64.pgp.asc
Résolution de people.debian.org (people.debian.org)… 5.153.231.30, 2001:41c8:1000:21::21:30
Connexion à people.debian.org (people.debian.org)|5.153.231.30|:80… connecté.
requête HTTP transmise, en attente de la réponse… 301 Moved Permanently
Emplacement : https://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp.11.2.202.643.sha512.amd64.pgp.asc [suivant]
--2016-11-01 12:50:42-- https://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp.11.2.202.643.sha512.amd64.pgp.asc
Connexion à people.debian.org (people.debian.org)|5.153.231.30|:443… connecté.
requête HTTP transmise, en attente de la réponse… 404 Not Found
2016-11-01 12:50:43 erreur 404 : Not Found.
wget failed to download http://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp.11.2.202.643.sha512.amd64.pgp.asc
downloading http://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp10.sha512.amd64.pgp.asc ...
--2016-11-01 12:50:43-- http://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp10.sha512.amd64.pgp.asc
Emplacement : https://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp10.sha512.amd64.pgp.asc [suivant]
--2016-11-01 12:50:43-- https://people.debian.org/~bartm/flashplugin-nonfree/D5C0FC14/fp10.sha512.amd64.pgp.asc
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 1250 (1,2K) [text/plain]
Sauvegarde en : « ./fp10.sha512.amd64.pgp.asc »
0K . 100% 13,2M=0s
2016-11-01 12:50:44 (13,2 MB/s) — « ./fp10.sha512.amd64.pgp.asc » sauvegardé [1250/1250]
verifying PGP fp10.sha512.amd64.pgp.asc ...
copying /var/cache/flashplugin-nonfree/install_flash_player_11_linux.x86_64.tar.gz ...
verifying checksum install_flash_player_11_linux.x86_64.tar.gz ...
wgetoptions= -nd -P . -v --progress=dot:default -O /tmp/flashplugin-nonfree.CzwCnN6Mdp/install_flash_player_11_linux.x86_64.tar.gz
downloading https://fpdownload.adobe.com/get/flashplayer/pdc/11.2.202.635/install_flash_player_11_linux.x86_64.tar.gz ...
unpacking install_flash_player_11_linux.x86_64.tar.gz ...
verifying checksum contents of install_flash_player_11_linux.x86_64.tar.gz ...
moving libflashplayer.so to /usr/lib/flashplugin-nonfree ...
setting permissions and ownership of /usr/lib/flashplugin-nonfree/libflashplayer.so ...
Flash Player version: 11.2.202.635
moving install_flash_player_11_linux.x86_64.tar.gz to /var/cache/flashplugin-nonfree ...
flash-mozilla.so - mode automatique
le lien pointe actuellement sur /usr/lib/flashplugin-nonfree/libflashplayer.so
/usr/lib/flashplugin-nonfree/libflashplayer.so - priorité 50
La « meilleure » version actuelle est « /usr/lib/flashplugin-nonfree/libflashplayer.so ».
calling update-alternatives ...
removing /usr/bin/flash-player-properties
removing /usr/share/applications/flash-player-properties.desktop
removing /usr/share/icons/hicolor/16x16/apps/flash-player-properties.png
removing /usr/share/icons/hicolor/22x22/apps/flash-player-properties.png
removing /usr/share/icons/hicolor/24x24/apps/flash-player-properties.png
removing /usr/share/icons/hicolor/32x32/apps/flash-player-properties.png
removing /usr/share/icons/hicolor/48x48/apps/flash-player-properties.png
removing /usr/share/pixmaps/flash-player-properties.png
installing /usr/bin/flash-player-properties
installing /usr/share/applications/flash-player-properties.desktop
installing /usr/share/icons/hicolor/16x16/apps/flash-player-properties.png
installing /usr/share/icons/hicolor/22x22/apps/flash-player-properties.png
installing /usr/share/icons/hicolor/24x24/apps/flash-player-properties.png
installing /usr/share/icons/hicolor/32x32/apps/flash-player-properties.png
installing /usr/share/icons/hicolor/48x48/apps/flash-player-properties.png
installing /usr/share/pixmaps/flash-player-properties.png
end of action --install
cleaning up temporary directory /tmp/flashplugin-nonfree.CzwCnN6Mdp ...
end of update-flashplugin-nonfree
je tourne en rond :(
Merci d'avance
Debian stretch Xfce, lenovo T500, Intel(R) Core(TM)2 Duo CPU P8700 @ 2.53GHz 800,00MHz.
If life is a tragedy, then lets make it.
Messages : 6184 Inscription : 24 avr. 2016, 18:41
Status :
En ligne
Messages : 744 Inscription : 22 avr. 2016, 12:05
Status :
Hors-ligne
01 nov. 2016, 19:10
pour mettre à jour flashplayer je charge le tar.gz directement chez adobe et je l'installe.
kitmale
Messages : 733 Inscription : 25 avr. 2016, 09:39
Status :
Hors-ligne
01 nov. 2016, 19:54
Sans compter le fait que d'après ce que j'ai lu il y a quelques jours adobe ne fera plus de paquets pour linux. On dirait que les gros groupes ont décidé de passer outre les libristes.
gfroid
Status :
Hors-ligne
01 nov. 2016, 20:53
D'accord, merci. Est ce que je peux vous demander comment on fait pour suivre la progression de la correction d'un bug?
gfroid
Status :
Hors-ligne
01 nov. 2016, 20:54
marcastro a écrit : pour mettre à jour flashplayer je charge le tar.gz directement chez adobe et je l'installe.
c'est ce que j'ai fait aussi.
gfroid
Status :
Hors-ligne
01 nov. 2016, 20:55
kitmale a écrit : Sans compter le fait que d'après ce que j'ai lu il y a quelques jours adobe ne fera plus de paquets pour linux. On dirait que les gros groupes ont décidé de passer outre les libristes.
t'as lu ça où? On peut avoir l'info? Quelle est la source?
kitmale
Status :
Hors-ligne
Status :
Hors-ligne
02 nov. 2016, 09:45
J'ai appris à lire
mais tu n'as lu que la moitié; les maj de sécurité(si on peut encore utiliser le mot sécurité concernant cet immonde flash) seront toujours publiées. Ceci dit cette version flash pour linux ne fonctionnera pas pour tous les sites qui demandent encore ce maudit plugin et en ce cas il faudra bien se rabattre sur pipelight.
Status :
En ligne
02 nov. 2016, 09:56
en cas de problème avec le flashplayer, je passe par chromium. Il a le "flashplayer inside", pas besoin de plugin.
Status :
Hors-ligne
02 nov. 2016, 10:25
piratebab a écrit : en cas de problème avec le flashplayer, je passe par chromium. Il a le "flashplayer inside", pas besoin de plugin.
ne fonctionne pas pour tous les sites demandant flash:exemple 6play.
hybridemoineau
Messages : 390 Inscription : 24 avr. 2016, 15:34
Status :
Hors-ligne
02 nov. 2016, 12:43
Seuls les passionnés de flash ou ceux qui corrigent des copies peuvent savoir quelle est l'actualité de flash...Seul Flash connait Flash.
Ii y a donc une reprise de Flash pour Linux (je cois qu'ils en avaient parlé sur Linuxfr.org):
http://www.omgubuntu.co.uk/2016/09/adob ... lash-linux
Mais il y a des soucis avec flash sous chromium, semble t-il, via debian-fr.xyz je crois (et donc avec pepper-flash), c'est le fil qui s'affiche juste en dessous de TRucs et astuces quand on se connecte:
viewtopic.php?f=7&p=7777#p7777 .
Le premier qui parle de Gnash ou de silverlight ou de flash.so à copier en user flash dans le répertoire f.fs aura comme gage d'ouvrir un nouveau fil.
Status :
Hors-ligne
02 nov. 2016, 12:52
merci pour l'info que j'ignorais;l'idéal serait bien sûr la disparition pure et simple de cette abomination calamiteuse que représente flash.
kitmale
Status :
Hors-ligne
02 nov. 2016, 12:58
marcastro a écrit : J'ai appris à lire
Ok j'aurais du fermer ma gu**le mais lemessage sur adobe etait clair!! tu as vulemessage sur la page d'adobe!?!
Adobe Flash Player 11.2 sera la dernière version prenant en charge la plateforme Linux.
et je me fiche des maj de sec car je parle des maj suivant l'evolution des languages
Ecoute, je sais que les sites que j'utilise nécessitent flash actualisé! et pas d'autres
Pas la peine de metomber dessus chaquefois que jedis qqch!!
kitmale
Status :
Hors-ligne
02 nov. 2016, 13:06
Chromium ? hummm ..... c'est pas google?
Status :
En ligne
02 nov. 2016, 18:01
chromium est la version de chrome dont tout les crampons google ont été virés.
Messages : 1343 Inscription : 23 avr. 2016, 23:37
Diaspora* : https://framasphere.org/u/hucste
Contact :
Status :
Hors-ligne
04 nov. 2016, 12:31
Très bonne revue, complète, sur Linuxfr ... merci @hybridemoineau.
Status :
En ligne
04 nov. 2016, 13:41
En attendant, difficile de se passer de flash, même nos télévisions nationales en font un gros usage sur leurs site.
(M6 replay par exemple)
